  1. Jun 6, 2023 at 5:37 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    It's different when you don't have a passenger. Or even when you do, but they aren't obedient lol. I used to drive with my windows cracked (2 full cranks) all the time because my A/C sucked and I was a smoker. Damn near every passenger I had would either want their window up while driving or would roll it up when they got out of the truck. Which pissed me off to no end, having to lean over and fix it everytime I dropped someone off. No matter how many times I told em not to.
  2. Jun 6, 2023 at 5:50 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Manual steering, non boosted brakes, windows with a crank and a clutch may seem to be too much trouble... ever had to split shift a two speed vacuum rearend with a non-synchronized transmission? or used a vacuum shifted overdrive?
    NUDRAT[OP] likes this.
  3. Jun 6, 2023 at 5:58 PM
    DJenerated
    Dija
    The Lone Star State
    I don't even know what language that is lol
  4. Jun 6, 2023 at 6:03 PM
    shifty` Goons of Hazzard
    Not following what you're looking to do; are you expecting your head unit to have a remote on/off switch of some sort that you can kick on while the truck is off to power bed-based speakers? Maybe a good one to run by @daveeasa
    Your owners manual has the gear oil weights you need for your specific truck. My truck, it's 75w90 recommended for the rear diff, transfer case, front diff.
    If your rear end has the LSD sticker on it, avoid synthetics. Supposedly there's some magic unicorn synthetic out there that'll work for LSD rear in these trucks, but I struck out. Install non-synthetic out back to avoid chatter. I went with Lucas 80w90 and it worked great. I started w/Mobil1 full synthetic and had chatter, added loads of additive, still had some chatter; I didn't want to add more additive, didn't want excess slip. Someone else on here mentioned they used 75w90 non-synthetic Valvoline and it worked with LSD rear. Seems the synthetics don't seem to coat enough in the gen1 LSD to avoid chatter after the truck sits a bit.
    For driveline: https://www.tundras.com/threads/black-hole-zerk-wtf.93630/
    bron-yr-aur[QUOTED] likes this.
  5. Jun 6, 2023 at 6:07 PM
    daveeasa
    David
    I don’t roll down the passenger side much. Just driver side and rear slider if it’s hot. In 30s the cabin is flushed and the A/C kicks in.
  6. Jun 6, 2023 at 6:21 PM
    DJenerated
    Dija
    The Lone Star State
    :confused:
  7. Jun 6, 2023 at 6:22 PM
    daveeasa
    David
    My ‘05 cabin is about 10 cubic feet of air. Maybe less. Flushes in thirty seconds.
  8. Jun 6, 2023 at 7:03 PM
    Sunnier
    Sunny
    San Diego, CA
    It sucked so bad, you stopped smoking? ;)
  9. Jun 6, 2023 at 7:28 PM
    DJenerated
    Dija
    The Lone Star State
    I just stopped smoking 6 months ago lol. I drove that truck throughout high school and college. I've bought 5 trucks since then, all with electric windows :D
    Sunnier[QUOTED] and JasonC. like this.
  10. Jun 6, 2023 at 7:31 PM
    DJenerated
    Dija
    The Lone Star State
    What flushes?
  11. Jun 6, 2023 at 7:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The stale whore air in the cab
  12. Jun 6, 2023 at 7:33 PM
    DJenerated
    Dija
    The Lone Star State
    Ok now I get it. Lol
  13. Jun 6, 2023 at 7:39 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Probably someone will come up with something way better, but one idea could be to wire all cab speakers to “front” and your bed speakers to “rear” and then you shift your audio to rear when you want bed jams? But then your cab audio would probably suck. Or does your head unit have any additional channels that output audio (like a subwoofer channel?) you could rework to run the bed audio?
    I think I’d just get a cheaper bluetooth speaker and say screw it.
    shifty`, DJenerated and NickB_01TRD like this.
  14. Jun 6, 2023 at 7:48 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Some kind of toggle switch not sure exactly how to wire it all up. On my last truck I had a loudspeaker under the truck for shenanigans, and just had a 3 position toggle switch on the back driver side speaker
  15. Jun 6, 2023 at 8:02 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Best way for @Mr.bee to run power/speaker wire is through the pressure equalization vents behind the rear seat, then route it from underneath using the 1 of the 2 forward drain holes at the back of the bed. No hole cutting other than the bedliner UNLESS he has the spray in liner which would be a no-go.
    Mr.bee likes this.
  16. Jun 6, 2023 at 8:18 PM
    https://www.jegs.com/i/JEGS/555/631094/10002/-1
    Sunnier likes this.
  17. Jun 6, 2023 at 8:31 PM
    daveeasa
    David
    I’ve done outside speakers before. With connectors to the kick panels where my junctions are and wire through the rear window.
    for a more permanent solution I’d go dual battery and bed mounted radio. But even better would just be a mobile radio and an inverter or dc charger in the bed. More multi-purpose and more jobsite mobility.
    shifty` likes this.
  18. Jun 6, 2023 at 9:01 PM
    Sunnier
    Sunny
    San Diego, CA
    JasonC. likes this.
  19. Jun 6, 2023 at 9:07 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Seeing some interesting options on the tube of yew.
    I think I may become one of those "who the F--- walls over two huge windows" former owners.
    It's not like I open them.
    bmf4069 likes this.
  20. Jun 6, 2023 at 9:09 PM
    NUDRAT
    SW CT
    that's when you switch to dealer plates - LOL
  21. Jun 6, 2023 at 9:12 PM
    NUDRAT
    SW CT
    Last soundproof room I saw / was in was at the Museum of Modern Art in NYC, when Tundra2's daddy was probably in short pants.
    It was freakishly effective & looked... well, angular. Not anything a house buyer would want to come across. Hopefully tech has changed.
    DJenerated[QUOTED] likes this.
  22. Jun 6, 2023 at 9:27 PM
    NUDRAT
    SW CT
    I'm guessing manual brakes & possibly drums front & rear in 1973
    Also good for minute adjustments so you can crack the window on the highway enough to get air, but not so much to get whistling.
    Depends how well the date is going. ;-)
  23. Jun 6, 2023 at 9:32 PM
    DJenerated
    Dija
    The Lone Star State
    Zing!:D
    NUDRAT[QUOTED][OP] likes this.
  24. Jun 6, 2023 at 10:08 PM
    NUDRAT
    SW CT
    shifty` likes this.
  25. Jun 6, 2023 at 10:27 PM
    Yup, small deep cycle 2nd battery with a box to hold the speakers and HU, something bluetooth-capable so you can remote contol the audio into it.
    Mr.bee likes this.
  26. Jun 6, 2023 at 10:27 PM
    RockAuto 5% discount code: 233736060177619741
  27. Jun 7, 2023 at 6:10 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Totally agreed, I just found the equivalent upgrade for my 1973 Chevy pickup. Once my initial focus on making it “go” is successful, I’ll then be working on “stop” and that looks great. I also want my kids to drive this one so stopping is a big plus.
    shifty` and Sunnier[QUOTED] like this.
  28. Jun 7, 2023 at 7:37 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Heads up on a rack for an AC if anyone wants
  29. Jun 7, 2023 at 7:48 AM
    Jack McCarthy
    Bill
    North of Boston
    Damn, I'm looking at 60K MSRP whether I'm buying a loaded 2023 Tundra SR5 or a Ford Raptor Ranger. Need to look at the pros/cons to both.
    bmf4069 likes this.
  30. Jun 7, 2023 at 8:07 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Well, a big con on the ranger is the blue badge on front and back.
