  1. Dec 15, 2022 at 1:56 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    yea, filling the gap if i need to ride a rail. I've used traction tape for dirtbike ramps, but everything is dry when i use my ramps.
  2. Dec 15, 2022 at 2:19 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Are those d-hole wheels 16's? And tight on the hubs?
  3. Dec 15, 2022 at 2:27 PM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    yeah d windows from jeggs ( 4inch BS), they scraped the front caliper, 275/70/16's so i had to put spidertrax 1.25, it was hitting on turns on front bumper, not on frame ( trimmed about 1/2 inch off) and rear seam weld, hammered pinch flat and I was good to go.
    RUSTYNUTS and Mr.bee like this.
  4. Dec 15, 2022 at 2:40 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What tires are you running?
  5. Dec 15, 2022 at 3:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, the plan to fix/flip vehicles was put on hold for the time being. Found a 2000 subaru outback for cheap with both blown head gaskets. Nissan plan is out the windurrr too I spose... for now. Don't own it yet, but I will. Planning on it being my first victim for TOP2.Ohhhhh...
    Anyways, I called around to some automotive machine shops. Looking like $45 a head for resurfacing only. They don't have the equipment to hot tank heads.
    Would yall keep searching till you find one that can resurface, hot tank, crack test, and check all the valve guides at the same time?
    That's what my gut says, but you guys know your way around engines/shops better than me.
    Oh, and price of the Subaru? $700
    805Tundra and Mr.bee like this.
  6. Dec 15, 2022 at 3:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Dec 15, 2022 at 3:52 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I could use a use smart car to keep in the bed in case my truck breaks down again. Those are under the payload limit, right?
  8. Dec 15, 2022 at 4:01 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I've owned two outbacks...awesome cars! Great in collisions too (don't ask how I know).
    Subarus are very finicky about head gaskets (My daughter's Legacy had them replaced twice, and then a friend took it on a trip, ignored the overheating, and fried the engine for good!) You're on the right track with the head resurfacing, but I think there's a lot more to it. I think they want OEM parts, just like our Toyotas
    shifty`, RUSTYNUTS, 805Tundra and 3 others like this.
  9. Dec 15, 2022 at 4:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've done my homework as best I can. Looks like the original head gasket used on the H4 engines was graphite coated, single layer steel. The turbo models or whatever used a multi-layer steel gasket which is what I plan on putting on. I'd just rather pay a shop to do all the head work at once, and then be done with it. With routine maintenance these cars are just like our Toyotas from what I've been able to read. OEM all the way as far as the head gasket goes.
    There was a recall for the head gasket issue on the 2.5 H4 engines, but Subaru's fix at the time was to buff the block, and cylinder head with a 3M wheel, slap a new OEM graphite coated gasket on, and send-em out the door. Quick as possible. NFG. That ain't how Tundra2's Garage rolls.
  10. Dec 15, 2022 at 5:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Well I had a wild day. While walking my dog, I got charged by a dog. It backed me across the street and into another home's driveway. It kept advancing and closing the distance no matter what I did. The whole time it was snarling and barking at me. First time I've drawn down on someone (thing) in 13 years of having a carry permit. It finally left when a passing car honked at it.
    This dog is always an asshole when we walk by but their invisible fence normally keeps him contained. I wasn't sure what to do so I called animal control.
    bmf4069, Jack McCarthy and Tundra2 like this.
  11. Dec 15, 2022 at 5:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    https://www.youtube.com/watch?v=-aq0hDvKJ5Q
    Here's the "Too Long; Didn't watch" cliff notes:
    The original gasket was single layer steel, coated in graphite. The graphite coating will eventually chip, and then start peeling/flaking away. The MLS gasket is the permanent* fix for the H4 boxer engine head gasket issues. As important as using the correct MLS gasket, is the prep work before installation of the head being correct. Subaru's OEM method for installing/torqueing is a little complex when you first look at it, but makes complete sense when you watch somebody do it in person/video. I've got the below video set to start at the "factory torque" process. After he explains, he shows you how its done.
    https://youtu.be/gOwu5nEet4c?t=320
    * as long as the prep work leading up to reinstallation of the head gaskets is correct, the torque patter above followed, and proper maintenance is performed on the engine... you should never have another head gasket issue with this vehicle.
    Something else to note about this particular model of "early" H4 engines is that the thermostat is mounted vertically, rather than horizontally like our engines. This can allow air to become trapped around the spring of the thermostat, and because of the airlock, never reach temperatures high enough to open the thermostat. I plan on researching to see if the later version of this same engines water pump will fit an earlier one as they are mounted horizontally, and properly bleed air. Do it right, do it once.
    shifty`, w666, txagg and 2 others like this.
