  1. Jul 19, 2023 at 2:05 PM
    Sunnier
    Sunny
    San Diego, CA
    Lurking for any info on A/C recharge. There was something I couldn't get from a dealer that prevented me getting a recharge from French Toast himself. Not sure if that was a part I'd for sure need, or a 'good to have on hand in case you need it' kind of thing, but whatever, I heard from a couple dealers that it's maybe not gonna be made again-?
    Meanwhile, I owed a favour of his choice to a friend, who picked me leading him on a trail run this last Sunday. In 106° temp (115° in Hulk's cab). I'll call that the least fun off-road trip in my experience.
    des2mtn likes this.
  2. Jul 19, 2023 at 2:13 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You're such a badass.
  3. Jul 19, 2023 at 2:19 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    New ECU didn’t change a thing. I’m at a loss, it’s got to be a wiring issue.
  4. Jul 19, 2023 at 2:31 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s not that hard, in my eyes, but you’ll be missing a few things to properly, you can’t use the recharge cans from AZ with normal gauges, you need a tank, and also the low side adapter for the fitting on the car. And a scale.
    What you could do(still need the low side adapter) is evacuate the system, let it set to leak check, take off gauges, and then hook up one or two of the small cans and guesstimate how much your putting in as close to the factory charge weight as you can
    Tundra2[QUOTED] and KNABORES like this.
  5. Jul 19, 2023 at 2:38 PM
    shifty` Inside his chest they found ten thousand pencils
    I swear you replied to this one already :D
    FrenchToasty likes this.
  6. Jul 19, 2023 at 2:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    @BubbaW you might've already posted, but got a wiring diagram for the add? And explain to me which signals to override if i wanted to run 2-low? And maybe a t-case wiring diagram to see if i could force a neutral.
  7. Jul 19, 2023 at 2:43 PM
    Sunnier
    Sunny
    San Diego, CA
    Nope, I sure wasn't. I was counting the minutes. But I found a new route for the SoCal 1st gens to run when it's less hot than hell. So that was a silver lining.
  8. Jul 19, 2023 at 2:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Damn, seems like it'd be best to let the dudes at raben do it then.
  9. Jul 19, 2023 at 2:53 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    100*+ & picks truck parts over overpriced concert tickets. Effin' winning.
    i've been fighting tantrums every morning the clouds burn off & while i only do cheap concerts, i bought an extra motorcycle instead of truck parts and have been living in regret ever since.
    bmf4069, JasonC. and Sunnier like this.
  10. Jul 19, 2023 at 2:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    do they have the fancy machine that measures what they take & how much to put in? Probably a $10k snapon tool. But no guess work & makes sure theres no leaks before charging.
    what about wingin' it for $40? Whats it going in? Maybe find the weight it needs?
  11. Jul 19, 2023 at 3:00 PM
    FrenchToasty
    Mo
    Bone stock
    Possibly, then it might be warrantied as well?
    Mr.bee likes this.
  12. Jul 19, 2023 at 3:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's going in the virus. If I have to throw a $40 can at it once every few years, that'd be fine, my biggest "issue" is needing a vacuum pulled because I opened the system when I hit the deer.
    And then opened it again fully when we replaced the condenser/dryer combo.
    I don't know. My local Raben is sketchy as fuck. They'll do a half job, and then expect payment for a full job.
  13. Jul 19, 2023 at 3:27 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    attached the 4 pages from 02 EWD dealing with 02 AC 4WD, if that helps.
    Seriously tho, maybe the heat got to me today but what are you meaning ?
    bmf4069 and JasonC. like this.
  14. Jul 19, 2023 at 3:33 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    If i wanted a t-case neutral, and maybe its possible mechanically. What signal does it look for to swap from 2hi to 4hi?
    a t case neutral would allow a flat tow.
    but if i get a marlin tacobox it'll be mechanical & have neutral, so i'd just have to trick the computer.
    interperate this for me, if i want ed the truck to think its activated, but it actually be deactived.
    i could have a swich for normal, and bypassed to disengage the add, let the diff spin. Might be fun.
    t-case neutral is only really useful if i wanna flat tow, but my jeeps did it & i used it.
