  1. Jun 5, 2023 at 4:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got storage in the boonies. And most of my shits plated. Till they stop giving me plates they can fuck off lol
  2. Jun 5, 2023 at 5:21 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Soundproofing a room makes a house unsellable?
    NUDRAT[QUOTED][OP] likes this.
  3. Jun 5, 2023 at 5:32 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Fiberglass insulation in the interior walls/floors and triple pane windows. The ideal living area would be heavy cinder block walls and concrete floors.
    BlueRay04 likes this.
  4. Jun 5, 2023 at 5:45 PM
    BlueRay04
    BlueRay04 B
    B
    2004 Blue Tundra SR5
    VTEC Wheels, Custom Reverse Camera, Tonneau Cover
    Basically, buy a German-built home :p
  5. Jun 5, 2023 at 5:55 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    First off, I would look into "Sound Deadening Drywall" it's much denser, and 2 sheets stacked will give you quite a boost in the quiet dept.! Also consider, since you are going to rip out the old drywall, put a fill of "Rock Wool" in those walls. I have 6" walls filled filled with the stuff, and the drywall. Also have dual Glaze windows, but there is more noise coming in thru the windows than the walls.
    Just Google "Sound Deadening Drywall"
  6. Jun 5, 2023 at 6:23 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I helped install this stuff in a duplex once, we just screwed it over the existing walls. Can't comment too much beyond that.
  7. Jun 5, 2023 at 6:33 PM
    daveeasa
    David
    For cheap and ugly, egg crate foam. I assume you want it looking better than that.
    NUDRAT[OP], JasonC., KK6PD and 2 others like this.
  8. Jun 5, 2023 at 7:59 PM
    empty_lord
    05 rollover special
  9. Jun 5, 2023 at 8:12 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You want to buy some 'hat channel'. They're metal strips that you screw to the studs, or even better, existing drywall. Then you'll screw another layer of drywall to the strips. What they'll do, is space the new layer of drywall about 1/2" away, so there's not a solid connection to the framed wall. That cuts down the sound traveling thru vibration. Then you want to seal every seam and penetration well. Around every light fixture box, electrical box, air duct, and around every door and window. There are a number of products specifically for sound sealing, but even just caulking will make a huge difference. If you really wanna get crazy, you can frame a second wall inside the room with a couple inch air space, and insulate the wall. As others mentioned, there are different types of drywall and insulation for sound. The hat channels make the most difference, as long as its sealed properly, in my experience, and I've done alot of soundproofing. Hat channels go on the wall and ceiling. You may find them called a different name.
    https://www.homedepot.com/p/Clark-W...Resilient-Channel-Single-Leg-727181/202090218
  10. Jun 5, 2023 at 8:57 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Sit in @bmf4069 ’s truck with the volume as high as you can stand for as long as you can stand, hearing problem solved :)
    But really, it might be worth calling a professional insulation company, they may be able to put new/additional insulation in an existing wall cavity without removing the wall board.
    If white noise does it they make little noise generators just for that, that’s certainly the cheapest and quickest solution.
  11. Jun 5, 2023 at 9:02 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    WHAT?
    shifty`, Sunnier, txagg and 1 other person like this.
  12. Jun 5, 2023 at 9:10 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    bmf4069[QUOTED] and DJenerated like this.
  13. Jun 5, 2023 at 9:13 PM
    DJenerated
    Dija
    The Lone Star State
    Come get your stuff, broski. You can just lock your family in the shed for a few hours this weekend. :D
    I have beer.
    And a pool.
    On second thought, you can bring the wife.
    :cheers:
    txagg[QUOTED] likes this.
  14. Jun 5, 2023 at 9:31 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I know! Have that 401k meeting in Htine this Friday or next. Can't remember which. They keep rescheduling.
    JasonC. and DJenerated[QUOTED] like this.
  15. Jun 5, 2023 at 9:44 PM
    DJenerated
    Dija
    The Lone Star State
    I might have to "store" that skid plate on my truck for science. What you going to do with my old one?
  16. Jun 6, 2023 at 10:27 AM
    We've hit a few trails like that so far. I don't think I realized how far up Ave of Giants was, we ended up doing Armstrong on the way up to our current spot between Manchester and Elk, our staging ground to hit some longer hikes, along with a few shorter ones. We did Caspar Creek and several Russian Gulch trails yesterday (the kids like falls and redwoods) along with Glass Beach as a wind-down. I think we're doing more water-side stuff today, probably starting on Navarro River and working our way out to the ocean. It's awesome here, but about 1000x more ticks here than what I found in PA or ME which I thought were notably "bad" (until here). How the hell do y'all deal with them?
    Beerwise, met an old friend and his wife who biked over at Anderson Valley Brewing (the road over the mountains was f'n nuts!) which ended up being more boring than I expected given the reviews. Too color-inside-the-lines for me, all but one of the IPAs were pretty basic. Also hit North Coast yesterday, which again for me was cool but known beer entity (Foggy Day tastes way better off the tap), but I wish I would've understood you can't actually see the brewery, and the pub/gift shop/brewery are all on different corners of an intersection. Beers were solid, but Cooperage was still hands-down the shining star so far, blindingly so. Wanted to hit Overtime Brewing while up in Fort Bragg, but they're closed on Monday, bummer.
  17. Jun 6, 2023 at 10:50 AM
    RUSTYNUTS likes this.
  18. Jun 6, 2023 at 12:12 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I've got a pair of 6x9's i wanna run stereo in the bed, prolly boxed. Prolly wanna run 6x9's in the front doors, too.
    how can i route the trucks stereo power to the rear if i need it? Like take all the power from the cab. Like a switch near the tailgate that diverts all power aft? Dont leave my doors open.
    DJenerated likes this.
  19. Jun 6, 2023 at 1:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Fotnot, JasonC., bmf4069 and 4 others like this.
  20. Jun 6, 2023 at 1:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Enjoy!!!
    Fotnot, Tundra2[QUOTED] and shifty` like this.
  21. Jun 6, 2023 at 1:22 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Random question, but you guys seem to know enough about everything. I looked at a 73 Ford manual pickup for my 17 year old last night. Super cool and smelled just like my grandpa. Brakes were really weak though, not mushy, just no power. The pedal feel was fine and it didn't drop to the floor. Is that typical of old trucks, or do you think new pads and rotors up front would fix that.
    My son's a good driver, but he's 17 and doesn't always see traffic patterns ahead so I want him to have decent brakes.
  22. Jun 6, 2023 at 1:26 PM
    des2mtn
    SW
    Tonto cover
    Does it have a brake booster? Might just be manual brakes :notsure:
  23. Jun 6, 2023 at 1:36 PM
    Sunnier
    Sunny
    San Diego, CA
    I learned to drive in a '69 Ford-- not sure about a '73-- which had manual brakes. Achieved best results by "pumping" the pedal. So in crisis braking, I sometimes revert to this. Which set me up well to not miss the ABS fuse in my play truck. So there's that.
    NUDRAT[OP] and Jack McCarthy like this.
  24. Jun 6, 2023 at 2:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Aaargh! Manual brakes and steering are not something to enjoy. I had to do it at one time in my life. Never again. Almost like crank windows but much worse
  25. Jun 6, 2023 at 2:10 PM
    daveeasa
    David
    I love my hand crank windows in the '05.
    NUDRAT[OP] and FrenchToasty like this.
  26. Jun 6, 2023 at 2:12 PM
    Jack McCarthy
    Bill
    North of Boston
    Only good for getting out of a submerged vehicle, IMO
  27. Jun 6, 2023 at 2:12 PM
    daveeasa
    David
    And forcing kids to do their own work.
  28. Jun 6, 2023 at 5:14 PM
    DJenerated
    Dija
    The Lone Star State
    You love leaning all the way into he passenger seat to roll down the window?
    I certainly don't miss that. My first truck I drove for about a decade was manual everything. I do miss the manual transmission sometimes though.
    Jack McCarthy likes this.
  29. Jun 6, 2023 at 5:17 PM
    Jack McCarthy
    Bill
    North of Boston
    @DJenerated, Dave forces his kid to roll it down instead.
  30. Jun 6, 2023 at 5:35 PM
    bron-yr-aur
    bron-yr-aur New Member
    Ché Calvo
    Windber, PA
    2004 DC 4x4/Tow pckg
    Mods: zip-tied PS line and tire shine
    Hey dude, I was searching for which oil to put in there (reading your thread “So you wanna…?” At the moment) and came across this post. Is it the same oil front and back? And I assume the correct oil will have something on the bottle about LSD-safe?
    And since we’re on the subject of maintenance, I’m searching for the grease points in the driveline. I found zerk fittings on the U joints. Any other places? A quick look and I didn’t see anything at the carrier. Anything to service there?
    Sorry for the newb questions, but my last 4x4 was a 1992 Toy with the 22re. Completely different animal, for sure.
