  1. Jul 1, 2020 at 10:22 AM
    #4861
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They make a thing called a d'versibit. It's a 6' long flexible drill bit that I'm betting you could squeeze in there. Maybe you could redneck something up out of it?
    Tundra2[QUOTED] likes this.
  2. Jul 1, 2020 at 10:23 AM
    #4862
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    And with all this talk of toyota/lexus SUVs, is there a list or page of all the SUVs that have lexus counterparts? Or one that has a what's what deal? I don't know how to ask what I'm asking. :oops:
    Tundra2 likes this.
  3. Jul 1, 2020 at 10:25 AM
    #4863
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    5th gen 4runner with supercharger!
    Toyota 1GR engine tuning
    1GR-FE Supercharger
    TRD Company produces supercharger kits designed out of the Eaton M90 supercharger with intercooler, ECU and all other aftermarket parts, specially for the GR engines.
    In order everything to work appropriately, you need to lower compression ratio. To do this, you need to buy a thick cylinder head gasket or forged CP Pistons fitted to 9.2 and Carrillo connecting rods. Besides, you may need a TRD inlet system and 3-1 design headers kit. When these performance parts bolted on your 1GR single VVTi, the engine will develop 300-320 horsepower and torque will be 450-500 Nm.
    Apart from the TRD supercharger kit, you will be able to find the other, more powerful solution. Doing port and polish, you will get more than 350 horsepower. The TRD supercharger kit is the simplest, not a too much loading engine.
    Hooptytrix[QUOTED] likes this.
  4. Jul 1, 2020 at 10:34 AM
    #4864
    rock climber
    I was replacing the UCA so yeah I did swing the spindle out. I didn't disconnect the brakes, but did unscrew the ABS line from off the UCA. I do remember having to maneuver it just right to fit the clamp.
  5. Jul 1, 2020 at 10:35 AM
    #4865
    speedtre
    speedtre New Member
    Inland Northwest
    FJ80 = LX450 (thanks @imDementeD
    LC100 = LX470
    LC200 = LX570
    4th Gen 4Runner = GX470
    5th Gen 4Runner = GX460
    Rav4 = NX
  6. Jul 1, 2020 at 10:38 AM
    #4866
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hmmm.... I'll begin investigating.
  7. Jul 1, 2020 at 10:43 AM
    #4867
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So the sequoia doesn't have a direct equivalent, right? And the difference in those 2 groups is just generations? The top is land cruisers?
  8. Jul 1, 2020 at 10:47 AM
    #4868
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Sequoia is based on Tundra, no Lexus alternative.
    The top is definitely the LC's and yes, different generations. LX450 is the FJ80 which is the first Lexus model of the LC. The 300 series should be out soon.
    Lastly, the 4runner is NOT a direct GX470/460. They do share a lot of similarities but the GX series is based on the Land Cruiser Prado (not sold in the US). The 4runner shares some bits but the GX is superior to the 4runner.
    Hooptytrix and speedtre like this.
  9. Jul 1, 2020 at 10:58 AM
    #4869
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I tried to keep the camera angle the same as possible for both pics.
    I didn't do a very good job at that
  10. Jul 1, 2020 at 10:58 AM
    #4870
    speedtre
    speedtre New Member
    Inland Northwest
    4th Gen 4runner and GX470 share the same chassis and in the case of the V8 4Runner, the same engine. They both share much with the Prado, but have significant differences too.
    Hooptytrix likes this.
  11. Jul 1, 2020 at 11:38 AM
    #4871
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    The GX460 has a timing chain vs the 470 having the belt. Correct?
  12. Jul 1, 2020 at 11:38 AM
    #4872
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Jul 1, 2020 at 11:45 AM
    #4873
    speedtre
    speedtre New Member
    Inland Northwest
    Yes, the 470 uses the same 4.7 in our trucks, while the 460 uses the updated 4.6 engine that also goes in the 2nd/3rd gen Tundras...