  15. Jul 19, 2023 at 3:54 PM
    Sunnier
    Sunny
    San Diego, CA
    Oh, yeah, you got to recalibrate your priorities. Anyway, 100° here is super hot, but nowhere near as hot (because of humidity) as 100° where you are. But tantrums just add to the over-heating. I just hide in the shade (when not off-roading). You, on the other hand, post tales of productivity every day. :angrygirl:
  16. Jul 19, 2023 at 3:58 PM
    Sunnier
    Sunny
    San Diego, CA
    After BubbaW weighs in, I'm thinking g you might want to go read over Cruzer's thread, then hit him up to weigh in on this. Seems tricking his truck into do stuff the engineers didn't build it to do, is his current main objective. Maybe something he's done will help you do what you have in mind.
    Mr.bee[QUOTED] and FrenchToasty like this.
  17. Jul 19, 2023 at 3:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Some days.
    had to get this done by 3:30 so i wasnt in the sun. Actual oil change tbd. After the sun gets behind the house i'm thinking about cutting some cactus i mowed over last month. Ya'll have more humidity than me, right? Just i might have a couple days without wind.
    but i keep truckin. Every little win is still a win.
    yesterdays body rinse:
    todays degreaser rinse (both):
  18. Jul 19, 2023 at 4:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    This is out of BubbaW's wheel house for sure but it took me a bit to finally figure out what Casey was talking about. :popcorn:
  19. Jul 19, 2023 at 4:05 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Damn, that’s cheap. Valvoline specials here are $99 while most shops and the dealer charge $150/charge.
  20. Jul 19, 2023 at 4:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    There's a wiring kit for manual t-case swap that has an ADD switch, I'll have to dig around for it from when I was compiling information for my future manual t-case swap. That's how I want to go about getting neutral and 2LO and AWD all in one. Too bad the early Seqouia cases aren't Torsen. I feel like 2LO would have helped on some of my descents in Moab.
    Not sure if you can really trick the T case into neutral. When the shift fork shaft is all the way in, it's locked in 2WD, then it moves out to shift into 4WD then Hi/lo. Maybe some electrical guru to get the shift shaft in between phases?
    bmf4069, BubbaW and Mr.bee[QUOTED] like this.
  21. Jul 19, 2023 at 4:22 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Oh man! That weller 12 is so good. I see Birthday bourbon and the woodford historical entry that I also have on my shelf!
    I’ve been knee deep in painting/installing trim throughout the basement, building a tree house for the kids and now tearing off my patio to redo.
  22. Jul 19, 2023 at 4:27 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    c'mon, give those of us that built treehouses a pic of the treehouse. Mine was 3 layers built into an ash & the winch crank was bicycle parts.
    bmf4069, txagg, Sunnier and 2 others like this.
  23. Jul 19, 2023 at 4:31 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
  24. Jul 19, 2023 at 4:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Standby.
    Also the bike winch is a great idea!
    still needs a door, windows and paint but most of its done.
    bmf4069, txagg, 805Tundra and 5 others like this.
  25. Jul 19, 2023 at 5:10 PM
    Jack McCarthy
    Bill
    North of Boston
    bmf4069, txagg, 805Tundra and 4 others like this.
  26. Jul 19, 2023 at 5:26 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  27. Jul 19, 2023 at 5:32 PM
    FrenchToasty
    Mo
    Bone stock
    Looks awesome!!!
    My dad used to build redwood swing sets for people with too much money, he did one with a Indiana Jones zip line, I got to test it out first.
    CodyP[QUOTED] likes this.
  28. Jul 19, 2023 at 5:35 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Better than awesome. Mine looked like a couple 10 year olds collected trash after a hurricane.
    Sunnier, CodyP, JasonC. and 3 others like this.
  29. Jul 19, 2023 at 5:36 PM
    Azblue
    The Dirty T ( ^_^)_且
    Don't you guys have jack stands? Easiest way to do a rotation is jack the rear of the truck up by the axle pumpkin and set it on a jack stand on both sides. Then use your jack to take of whichever front wheel you wish while both rear tires are in the air, remove and swap either side.
  30. Jul 19, 2023 at 5:36 PM
    FrenchToasty
    Mo
    Bone stock
    Soooo…… you were 10 when you built yours?
    bmf4069 and Sunnier like this.
