  1. Jul 21, 2023 at 10:58 AM
    Sunnier
    Sunny
    San Diego, CA
    All of them sold by HF shoplifters running out the back door in El Cajon...
    bmf4069, txagg, Mr.bee and 1 other person like this.
  2. Jul 21, 2023 at 11:04 AM
    Sunnier
    Sunny
    San Diego, CA
    "Thank you!" I forgot to say before, but I got -5% without giving my phone number, thanks to you!
  3. Jul 21, 2023 at 11:05 AM
    shifty` Inside his chest they found ten thousand pencils
    You may very well be right, but this guy is in East Los at least (Montebello).
    At least I think Montebello is considered E.LA
    Sunnier[QUOTED] likes this.
  4. Jul 21, 2023 at 11:07 AM
    Sunnier
    Sunny
    San Diego, CA
    Oh, good. I get edgy buying locally stolen. :rolleyes:
    Also, Casey, I saw your post. :p
  5. Jul 21, 2023 at 11:10 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    bmf4069 likes this.
  6. Jul 21, 2023 at 1:44 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I lived in LA as a kid. Montebello is located east of East LA in western San Gabriel Valley. Back in the 60s I don’t think anyone consider Montebello part of East LA
  7. Jul 21, 2023 at 4:30 PM
    Sunnier
    Sunny
    San Diego, CA
    Today has been a tour of Toyota and after-market resources, trying to get a crash course in getting this gears and locker upgrade done right the first time. Started with my "personal" parts guy at Toyota in Santee. Got exploded diagrams, ordered OEM seals to replace everything between the new stuff and the remaining stuff. Then to the 2nd tied-for-top installer, then to my favourite alignment shop (separate work coming, so I figured I'd ask for a gear referral too), then back to my Toyota parts guy.
    Ok, smart people: I got a brief show-stand-tell instruction on where an ECGS bushing would go, and looked at a disassembled component wherein I saw a "needle bearing". Can you explain to me what's better about the ECGS-- it's smooth, no "needles" lining, so I'm guessing (did not have an ECGS bushing for side by side comparison) it's a bit larger, fits more tightly?? Or-?
    Meanwhile, the owner of the install shop that was at the top of my list told me he understands why some people want to replace the needle bearing with an ECGS-- especially if running long-travel and driving hard-- but he's a fan of having another OEM needle bearing on hand at install. If the original looks worn, replace it with another OEM.
    I gotta admit, as soon as I saw the needle bearing is lined with "needle" shaped spline, I could picture it holding the splines of the end of the part that fits inside to join. I cannot picture why these wouldn't be better than a smooth surface.
    So...
    I know y'all are fans of the ECGS, and the Toastmeister even shares the Tool of Goodwill. Can you please drop some wisdom on me?
    FrenchToasty likes this.
  8. Jul 21, 2023 at 4:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    https://www.tundras.com/threads/best-gen-ecgs-bushing-tool.59664/#post-1563691
    I definitely wouldn’t put another oem needle bearing back in. ECGS bushing is solid bronze? Maybe and I believe a tighter fit to the axle.
    If your pulling and dropping off gears, it’s even more so easy to do, “while your there” kinda thing
    Karma drove his truck harder than you probably…….
    Sunnier[QUOTED] and FirstGenVol like this.
  9. Jul 21, 2023 at 5:26 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    OEM or die!
    Petrol
    https://youtu.be/OTIsn_i-T-s
    NUDRAT[OP] and FrenchToasty like this.
  10. Jul 21, 2023 at 5:33 PM
    FrenchToasty
    Mo
    Bone stock
    DJenerated[QUOTED] likes this.
  11. Jul 21, 2023 at 5:34 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Used to love watching Trucks! or was it called Gearz!??
    DJenerated and FrenchToasty like this.
  12. Jul 21, 2023 at 5:51 PM
    DJenerated
    Dija
    The Lone Star State
    Trucks! I think gears was Stacey's later show after he retired from Trucks!
    artsr2002[QUOTED] likes this.
