  1. Nov 28, 2022 at 6:35 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    This has turned into some expensive ass firewood man. Sorry it's giving you hell bud
    RUSTYNUTS and Sunnier like this.
  2. Nov 28, 2022 at 6:37 PM
    daveeasa
    David
    Mostly there.
  3. Nov 28, 2022 at 6:55 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I bought the truck like this, but it works. Far from a pro install, but I plan on addressing it at some point. Was feeling good after we BTHO LSU the other night and cranked up some L Wayne on the way home. Honestly a pretty good sounding setup with alpine unit and mid grade door speakers. Real problem is the sub can't travel when the back seats down. Need to get a cage for it.
    5N0W808 likes this.
  4. Nov 28, 2022 at 6:58 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Nice. Downfire>Upfire. Course its kinds of hard to make an enclosure that down fires there and still be able to use the same size sub. Could be done but would require cutting some metal perhaps. Throw a low profile sub grill on there so it has some room to pound and breathe.
    Is the underside seat material soft or is it hard rigid plastic like on the DCs? I have a tiny box for under the rear seat of my DC but the sub space it tiny, the subs it'll fit are also tiny, and the sub roll surround would smack against the hard plastic of the underside of the seat on my DC. I gave up and eventually just have a truck wedge box wedged between the rear seat and the back of the center console.
    txagg likes this.
  5. Nov 28, 2022 at 7:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thinking about getting one of these for Crackie. I also thought about pulling the one from the V6, and swapping it over, but damn pulling the headliner again. Was it @FrenchToasty that had one of these?
    5N0W808, txagg and FrenchToasty like this.
  6. Nov 28, 2022 at 7:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah I have one, it’s a cheaper option if your going to run more than 3 or 4 accessories
    des2mtn and Tundra2[QUOTED] like this.
  7. Nov 28, 2022 at 7:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, do you like it? Any issues with it? Was it troublesome running the controller wires into the cab? Got pics of where you mounted it?
  8. Nov 28, 2022 at 7:24 PM
    FrenchToasty
    Mo
    Bone stock
    B6F5795F-E72D-4CE5-A494-ECF1CE119CB1.jpg I have it in the sunglass holder area.
    it was all pretty easy to install, it does have 3/8 inch or so connector that will need to be snaked into wherever you mount it.
    So far it’s worked great, I’ve only got one slot left available; they do have other models with bluetoof action if your into that
    Tundra2[QUOTED] and des2mtn like this.
  9. Nov 28, 2022 at 7:27 PM
  10. Nov 28, 2022 at 7:29 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I've got one too. One thing I do not like about the version I have is you cannot turn off the backlight. I had to run an additional switch just to the Auxbeam just so I could turn the backlight off when the truck is parked at night. I didn't connect my Auxbeam to my ignition because I want certain things to have power without ignition.
    Controller wires are easy to run through the cab, the typical firewall grommet on the drivers' side.
    Not a good solution for a lot of people, but I drilled into the lower part of the dash and added a Ram ball on the dash and another ram ball to the back of the panel. I like this spot and doesn't really obstruct anything.
    Brains under the hood.
    bmf4069, RUSTYNUTS, txagg and 3 others like this.
  11. Nov 28, 2022 at 7:30 PM
    artsr2002
    'Yonder
    What's a sunglass holder? Do you mean the taco holder?
  12. Nov 28, 2022 at 7:32 PM
    FrenchToasty
    Mo
    Bone stock
    It’s always sunny here, so nothing but my face needs to be holding my shades.
    RUSTYNUTS likes this.
  13. Nov 28, 2022 at 7:33 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    5100 rears are on sale for $180 a set at suspensionlifts.com right now (Usually $200). Whole lift kit sets might be as well. Finally pulled the trigger on the rears. Should have done it a while ago.
    Link to rears
    bmf4069, shifty` and artsr2002 like this.
