  1. Nov 25, 2022 at 8:16 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Got an email from Skid Row. Looks like they are running a sale on Cyber Monday for our trucks. Sale doesn't appear active yet. Not sure if the 1stgen10 code will work with it too
    5N0W808, Filthyphil and FirstGenVol like this.
  2. Nov 25, 2022 at 8:25 AM
    daveeasa
    David
    Slightly tempted to order new door latches with the discounts. Not sure. But tempted.
  3. Nov 25, 2022 at 8:27 AM
    daveeasa
    David
    Actually, while I ponder, someone else already replaced seatbelt latches, yes? Or is it maybe only the driver seat which has a latch bolted down and the bench is integrated?
    Looks like I found stuff in Oak but not moon mist. 732300C030E1
  4. Nov 25, 2022 at 8:28 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think you can replace just the seat belt latch on the driver's side. Passengers that's a little harder to do....
  5. Nov 25, 2022 at 9:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I need to replace the female part of the buckle. And something is up with the seat sensors because my selt belt light will flash randomly. I don't think it's a safety concern so I've put it way down the priority list.
    I did find this just now. Not sure why I would need a cock plug though.:monocle:
    bmf4069 likes this.
  6. Nov 25, 2022 at 9:51 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It's for when your rooster won't shut the fuck up.
    NUDRAT[OP] likes this.
  7. Nov 25, 2022 at 11:17 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hey, follow up if you figure out what’s making your seatbelt light flash, mine’s been doing it a lot recently too, if I wiggle it it’ll go off. I have also given it low priority, but it’s kind of annoying.
  8. Nov 25, 2022 at 11:36 AM
    Usually it's faulty ground (or faulty absence of ground), i.e. wiring corrosion or similar. I've rarely found the in the actual receptacle, but sometimes blowing air into the receptacle will break something free. Sometimes squirting a load of contact cleaner into the receptacle and plunging the metal belt in a couple dozen times will solve it. But it's almost always the connection near the base of the belt strap thing, near where it mounts to the floor. There's almost always a connection to the body harness within a few inches after that bolt on the floor. Sometimes just cleaning that out with contact cleaner will solve the issue.
  9. Nov 25, 2022 at 11:39 AM
  10. Nov 25, 2022 at 11:42 AM
    PenderBen
    2003 Tundra AC 4x4
    Cool, thanks for the advice, I’ll look at that first, sounds easiest. I did have an issue a while back where the latch wouldn’t spring back unless I jiggled it, but that went away, something may have fallen in at some point.
  11. Nov 25, 2022 at 11:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In my case, the seatbelt light likes to flash if I put something in the passenger seat, even if it doesn't weigh much. I should probably try the contact cleaner on my buckle because it likes to stick.
    Yep. I ended up ordering from Serra because they were the exact same price as McGeorge and I already had everything in my cart. Got new LCA's for $212 each.
    Casper421 and shifty`[QUOTED] like this.
  12. Nov 25, 2022 at 11:47 AM
    Oh, if not obvious from my other post, my goods arrived today, everything but extended links I guess, which I still need to order. Skipping Duros for now. Now I get to stare at it and get depressed for a couple of weeks until I can get off my ass and finally install it. Sucks.
    Meanwhile, in case anyone was wondering, the $600 Eibach UCA are 100% SPC: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1500#post-2992772
    bmf4069, Mr.bee and AleHole like this.
  13. Nov 25, 2022 at 11:51 AM
    Ah - Maybe an issue with the SRS seat occupancy sensor in the passenger seat, then? I don't remember how that works, though. There was one guy on here from Florida or something who pops in randomly who was trying to figure out how to bypass it, his was totally broken.
    Your truck has the keyhole in the dash to turn pass seatbelt on/off, right? Does the position of that impact whether or not the belt flashes? My center dash light comes on if I put anything more than 15-20lb in the passenger seat.
  14. Nov 25, 2022 at 12:00 PM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, my passenger side seems to operate normally (does flash with a bit of weight on the seat), it’s my drivers side that flashes randomly while driving with my belt buckled.
  15. Nov 25, 2022 at 12:06 PM
    Try blowing out the driver receptacle, then flood it with CRC contact cleaner, then latch/release the buckle a few times.
    If that doesn't fix it, work backwards from there, first checking the wire connection near the floor mount.
    PenderBen likes this.
  16. Nov 25, 2022 at 12:07 PM
    PenderBen
    2003 Tundra AC 4x4
    Thanks, will try that- not at home with truck for a few days, but will be next week.
    shifty`[QUOTED] likes this.
  17. Nov 25, 2022 at 4:18 PM
    I cringe every time I see that picture, I remember you posting it on other threads, but I don't want to hijack up that guy's build thread to say this:
    I remember that fight. I get that same nauseating feeling in my stomach just seeing the picture, I don't even need to watch the video again.
    Mind you - I'm the type of guy who eats a nice bloody stake while watching bodies get cut open on TV, or kin skin a buck, doesn't bother me. Something about the thought of snapping your tibia & fibula, and putting your full body weight down onto the broken bone stump like a foot is, like ... it's fingernails on a chalkboard to me.
    I've broken bones. None were compound fractures like that. All were below the ankle or above the hip, so far (knock on wood). That's just ... ugh.
    RUSTYNUTS and FrenchToasty like this.
  18. Nov 25, 2022 at 5:05 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    If the seatbelt light is on & you get in an accident, my understanding is the airbags won't deploy. That could matter, maybe push it higher on the to-do list.
    RUSTYNUTS likes this.
  19. Nov 25, 2022 at 6:03 PM
    Casper421
    In the woods
    06 DC
    @FirstGenVol Are you a college basketball fan? The Vols are playin well against #3 KS!
    FirstGenVol likes this.
  20. Nov 25, 2022 at 6:09 PM
    daveeasa
    David
    So all you guys w flashy seatbelt don’t have airbag trouble? Just me having both?
  21. Nov 25, 2022 at 6:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes! I'm taking my dad to a game in a few weeks for his birthday.
    Casper421[QUOTED] likes this.
  22. Nov 25, 2022 at 7:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  23. Nov 25, 2022 at 7:24 PM
    Casper421
    In the woods
    06 DC
  24. Nov 25, 2022 at 9:07 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Plenty
  25. Nov 25, 2022 at 9:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine always stays pushed down unless I really mess with it. Seatbelt light doesn't flash and it doesn't ding when I start it. It latches just fine but I always wear my seatbelt so I just leave it be.
  26. Nov 26, 2022 at 4:21 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    First day of rifle here in PA.
    What it sounds like at my house.
  27. Nov 26, 2022 at 7:23 AM
    daveeasa
    David
    F yeah, truck stuff!
  28. Nov 26, 2022 at 7:56 AM
    Going with the under-deck storage solution, I reckon?
    FrenchToasty likes this.
  29. Nov 26, 2022 at 8:30 AM
    daveeasa
    David
    from last night. Got a few hours in. Gonna run an unplanned $1k. And interrupted every few minutes. Got my 2nd HD run in before they woke up.
    Shot from this morning
    8’ wide by 6’ deep by 5-7 feet high.
  30. Nov 26, 2022 at 10:47 AM
    PenderBen
    2003 Tundra AC 4x4
    I was under the impression airbag function should be fine with seatbelt light on, but would not function if the airbag light is on.
    random screenshot:
