  1. Apr 24, 2023 at 10:19 AM
    shifty` I'm having daydreams about night things
    I'm assuming that one was intended for street-only, road queens, if the manufacturer claims it's a "STREET SERIES" prominently in their description.
    I actually take my truck out in the boonies for hiking, fishing, camping. It's a complete vanity purchase to a degree though. New wheels aren't going to give any performance boost, any realistic gain on the trails I'm running on, but whatever.
  2. Apr 24, 2023 at 12:14 PM
    Casper421
    In the woods
    06 DC
    What size tires are you gonna run?
  3. Apr 24, 2023 at 12:30 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I think we need a monday poll.
    35", 37", 40" or 44"s...
    bmf4069, FirstGenVol, shifty` and 2 others like this.
  4. Apr 24, 2023 at 1:25 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I didn’t even know faux bead-lock wheels were a thing. I thought you were joking initially.
  5. Apr 24, 2023 at 1:56 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Bet that it'll be close to stock. As in no cutting nothing.
    NUDRAT[OP] and shifty` like this.
  6. Apr 24, 2023 at 2:13 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I was looking for a commuter car and gave up on Camry's and Corolla's because the price people wanted for them was too much. I was looking at avalons and then found a lexus ES330 for less than that. Oddly enough, at least in Denver, the ES330 and ES350 sell for less than Toyotas.
    Total grandpa car, but maybe worth a look.
  7. Apr 24, 2023 at 3:26 PM
    Nope, wasn't kidding. I mean, the only purpose it saves is keeping your lips safe(r), and giving a 'visual inch' if it's the same color as the tire. If any.
    Curious to hear your opinion, and @assassin10000's input too.
    I'm debating between 275/70r17, 275/75r17, or 285/70r17. Not sure I want to lug the extra weight that half inch 285 will add. And with the visual inch the faux beadlock gives.
    Brand-wise, still going back and forth between Nitto Ridge Grapplers, Toyo AT2 and AT3. I keep catching myself doing a double-take, like, "Oooh, what tire is that?" only to see it's the Nitto RGs. The Toyos seem universally loved though, and seem better on noise with a tamer profile.
    If math is right, 17x9 w/-12 offset should put me @ ~4.5 BS if my math is right, so if this info is correct and my OEM 5-way splits are 17x7.5 and +18 that's 5" BS, I should be pushed out a little farther, and hopefully free and clear of rubbing suspension and maybe frame with the 285s (edit: Nope, with 9" wide rim at 4.5" backspace on an aggressive 275, I rubbed. Lesson learned: under 4.6 backspace is not conducive for a rim wider than 8.5" at 275 or 285 "typical" tire sizes for our truck). I think @alb1k was saying the DC sweet spot is around 4.75 BS, but AC seem to have less issue with clearance.
    I still need to get my COs & UCA etc. installed, though. Got the easy stuff done out back, but haven't had the few hours on a weekend to tackle the rest.
    KNABORES likes this.
  8. Apr 24, 2023 at 3:36 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Revere Beach? Lawrence? Is Roxbury still a war zone? :anonymous:
  9. Apr 24, 2023 at 3:43 PM
    Jack McCarthy
    Bill
    North of Boston
    Neither armpit are applicable unless you like to drive on people’s front lawns.
    NUDRAT[QUOTED][OP] likes this.
  10. Apr 24, 2023 at 4:19 PM
    Casper421
    In the woods
    06 DC
    How much lift are planning for up front? Think I remember you saying less than 2"? I wouldn't recommend 285's. 275's will save some weight and have less footprint, giving you slightly better mileage and feel. I think 275/70's(32.2x10.8) will look perfect if you stick to a small lift. The 275/75's and 285's will rub and require some cutting. They'll look great but will most likely give you some headaches.
    I had Toyo at's on my old Titan, wore great and easily could've lasted 50k. The new at3's look sweet imo. And just saw they have a 35x11.5r17, wish i knew that 6 months ago! You can get the at3's in a P265/70r17 or P285/70r17. The 275's are only LT's.
    My old boss had 2 sets of RG's while i worked for him. They get loud and shudder towards the end of their life.
    FirstGenVol and shifty`[QUOTED] like this.
  11. Apr 24, 2023 at 4:29 PM
    Jack McCarthy
    Bill
    North of Boston
    Roxbury has been primarily gentrified but Nubian square (Dudley square) is still downtrodden.
    We also have the methadone mile although I wouldn’t exactly brag about that. Build a methadone clinic and they will come, so it is said.
    The Combat Zone on the edge of Chinatown is all but gone as well, so some good news.
    Not too many people can afford to live in Boston nowadays.
  12. Apr 24, 2023 at 5:21 PM
    The coilovers supposedly support 2"-3", I don't think they'll wind down lower than 2". Guess I'll basically land somewhere in the 2"-2.5" range up front. I'm anticipating having to toss at least 1" out back to even things up and may have the truck squatting for a few days while I wait for parts if that's the case.
    Dude on my street is a T4R nut with a 1GT DC running 275/70r17 with my same 5-spoke split stockers. They stuffed fine on my truck w/o any lift. Lock to lock, forward or reverse, zero rub on stock suspension. Has me contemplating 285s.
