  1. Mar 5, 2023 at 10:07 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Cut some scrap flashing, throw some putty around the hole, and then rivet the flashing over the hole. Unless it’s completely toast that should hold you for a long time
    Hummer[QUOTED] likes this.
  2. Mar 5, 2023 at 10:40 PM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    Asparagus and bacon, yeah! I'm sure Shifty knows, the female shoots are tender but should be trimmed to the ground so the plant can continue producing the hearty stalks. When temps get warmer, let the plant produce seeds which can be spread to make more asparagus.
    Our orchard produced an abundance of volunteer asparagus which spread from cultivation and mowing. We would collect 1-2 bushels in spring and fall. Then blanch, vacuum package and freeze for later use.
    We love asparagus. Had some this evening along with venison loin.
  3. Mar 6, 2023 at 6:32 AM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    Not true. We bought root bunches from the big blue hardware store, planted as advised, and had our first harvest the following year (~14 months).
    It can be weedy, but it doesn't like competition, so it's a bit weird. It spreads via underground roots, and gets really tall. Most people, when they see it totally unfurled, would have no clue it's asparagus. Each little nodule you see in my up-close pic will unfurl into a huge, airy frond which looks like fennel but green. It gets ~5ft tall.
    If you've never had fresh asparagus, it's pretty incredible. You can literally snap the end off and eat it as-is, it's not fibrous at all. If you put them in the microwave for 2-3 seconds, it's equivalent to blanching, they go limp and are very sweet. It's pretty wild.
    Yup! We have very limited space to grow. I basically have (3) 3'x3' stackstone beds and (1) 3'x5' bed on the side yard to grow everything. Asparagus and strawberries are co-mingling in one of the 3x3. I need to clean up the strawberries, they tend to migrate.
    Here in NW GA, you only get one harvest window, over about 2-4 weeks, starting right about now. After that, we let it unfurl into some 2x3 galvanized fence for vertical support to support growth, seeding. You can clearly tell males and females apart, the females create berries. :D
    I've got some MP3s (mostly albums) I can kick your way if it's interesting. Mostly Magic Mike/Royal Posse, but I'm pretty sure I've got a few others. Believe it or not, a lot of the old bass stuff is on Spotify too. I know Magic Mike, PEB, Bass 305, and Quad Force was on there as recently as the pandemic.
    A lot of the better Miami sound stuff was published on Pandisc, but less bass CDs and more freestyle. I think Bass 305 had their own label, and Magic Mike was publishing out of Orlando w/Cheetah. Area Code Records had a ton of good stuff too. Including one of my favorites, one of a few I have on vinyl, from Miami Bass Labs, off the Deerfields EP:
  4. Mar 6, 2023 at 7:37 AM
    Pulling pics off the phone, I remembered I failed to share this from the recent trip to Costa Rica. In Cohuitta, near the preserve. I've never seen a double cab Taco before, at least not that I can recall. Saw this and thought it was pretty rad, despite looking goofy af.
    Mr.bee, bmf4069, Hummer and 1 other person like this.
  5. Mar 6, 2023 at 7:38 AM
    Pre-taco Toyota P’up in double cab. 89-94 variant or so. Dope. Probably a Hilux derivative?
  6. Mar 6, 2023 at 8:03 AM
    I was curious about the front, because it looked like what I picture in the early 1st gen Tacos. But the bed looked like the old Toyota pickups.
    Plenty of Hilux all over down there. Actually some really cool vehicles in general. Lots of 2nd gen Excel (Hyundai) Galloper IIs which have a Land-Cruiser-shagged-a-Land-Rover vibe.
  7. Mar 6, 2023 at 10:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Y'all I might not come back from London. Daughter wanted to see a concert at The O2 so I'm hanging out with the wife at the Amex lounge.
    NUDRAT[OP], alb1k, txagg and 9 others like this.
  8. Mar 6, 2023 at 3:05 PM
    daveeasa
    David
    Friend just called me for emergency help. On fumes with sprinter van, pulled into gas station and put 0.3 gallons of unleaded in b/c 3 kids and chaos. She is not sure what to do now, fill with diesel and say f it and hope or call in favors to get kids off to other places and tow the van somewhere to a place to drain it or attempt DIY siphon to some tank but you'd want someone qualified to do that. Her husband is home with the 4th kid (yeah, too many kids).
    Anyone want to opine on risk level here? I will google what the tank capacity is.
    Looks like 24.5 gallon diesel tank. Say 2 gallons in the tank plus the 0.3 of gasoline so 20-22 added. Let's do the math on % of gasoline vs diesel.
    Oh, I guess it's just 0.3 / 24.5 or let's call it 24 to shutoff, since we know only 0.3 of gasoline. That's a bit over 1%.
  9. Mar 6, 2023 at 3:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I would think you SHOULD be ok to fill with diesel but I could be wrong here. Very small percentage if it’s only .3 a gal of gasoline.
    i feel like it’s not much different that crappy gas you can sometimes get at a gas station
    NUDRAT[OP] likes this.
  10. Mar 6, 2023 at 3:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Fill with Diesel. In the NE people add a little gas to diesel when it’s really cold to prevent gelling. No harm
  11. Mar 6, 2023 at 3:44 PM
    Casper421
    In the woods
    06 DC
    No harm at all. Fill with Diesel and forget it.
  12. Mar 6, 2023 at 4:22 PM
    daveeasa
    David
    Thanks guys. I relayed your comments to my friend who is all stressed out. Hah. It was his wife who goofed.
    NUDRAT[OP], CodyP and FrenchToasty like this.
  13. Mar 6, 2023 at 7:34 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    May have to devote some space for that in one of our raised beds for next year then.
