  1. Feb 19, 2023 at 6:13 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I was just thinkin, hmmmm, never seen welder connectors soldered, maybe I should do that to mine.... you almost had me ya lil whippershnapper
  2. Feb 19, 2023 at 7:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mended. No solder. Bigger Magnet. Red heat shrink so as not to reverse them again....
    On the far left, 220V @80 amps. Middle, 220 @100 amps. Far right. 120 @160 amps.
    Could just be me, but I was struggling to achieve, and maintain ARC on 120. No matter the amp setting..once I finally struck an ARC and kept it, I just walked the dude up the plate. I think this is all 1/8" steel? Maybe 3/16" max.
    All done with a Non-dried 1/8" 7018 rod. We don't have a dryer for our rods because we weld so infrequently with stick here.
    txagg, Jack McCarthy and Sunnier like this.
  3. Feb 19, 2023 at 7:45 PM
    The 220v 100a bead is butter. That 120 is uh, a good candidate for a grinder. Not sure how well it’s penetrating. May be limited use if only 120 is available.
    FrenchToasty and Tundra2[QUOTED] like this.
  4. Feb 19, 2023 at 7:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The 120 "bead" is absolute trash. I'm not sure what it's called, but when your weld erupts in a sparkler effect, it's not good penetration. Anytime I got the ARC to strike for just a second, and I would try to walk it out it would die out, and then erupt in the sparkler. Definitely no penetration.
    FrenchToasty likes this.
  5. Feb 19, 2023 at 7:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh, regarding the limited use... I believe out generator has a 220 plug. Kinda defeats the purpose for me, but it does work, and I may sell this welder here for someone's home use.
    Edit: I'll definitely play around with this on some scrap steel or whatever in my off time. Probably not in the tent though. That'd kill me. Anyways, I'll give it more than a rushed shot at work after watching a few YT videos.
  6. Feb 19, 2023 at 9:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Feb 19, 2023 at 9:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    shifty` and bmf4069 like this.
  8. Feb 19, 2023 at 10:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sucked it up and bought oem rear drums for the tundra. Had my local shop use ‘premium’ raybestos drums and they are so outta spec. Applying the brakes makes the truck gallop to a stop. Such shit.
    Should be simple enough to swap drums without any issues or adjustments I’d think since I’ve only put less than 2,000 miles on it
    txagg and bmf4069 like this.
  9. Feb 20, 2023 at 3:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Found a scangauge 2 locally for sale for $50. Trynna scoop it up if ole boy'll ever message me back. How are yall mounting them things again?
    I forgot how peaceful parking lots are with a cup of coffee..
    Sunnier and bmf4069 like this.
  10. Feb 20, 2023 at 7:33 AM
    daveeasa
    David
    I think with my double airbag issue I may never reinstall my scangauge but $50 is a good price. The spiker mount is great. Pretty easy install. Hardest part is the torx to remove the OEM grab handle fastener.
  11. Feb 20, 2023 at 2:53 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I went into Harbor Freight today to see if they could get their hands on the winch that is marked down. No luck. I was willing to buy a bigger more expensive one but the dimensions listed online are taller than the space allowed in my Brute Force bumper. Curious how people are getting around that issue. The 20% off deal ends today.
    daveeasa likes this.
  12. Feb 20, 2023 at 2:54 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Can you order online, or ask for a rain check?
  13. Feb 20, 2023 at 3:03 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Negative. It won't even let me add it to my cart. I know people are running bigger winches with my bumper. They must be relocating the control box?
  14. Feb 20, 2023 at 3:19 PM
    Sunnier
    Sunny
    San Diego, CA
    I understand you can order using the coupon.
  15. Feb 20, 2023 at 3:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The winch I was trying to buy is on closeout and only for purchase in person. It's not available within 100 miles. I can't order it online sadly.
    Sunnier[QUOTED] and FrenchToasty like this.
  16. Feb 20, 2023 at 3:54 PM
    Sunnier
    Sunny
    San Diego, CA
  17. Feb 20, 2023 at 4:13 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Which winch?
  18. Feb 20, 2023 at 4:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  19. Feb 20, 2023 at 4:39 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Well that sucks. Every store in my area is reporting them in stock. That’s like 10 stores within 50 miles. Probably one of the few benefits to living in New England.
  20. Feb 20, 2023 at 5:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Feb 20, 2023 at 7:33 PM
    empty_lord
    05 rollover special
    [​IMG] $668 in tires for the mr2 today… 215/40r17 and 255/40r17
    shifty`, robabeatle, bmf4069 and 3 others like this.
  22. Feb 20, 2023 at 7:38 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    My Saab hotrod had bigger tires in back. Was funny 'cause front wheel drive & all.
    Those a summer compound, get rock hard in the cold?
  23. Feb 20, 2023 at 7:43 PM
    empty_lord
    05 rollover special
    200TW. This is not a car i will be willing to drive under 40 degrees or in the rain
  24. Feb 20, 2023 at 10:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My 1/2" impact went from being evaluated to being shipped back to me with no word per the milwaukee service tab tracker thing on their website. No confirmation email saying it was fixed, or not. Just an email saying it was shipped back?
    I sent them a reply in hopes of an answer and an explanation of what was wrong if they fixed it
  25. Feb 20, 2023 at 10:36 PM
    daveeasa
    David
    So, given this is the second time I’ve had airbag problems, what should I do?
    f it, install new wheel w audio controls and new airbag and new clockspring and see what happens?
    attempt to replace all the airbag parts with 05-06 dual stage? Probably a massive effort?
    Or unplug the SRS module and ignore the light, maybe pull the bulb?
    suck it up and troubleshoot like a normal person
    Seems hard to image a situation where 20 year old airbags would be a difference maker. Hmmm.
  26. Feb 20, 2023 at 11:19 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Pull the airbag light and get a respectable quick release steering wheel.
    shifty`, txagg, CodyP and 2 others like this.
  27. Feb 21, 2023 at 5:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Murphys law Monday misery.
    Cracked my new phones screen when I got hit in the head with a bundle of 10' long 3/4" all thread. Smooshered a finger in the same accident.
    Burnt the clutch/gearbox out of a buddy's drill... fubar'd
    Hit my fucking head again in a scissor lift. Seeing stars mate.
    The show must go on though
    shifty`, bmf4069, Mr.bee and 2 others like this.
  28. Feb 21, 2023 at 5:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  29. Feb 21, 2023 at 5:34 AM
    My mom used to live in northern Tennessee around the Richmond area. Pretty hills, bourbon and horse racing.
  30. Feb 21, 2023 at 5:45 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    From Twitter:
    NUDRAT[OP], bmf4069 and txagg like this.