  14. Jul 1, 2020 at 11:55 AM
    #4874
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Had to rotate the pass horn up some. Will post video links later. Waiting on them to upload. :D
    Painfully slow. o_O
    NUDRAT[OP] likes this.
  15. Jul 1, 2020 at 12:30 PM
    #4875
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Decided it best to wear an undershirt so you guys wouldn't have to look at my plumbers crack today. I haven't watched any of the videos so I'm not sure how well it worked, or if it was worth the extra heat.
    Weather says feels like 90°F with 70% humidity.
    Darkness likes this.
  16. Jul 1, 2020 at 12:31 PM
    #4876
    imDementeD
    The gx and Prado are same lc120s just difference in the aspect where the lc is different than the lx (lc100s)
    The 4runner is the one that does share similarities but not the same.
  17. Jul 1, 2020 at 1:21 PM
    #4877
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Jul 1, 2020 at 1:36 PM
    #4878
    Professional Hand Model
    Hand Protectors
    Were you able to use those adjustments at the hinges?
  19. Jul 1, 2020 at 1:42 PM
    #4879
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. For door seam all it took was removing the top 10 mm bolt in the door hinge area. Bent the tab towards rear of cab slightly. Tightened bolts back up.
    Real nice.
    For the hood seam I loosened all 3 bolts on top of the fender, pushed in, and tightened back down.
  20. Jul 1, 2020 at 2:17 PM
    #4880
    Hooptytrix
    Dirty South
    Anybody have a roof rack on there truck?
  21. Jul 1, 2020 at 2:29 PM
    #4881
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  22. Jul 1, 2020 at 2:33 PM
    #4882
    Hand Protectors
    Not sure. The more I think about it the less I want to do it. I’d hate for a bolt to snap and then I just caused a problem to fix. On hold for now. I’m starting to investigate the FSM hard and need to find the gas tank dropping for fuel pump replace which was my reason for doing bed removal, but the tank still needs dropping even with bed off.
    Hooptytrix and Tundra2[QUOTED] like this.
  23. Jul 1, 2020 at 2:37 PM
    #4883
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Now, let me ask a question regarding my bed.
    The surface rust on it I will remedy. Would it be worth my time to buy rust-oleum bed liner, and go that route?
    Or just paint it, and put my plastic liner over it?
    Either way, the plastic liner is going back in. Not sure what the pros would recommend.
    Also, I can't remember what was recco'd for running boards.
  24. Jul 1, 2020 at 2:43 PM
    #4884
    Hand Protectors
    I used the Rustoleum Bed Liner on both the bed and rails and running boards. Proper prep is key. Even put a coat of Bed Liner on the Bed Liner. :rofl:
  25. Jul 1, 2020 at 2:46 PM
    #4885
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thinking of going red on the hooks.
  26. Jul 1, 2020 at 2:49 PM
    #4886
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Not sure how to prep the plastic bed liner. Any pointers?
    I remember your recco on the RBs
  27. Jul 1, 2020 at 3:24 PM
    #4887
    Hand Protectors
    Washed the topside with a stiff brush and soapy water. Let dry and spray.
  28. Jul 1, 2020 at 3:29 PM
    #4888
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My boss just called. I go back to work Monday night.
    Any advice on getting a second alignment opinion?
    I'm not sure going back Monday if that would be enough time to do a front end re-build since its my first time.
  29. Jul 1, 2020 at 3:29 PM
    #4889
    Hand Protectors
    Found some good FSM data for our engines. Discovered that my Old MAF Sensor was out of spec, too. Looks like there is Fuel Injector Spec here, as well, so I’ll test my old ones tomorrow.
    NUDRAT[OP], FrenchToasty and bmf4069 like this.
  30. Jul 1, 2020 at 4:23 PM
    #4890
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @FirstGenVol Brought it to my attention I never posted an "After" picture.
    The angles are slightly different. My bad.