  14. Mar 6, 2023 at 8:21 PM
    Now is actually the time to plant if you're gonna do it, per KY's extension service. They've got a nice PDF covering all the shit you need to know. (link) I'm sure there's probably YouTube videos on it too, I just tend to favor our ag folks.
    You'd be surprised, check for asparagus crowns (root bundles) the garden center at big orange or big blue if they've got hardware stores near you. You may also find at Tractor Supply, or your local Ace Hardware, or other ag store.
  15. Mar 6, 2023 at 8:46 PM
    NickB_01TRD
    Nick
    KY
    She's the plant lady. I just help. I'll pass some info along though.
  16. Mar 7, 2023 at 10:29 AM
    daveeasa
    David
    I can’t understand why the HOA doesn’t like this. 24ECF4D6-94A1-4947-AE79-92FBD0FF8536.jpg
    NUDRAT[OP] and bmf4069 like this.
  17. Mar 7, 2023 at 10:35 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    The Host of Assholes.
    bmf4069 likes this.
  18. Mar 7, 2023 at 11:00 AM
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    Is that your wife painting the house? They ought to appreciate that.
    bmf4069 likes this.
  19. Mar 7, 2023 at 11:08 AM
    daveeasa
    David
    GC's helper (happens to be female). She did the new insulation this morning which was so nice b/c I'm sick of being itchy from that s (took all the old stuff out / in / out / in a bunch over the past few weeks and finally to the dump).
    I have a puffy that is an itchy puffy now, washed it twice, still all fiberglassed.
    She's doing some moisture barrier before they install the window since they needed the plywood to frame the other window as today is drywall install day.
  20. Mar 7, 2023 at 11:28 AM
    Are they pissed about the tire tracks in your yard? I'm confused and feeling like you're playing a hunt-for-hidden-shit game with your picture.
    Sunnier likes this.
  21. Mar 7, 2023 at 11:28 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    A cup or two of Vinegar in your bath water gets rid of the itch. Somehow it draws out the bits of insulation that are irritating you. One of my first jobs was making AC ductwork and dealing with insulation. Bathe well, drain the tub, and shower off the vinegar smell.
    txagg, NUDRAT[OP], Sunnier and 2 others like this.
  22. Mar 7, 2023 at 11:32 AM
    daveeasa
    David
    Thanks! I'll wear my puffy in the bath too :)
    "used car lot" was the quote. The tire tracks don't help. I want wood chips but wife doesn't. Ideally a slab but kitchen takes priority.
  23. Mar 7, 2023 at 11:41 AM
    Is there a limit to the number of vehicles you can have per the HOA terms? Is there any definition saying all vehicles must be regularly driven and/or operational, or is current registration ample?
    HOA can pretty much come up with whatever petty bullshit rules they want to spite you, so I wouldn't push your luck. At the same time, as a contributor to the HOA and a community member under the HOA, you have a right to request the terms and conditions at any point to ensure you're in compliance.
  24. Mar 7, 2023 at 11:50 AM
    daveeasa
    David
    Limit -- to my knowledge no, just can't park on the street overnight. I could see someone considering adding a clause about not parking on your lawn. This specific community, that specific rule, it would likely make sense. We have the top 3 worst driveways, ours is short and steep, others are steeper but longer, some are insanely awesome and I'm way jealous.
    Regular driving -- I drive each as frequently as I can. Because I want to keep them operational, etc. I let my youngest pick the rig for driving to school while his cousin is gone. The sister in law is particular about car seats for her kid, so I honor that and take the DC when I'm going to her place but they are out of town right now. All reg is new/clean/current and plates are brand new of course. I think maybe the bumpers on the Tundra are seen as a little WT? They are "aggressive" looking. I have a winch fairlead (still need to install the winch) and front plate sticks out in front with a flip up. So I try to park it nose in.
    I think the city has limits on driveway width?
    "Driveway Widths. Driveways shall conform to the minimum width requirements of LOC 15.06.610 (Oregon Fire Code Adopted) and LOC Article 50.55, Parking Standards."
    Right now our driveway is 3 bays wide and perpendicular to street, feeding straight to the garage. So adding on the side might hit some code / enforcement.
  25. Mar 7, 2023 at 11:54 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    DJenerated and alb1k like this.
  26. Mar 7, 2023 at 12:13 PM
    alb1k
    Left Coast
    It's good
    I think wrapping one of the tundras in metallic hot pink is in order.
  27. Mar 7, 2023 at 12:18 PM
    daveeasa
    David
    I definitely need another Tundra. No question.
  28. Mar 7, 2023 at 12:30 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Working on some cool shit today. Airport conveyor controls.
    Where's that friendly neighborhood electrical engineer at? No, really, it's not letting me tag Jack. Wtf? Anyways, WTF are these and WTF purpose do they serve?
    And why are these needed if the motors are ran off VFDs?
    txagg, CodyP and Jack McCarthy like this.
  29. Mar 7, 2023 at 12:36 PM
    https://www.galco.com/rl-00402-mte.html for the 1st thingy
    And @Jack McCarthy I'm tagging you since @bmf4069 couldn't
    bmf4069[QUOTED] likes this.
  30. Mar 7, 2023 at 12:46 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @Shifty Damned if I know, I’m not a electrical “power” engineer but I can ask one.
    Can’t be an expert at everything electrical; way too much to cover. I’m a ones and zeros guy. haha
    Guy who sits across from me is an electromagnetics expert and does radar cross section signatures. Basically what we call a “blob-ologist”.
    Google will tell you everything you need. Even the experts refer to it. Now isn’t that comforting?