  14. Nov 28, 2022 at 7:33 PM
    des2mtn
    Shady Grove
    Tonto cover
    I mean you wear those huge ass pit vipers that won't fit in there anyway
    CodyP, bmf4069, RUSTYNUTS and 4 others like this.
  15. Nov 28, 2022 at 7:36 PM
    Now this is a mod I can get behind. About 12 times in one sitting. :rofl:
    Yup, just paid ~$200 for mine. Hope they ship yours in better shape than ones they shipped to me a few months ago. Whoever does their warehouse fulfillment blows.
  16. Nov 28, 2022 at 7:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell yeah! This is the kinda feedback I was after! Good spots for both of those switch panel locations IMO.
  17. Nov 28, 2022 at 7:37 PM
    artsr2002
    'Yonder
    Uh, I believe we've established that the tacos go there. Goh. Get with the program dude. LOL
  18. Nov 28, 2022 at 7:53 PM
    NickB_01TRD
    Nick
    KY
    My fronts came from them as well and they were perfect so I guess we'll see.
  19. Nov 28, 2022 at 8:42 PM
    Sunnier
    Sunny
    San Diego, CA
    I put my controller in the lower dash area, left of the steering wheel. Fab’d a backplate from some plastic type stuff that I was able to heat and bend into shape. Drilled through that, attached through the dash panel, then put a narrow metal plate behind the dash, to spread the stress so it doesn’t rip the dash material when I jump the truck. If you decide you’re interested in see this option, lmk and I’ll snap pics in the day time.
    RUSTYNUTS and Tundra2[QUOTED] like this.
  20. Nov 28, 2022 at 8:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'd love to see it. Sounds cool!
    Sunnier[QUOTED] likes this.
  21. Nov 28, 2022 at 9:03 PM
    artsr2002
    'Yonder
    I keep wanting to replace my Kenwood stereo with a capacitive screen Kenwood unit with the HD screen knowing damn well that there is nothing wrong with my current unit in the DC which I hardly ever drive anyway. Stupid Black Friday, Cyber Monday, Tech Tuesday whatever Wednesday sales emails. :D
    shifty` likes this.
  22. Nov 28, 2022 at 9:10 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    bmf4069 and RUSTYNUTS like this.
  23. Nov 28, 2022 at 9:13 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Do they make a model with 2 separate power inputs for ignition and 12v constant? That would solve problems
  24. Nov 28, 2022 at 9:16 PM
    artsr2002
    'Yonder
    Can you tie the lighting into your dash illumination circuit to dim when your lights are on?
  25. Nov 29, 2022 at 4:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That amp is gonna die if you run it too much with the seat down.
    It's soft on the under side. Not much give, but enough to be squishy.
    txagg[QUOTED] likes this.
  26. Nov 29, 2022 at 5:45 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I used a random 2 x2 across the top of my subs so that someone can sit in the rear passenger seat and not cause the seat bottom to flex into the subs. Simple, cheap, and and works.
  27. Nov 29, 2022 at 6:28 AM
    des2mtn
    Shady Grove
    Tonto cover
    Nope, there's no wires that come out of the switch to control the dimness. There is a sensor built into the switch panel that adjusts the brightness.
    Yeah, I agree. I believe they used to have a model where the brightness could be manually adjusted.
    I'm content with the power cutoff switch I added and will leave it be though. I pretty much only cut power to it if I park in public at night so the cab isn't lit up.
    FrenchToasty likes this.
  28. Nov 29, 2022 at 12:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Planning on getting a new tent of pain tomorrow. Saw that harbor freight has a slightly bigger one now. 12×20 instead of the 10×17 that I had.
    10×17 is $250.
    12×20 is $399.
    Decisions...
    RUSTYNUTS, bmf4069, txagg and 2 others like this.
  29. Nov 29, 2022 at 12:59 PM
    FrenchToasty
    Mo
    Bone stock
    More pain=more pleasure
    CodyP, RUSTYNUTS, bmf4069 and 4 others like this.
  30. Nov 29, 2022 at 2:07 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    At least from drinking cold cheap beer if nothing else.