  12. Dec 15, 2022 at 5:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Shit man. Glad you got out.
  13. Dec 15, 2022 at 5:23 PM
    Jack McCarthy
    Bill
    North of Boston
    Why didn’t your dog try to defend you? Pets are usually protective.
  14. Dec 15, 2022 at 5:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Be the guy that walks with a golf club, that never actually golfs
    805Tundra, NWPirate, txagg and 3 others like this.
  15. Dec 15, 2022 at 5:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Dog knew dad was strapped. Like all good parents, he’s prepared his kids.
    RUSTYNUTS, bmf4069 and FrenchToasty like this.
  16. Dec 15, 2022 at 5:36 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    She's 13 years old and getting pretty chill in her old age. She was watching him but that's it. If my other dog Gunner had not passed away in March he would have tried to eat this dog. I'm honestly glad my dog didn't escalate the situation. I had run out of room to retreat and was unsure how I was going to get away without turning to violence.
  17. Dec 15, 2022 at 5:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Next time walk with a bat….
    RUSTYNUTS and txagg like this.
  18. Dec 15, 2022 at 5:38 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Honestly a bat or golf club would be preferable to a gun in this scenario. Trying to shoot a moving dog, one handed, without shooting my own dog is not ideal.
    Ironically, it's not legal here to carry an ASP baton unless you take a special class.
    CodyP likes this.
  19. Dec 15, 2022 at 7:43 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you almost become an ATF agent? Damn dude.
    FirstGenVol[QUOTED] likes this.
  20. Dec 15, 2022 at 7:45 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That all sounds good. Can you do the HGs with the engine in? What do those even look like from the bottom? Also, have you bought the car yet?
    Tundra2[QUOTED] and FrenchToasty like this.
  21. Dec 15, 2022 at 7:51 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Reviews are starting to come out on the Harbor Freight off road jack. It performed very well. Both it and Pro Eagle are made in China.
    If I was going to pick one, I'd go with Harbor Freight for $299.
    https://youtu.be/Vv_8ooIbaVU
  22. Dec 15, 2022 at 8:10 PM
    FrenchToasty
    Mo
    Bone stock
    Probably come from the same factory, just different cousins putting them together
    shifty` likes this.
  23. Dec 15, 2022 at 8:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't own the car yet legally, but it's all done by word of mouth. Going to pick it up saturday. Uhual tow dolly for the win. You can* do them in car, but every thing I've ever read on it leads me to believe that a true repair will be pulling the engine, doing the timing belt, water pump, idler, etc all at the same time.
    RUSTYNUTS likes this.
  24. Dec 15, 2022 at 8:43 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Is there a special procedure for using a tow dolly on those since they are AWD? Or just hook it up and go?
  25. Dec 15, 2022 at 9:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Unbolt the drive shaft from the rear differential. Same as a rwd vehicle.
  26. Dec 15, 2022 at 10:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    front shocks assembled and rack on.. waiting on jamb nuts to put the outer tie rods on.. then this thing can roll for the first time. (yes the spindles are crusty. they're temp prerunner spindles to make it roll)
    [​IMG][​IMG]
    NickB_01TRD, shifty`, AleHole and 8 others like this.
  27. Dec 15, 2022 at 11:44 PM
    18" TRD Off Road Wheels
    NUDRAT[OP] and FrenchToasty like this.
  28. Dec 15, 2022 at 11:54 PM
    Never know. Somebody might not be an audiophile and just wants a stock unit. :p
    Sunnier likes this.
  29. Dec 16, 2022 at 6:48 AM
    daveeasa
    David
    Got that fancy aux battery tray inbound and thinking about what I’ll do with the stock location. It’s got a 31 right now and that sucker is too big and heavy in my opinion. If I do an OGE RedArc tray it’ll be even taller and probably hit the hood. So I gotta shrink height and weight.
    so I think either 24F or 35. Gotta decide.
    The aux will be a 27 I think, though maybe 24 as it’s the same width and height, just shorter length and lower weight IIRC.
    I also have a 27F in the ‘05 which is overkill there, may well swap back to a 24 to shave a little bit of weight.
    Can’t think of any good way to make use of the 31, it was a poor decision.
  30. Dec 16, 2022 at 7:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Niko passed away Wednesday night by himself in the woods. He was interned today. Rip feline fuckhead
