  1. Sep 15, 2023 at 4:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  2. Sep 15, 2023 at 4:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Sep 15, 2023 at 4:55 AM
    Ok, for you, sold. When you picking up?
    bmf4069[QUOTED] likes this.
  4. Sep 15, 2023 at 5:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Lol, I would like a set of those, but I gotta wear these Coopers down first.
  5. Sep 15, 2023 at 6:14 AM
    C'mon man, just stretch those 16s to fit 17" wheels! ;)
    But seriously, sell them bastards off to pay for my shoes, then spend the extra $$ on new soles. :yes:
  6. Sep 15, 2023 at 6:26 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    All I know is my 295/75r16s rubbed the back of the wheel wells when articulating off road, especially when articulating and turning before, when I was on the D setting. I've been running the F setting for a few years with no issues and rarely rub now. It's gotta be a hard stuff of the tires while turning to be a slight rub now.
    assassin10000[QUOTED] likes this.
  7. Sep 15, 2023 at 6:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That first fill up in the virus is so refreshing after being in the truck
    bmf4069, NUDRAT[OP], Festerw and 2 others like this.
  8. Sep 15, 2023 at 6:34 AM
    I brought the truck in clocked at "D" (SPC logo parallel to tire, per SPC's reco) and I was at roughly mid-slot on the driver's side. Passenger side was slotted halfway between center and outside, like if the tire was "0" on the slot, and the coilover was 10, it was set around 7.5, while the driver side was more like a 5.
    I just checked, I'm still clocked at "D", and it doesn't seem like I'm very far off from where I originally had things slotted up top. They told me they had the 'younger technician' on alignment that day, I'm thinking he didn't touch anything on the UCA at all, solely aligned using cams. It would also explain the lack of change in before/after. I think he was dialing in based on the machine more than anything.
    I think I probably need to re-clock at "C" before going in, and try to re-slot the UCA near center on both, and request staying closer to 2.4-2.6 on the caster, and adjust down the camber a bit, sound about right?
  9. Sep 15, 2023 at 6:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sounds like you had a similar experience as me. At least your caster wasn't at two different levels like mine. Crazy how hard it is to find a shop that can figure these SPC arms out. Or they just don't GAF.
    DJenerated likes this.
  10. Sep 15, 2023 at 6:40 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Late night bee is the best bee
  11. Sep 15, 2023 at 6:48 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  12. Sep 15, 2023 at 6:49 AM
    DJenerated
    Dija
    The Lone Star State
    I bet you are correct. When I brought mine in for alignment, I made a copy of the SPC chart for the techs and they didn't even touch the UCA. Even after I explained to them that they were adjustable and I didn't know what I was doing when I installed them lol.
    I rode with em the way I installed em which was basically just like yours, until I swapped my Toytecs for Kings
    It's easier to clock em to center with a big level.
  13. Sep 15, 2023 at 6:51 AM
    My guess is this, but full disclosure: I understand relatively little about alignments, having never used any of the machines they're using. I've only ever done "shadetree shop alignments" to get things good enough to drive w/o killing tires until I get professional alignment done. And based on 'before' numbers I've seen, I do it pretty gd well enough. :D
    The upper pivot (i.e. UCA/UBJ for us) is typically static on most vehicles I've owned (at least), and when you go in, the technician is only expecting to work with two LCA cam/adjusters to move the wheel across X/Y/Z axis to dial things in.
    SPC UCA adds two additional articulation points at the upper pivot (UBJ) to achieve those same goals: Slot milled into the arm allows flexibility for camber by sliding the joint in/out at the upper pivot point, and their clockable UBJ lets you crank the caster way the hell up and way the hell down. That's is awesome for offroad, but if you're a regular alignment dude who only ever works with the UBJ/UCA being a fixed pivot point, the basic alignment algebra you already know just became full-blown trigonometry because you can eek out caster and camber from up top or down below.
    I'm going to take a wild stab here and say "something needs to be in a fixed position". Like, I'm guessing there's probably an ideal range someone familiar with these UCA would either use on (A) the cams or (B) the UCA. For me, I'm thinking if I can get the uppers to mid-slot, and clocked at "C", and with those set, let the tech know I want to caster be in the 2.4-2.6 range and camber closer to -0.2/-0.3, he can probably get me there using the lower cams.
  14. Sep 15, 2023 at 6:52 AM
    DJenerated
    Dija
    The Lone Star State
    This!