    I've been using @FirstGenVol and @EvilMilkshake as reference material knowing they're both AC owners, and DC/AC have some geometry differences. Both guys are running 285/70r17 on SCS Ray10, either -10 or -12 offset, I forget (I think SCS is spec'd -10, so 4.35ish BS?) here's FGV's (link), and EM' (link) setup. EM has no spacers, I don't remember if FGV is running spacers up front or not.
    It looks like 275/70r17 and 275/75r17 have a max reco'd wheel width 17x8.5? No issues w/stretch to cover that 0.5"? I think 235/85r17 would look like a damn pizza cutter. It's wild how much more massive side-by-side the 285 looks than the lower width/aspect yet only 0.3"gain (edit: 0.6" total, I guess)
    Casper421[QUOTED] likes this.
  13. Apr 24, 2023 at 5:55 PM
    Casper421
    In the woods
    06 DC
    If you’ll be at 2-2.5”, I’d look into a P rated 285.
    shifty`[QUOTED] likes this.
  14. Apr 24, 2023 at 6:08 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Oil has skyrocketed in my area. I used to get 6qts of Mobil 1 advanced full from BJs for sub $30. It’s now $45+ And wal mart isn’t any cheaper
  15. Apr 24, 2023 at 6:14 PM
  16. Apr 24, 2023 at 6:25 PM
    Mr Badwrench
    Mr Badwrench New Member
    hmmmm....
  17. Apr 24, 2023 at 6:38 PM
    MEWaters
    MEWaters New Member
    Maine
    “Additive supplies are limited” not the crude itself supposedly.
    They’re working hard to force the EV transition slowly but surely
  18. Apr 24, 2023 at 6:48 PM
    But wait, when oil demand drops, price should drop with it, right? :D
    (The correct answer is NO, oil pricing is absolutely 110% artificially crafted bullshit, controlled by a few key entities who pray you'll never figure out who they are, as they get you angry at the leadership du jour, and the reality is they'll use the lack of demand to advertise higher prices due to "scarcity" or some other similar crap ... because they can, because people are ignorantly chasing after the wrong problem)
    bmf4069 and Mr Badwrench like this.
  19. Apr 24, 2023 at 8:42 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    33x10.5x17. My 255x85xr16 is 33.1x10x16
  20. Apr 24, 2023 at 8:57 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Now compare to 285/75r17 and 295/75r16 to your previous measurements for some seriously beefy 33's
  21. Apr 24, 2023 at 9:00 PM
    Casper421
    In the woods
    06 DC
    Your 295’s are 33’s, my 285/75’s are 34’s :boink:
    DJenerated[QUOTED] likes this.
  22. Apr 24, 2023 at 9:01 PM
    DJenerated
    Dija
    The Lone Star State
    Yeah. I can live with that. They're still beefy.
    Yours is . 4" longer but mines .4" wider. What ever butters yo bread better :fistbump:
    shifty` likes this.
  23. Apr 24, 2023 at 9:57 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've got an 08 ES350. It's treated me well the last 5 years. Other than the alternator smoke show a while back.
    I just can't stand the look of the ES330 so I didn't even consider it.
  24. Apr 25, 2023 at 6:36 AM
    Sunnier
    Sunny
    San Diego, CA
    I'll check these out. Thank you!
  25. Apr 25, 2023 at 8:40 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Final boat update-
    It ran great! We all had a great time.
    I was super happy with how well it ran for not running in 14 years, especially since I didn’t do anything at all to the carbs, pumps, lines, etc. Only got it up to 35mph or so, I’m still not terribly comfortable with it. Plus it was really cold. Still have some work to do, but so far it’s really good.
    I’ve attached some half decent photos I took with my phone, but I have two rolls of film that will be developed and scanned in a week or two.
    Sunnier, bmf4069, shifty` and 6 others like this.
  26. Apr 25, 2023 at 9:55 AM
    FiatRunner
    Jack
    Wait, that’s not entirely true. I’m so tired that I completely forgot about this.
    One of the seals on the gearcase is gone. Maybe multiple. When I pulled the boat out of the water, I checked the oil in the lower unit and it was super super milky. There’s definitely lots of water getting into the oil and gears down there, which is not good news.
    Re-sealing a lower unit on an outboard is not a simple or easy task, and it often requires specialized tools as well. I’m hoping that I’ll be able to replace a single seal instead of tearing the whole thing apart, but we’ll see.
    txagg and bmf4069 like this.
  27. Apr 25, 2023 at 10:30 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That sounds like something kinda big to over look! The rose colored glasses were in full effect. Hopefully that seal doesn't eat your lunch.
    FiatRunner[QUOTED] likes this.
  28. Apr 25, 2023 at 10:35 AM
    Just for shits n giggles, I was curious...
  29. Apr 25, 2023 at 3:50 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Who says you can't off-road in a Rivian.
    evanhmn, Casper421 and DJenerated like this.
  30. Apr 25, 2023 at 3:52 PM
    DJenerated
    Dija
    The Lone Star State
    Those aren't beefy.
    So why'd you quote me if you didn't check the sizes I said? You're slippin