  13. Jul 21, 2023 at 5:54 PM
    DJenerated
    Dija
    The Lone Star State
    4 inch imho is the best looking yet still functional lift
  14. Jul 21, 2023 at 6:17 PM
    Sunnier
    Sunny
    San Diego, CA
    What lift is best in your IMLHO or IMDO? :boink:
  15. Jul 21, 2023 at 6:19 PM
    Sunnier
    Sunny
    San Diego, CA
    Ok, I think I'm almost there.
    Now I need to know, where do I order the "solid pinion spacer"? Who manufactures it, and where can I buy it?
    I think I only need one for the back (because the front is already fairly well protected, am I right)?
  16. Jul 21, 2023 at 6:22 PM
    DJenerated
    Dija
    The Lone Star State
    What? :confused:
  17. Jul 21, 2023 at 6:27 PM
    Sunnier
    Sunny
    San Diego, CA
    Well, you gave your honest opinion. I figure, based on the qualifier, that you offer other, less honest or dishonest, opinions. What are those?
    bmf4069, DJenerated and Casper421 like this.
  18. Jul 21, 2023 at 7:24 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I got mine here:
    https://trail-gear.com/toyota-solid-pinion-spacer-kit.html
  19. Jul 21, 2023 at 7:27 PM
    Sunnier
    Sunny
    San Diego, CA
  20. Jul 21, 2023 at 7:39 PM
    The splines do not ride on the needles, the smooth part of the shaft does. The needles corrode and wear down. The ECGS bushing can’t wear out as it has no needles. It’s impregnated with some kind of lubricant that makes it slippery. It fits tight and helps eliminate play. Worthwhile upgrade while you’re in there. Mine honestly was fine and probably didn’t need replacing. But I was already in there.
  21. Jul 21, 2023 at 7:59 PM
    daveeasa
    David
    I’m pretty well read on TW and this site re ECGS. I know of zero problems with it. Not to say nobody has ever had trouble but I haven’t read about it.
    contrast that with countless “vibe” threads where the ECGS bushing solved the problem definitively.
    There are not many no brainer mods out there but this is one of them. One and done. Who wants vibes? Not I.
    bmf4069, Sunnier and DJenerated like this.
  22. Jul 21, 2023 at 8:08 PM
    DJenerated
    Dija
    The Lone Star State
    8-12 inch lift :D
  23. Jul 21, 2023 at 8:16 PM
    Sunnier
    Sunny
    San Diego, CA
    Sold! Thank you for explaining why no splines is best. I understand. :)
  24. Jul 21, 2023 at 8:17 PM
    Sunnier
    Sunny
    San Diego, CA
    Only good vibes.
    daveeasa[QUOTED] likes this.
  25. Jul 21, 2023 at 8:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Latest upgrades/modifications.
    bmf4069, Mr.bee, FrenchToasty and 2 others like this.
  26. Jul 21, 2023 at 9:17 PM
    Casper421
    In the woods
    06 DC
    Found a high rise Leer shell off a t100 for basically free. A high rise isn’t my first choice but it’s hard to pass on this deal. Wonder if it’ll fit a dc?
    FrenchToasty, DJenerated and Sunnier like this.
  27. Jul 21, 2023 at 9:26 PM
    Azblue
    The Dirty T ( ^_^)_且
  28. Jul 21, 2023 at 10:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Anyone got any ideas on how I can mount some kind of holder for my 3/8 and 1/2 drive extensions? The female end is about a millimeter larger than the locking collar near the end
  29. Jul 22, 2023 at 12:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thinking of putting one of these on the virus for thr high mount light
    Link
    Thoughts? Looks straight forward
  30. Jul 22, 2023 at 4:17 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Some guy on the Facebook page got a topper for a T100 recently and it seemed to fit great. I don't remember if he had a DC or AC though. Definitely worth a shot.
    Casper421[QUOTED] likes this.