  15. Sep 15, 2023 at 8:54 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nice. There are times it helps but usually it's the lowers on toyota/lexus vehicles that get the needed clearance.
    Sounds like a plan.
    Especially if the numbers they talked about were near what @empty_lord and I recommend. What you got clearly is not.
    shifty`[QUOTED] likes this.
  16. Sep 15, 2023 at 9:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The way it was explained to me was you need to have them set the cams at their midpoint, then use the UCA to get close, then fine tune with the cams.
    But my first experience was very similar to yours, they told me the cams were maxed out and it was 'as good as it's going to get" then I asked if they adjusted the arms and they told me no "because you installed them backwards". After driving back to the shop and showing them no I did not you can literally move them anywhere, they charged me an extra 1/2 hour because they couldn't be bothered to read the instructions I had them staple to the work order.
    shifty`[QUOTED] and FirstGenVol like this.
  17. Sep 15, 2023 at 9:18 AM
    DJenerated
    Dija
    The Lone Star State
    You're not the first person to tell me not to do what I did. But I didn't get this way by always listening to others. Lol
    I'd still be rubbing if I hadn't done it my way. And that would make my offroading experiences much less enjoyable. I'd likely have to spend $1k on Solo UCAs to achieve the same affect. No point when I've already got the SPCs. At least until I buy 35's... Then the Solos will likely be purchased and a 1in body lift installed
  18. Sep 15, 2023 at 9:25 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I'm not saying, not to do what you did. I'm just saying the majority of the time it isn't necessary.
    If it works, it works and screw the naysayers. With big tires and the many different setups (lift amount/height, arms, bumpers, amount of hammering and/or cuts), you gotta do what you gotta do.
    shifty` and DJenerated[QUOTED] like this.
  19. Sep 15, 2023 at 9:28 AM
    DJenerated
    Dija
    The Lone Star State
    :amen:
  20. Sep 15, 2023 at 10:10 AM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Hey how do we feel about removing one of the tailgate cables and leaving it off to fit a deezee style tailgate assist? Is that gonna cause wonky tilted pressure over time and be a problem?
  21. Sep 15, 2023 at 10:14 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Depends on if anything of weight will be set on the tailgate.
    If never then it doesn't matter. If yes, then it can tweak the tail gate.
    TXTundraGuy23[QUOTED] and Mr.bee like this.
  22. Sep 15, 2023 at 10:16 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I wouldnt wanna stand on the tailgate with a single cable. Good way to make the TG hard to open.
    but theres a torsion spring some folks use.
    TXTundraGuy23 likes this.
  23. Sep 15, 2023 at 11:23 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
  24. Sep 15, 2023 at 11:25 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Did you use a coupon or promo code? Think I'm going to order a set of regular duty ones. I already have air bags and rear sway bar waiting to be installed, and don't want the lift you need.
  25. Sep 15, 2023 at 11:38 AM
    I tried to find a promo code, but came up short. After about 10 minutes of scouring the usual suspects for one, I decided "aww, hell ... $500 shipped for everything seems fair" and pulled the trigger.
    FWIW, UPS ground was ~$137 shipped for me. Fedex Ground was ~$91. I hate FedEx, but I'm also a cheapskate on some things. Fingers crossed they arrive intact.
    txagg[QUOTED] likes this.
  26. Sep 15, 2023 at 11:56 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Looks like the Husky brand on Rock Auto is the same price shipped as these. Are these superior quality? If not, no rush to order
  27. Sep 15, 2023 at 12:03 PM
    I also saw Dorman had the exact same part number in scAmazon's site not too long ago. I'm assuming ATS is making for multiple sources. They may be the same.
    I only purchased through ATS b/c there a "known quantity", really. Others with my cab type have used the specific product, and now I know (in hindsight) could use another half-inch or so of rear lift, and Icon doesn't want me keeping my overload in to stay how high I am currently, and others have gotten as much lift as I have with Icon today and up to half an inch more ... I'm running with it. Worst case scenario, I'm getting a half-inch shim or spacer later to make up for things.
  28. Sep 15, 2023 at 1:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  29. Sep 15, 2023 at 2:09 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    How much lift did the ATS springs net?
  30. Sep 15, 2023 at 3:08 PM
    Everyone around here in 1GT land (were you not one of them?) is claiming 1.5” - 2”. Mine won’t ship until next Tuesday afternoon. Should have them by next Friday I think.
