  1. Nov 13, 2022 at 2:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If I had a do over on the silver truck, I'd have went with solo over the napa arms I put on. Solo has poly, yes? Plus improved caster?
  2. Nov 13, 2022 at 2:52 PM
    Obviously, discretion is advised. It won't apply to a simple tool like a maul. YMMV (your mileage/morals may vary). Not saying I would do it, just ... saying.
    1. You have a DC but I'll be verbose in case others find this later. If you've got an Access Cab or Regular Cab truck, your truck will likely squat an inch or so to the rear running 2885, or worse if you're also 2WD, worse still if 2WD and V6 - if you're reading this and it applies to you, you'll need to make a choice, either go with 2884 instead or you'll need to lift the rear, so consider buying Icon or Toytech or whatever brand you prefer AAL, since lifting or dropping vehicles with blocks is not ideal. If your Double Cab, but you're 2WD, you'll probably have a little squat also, but DC/4WD with that setup should settle to just about level. Obviously, this entire chunk of text will vary if you have (or intend) to add a camper, armor, or other added weight. You didn't list your drivetrain, or whether you have and/or will add extra weight front and back, so ... take it or leave it.
    2. Save your hard earned dollars. This Eibach Pro 5.25485K kit is just SPC UCAs resold by Eibach, but 30% cheaper. Mevotech also resells, but I'm not sure if bushings are same. Save yourself $300 buying Eibach's. Or save yourself $500 buying Mevotech and hope the bushings are the same. 1stGenOffroad may be able to get them for you. I'm not sure if Josh knows this info already or not.
    3. Go with OEM LCA so you're only doing this once, hopefully the last point will save enough to offset some of the cost. The OEM already lasted you this long. Don't you want to pay a little more to get there? It's extra insurance and should be added longevity. You get what you pay for.
  3. Nov 13, 2022 at 2:53 PM
    *SQUEAK* *SQUEAK* *SQUEAK* *SQUEAK* *SQUEAK*
    bmf4069, Sunnier, FirstGenVol and 2 others like this.
  4. Nov 13, 2022 at 3:30 PM
    AleHole
    AleHole PNW
    Seattle
    '06 DC SR5 4WD Tow Package w/LSD
    Thanks for all the replies everyone. I should of mentioned parts are already bought and sitting in my garage and yup V8 4x4. Undercover tonneau most the time with a few sandbags in the winter is my payload. An occasional trip for mulch or what ever.
    Shifty you make a good point about the OEM lower arms. Im gonna return the Moog. Pony up for OEM.
    Tundra2 and shifty` like this.
  5. Nov 13, 2022 at 3:54 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Supposedly if you use the right lubricant, they should stay quiet
    :boink:
    Tundra2 likes this.
  6. Nov 13, 2022 at 4:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Not mine, zerk tapped and greased with Energy Suspension #5 super tacky grease. I now have zerks everywhere there is poly. I'll sneak up on you.
  7. Nov 13, 2022 at 4:19 PM
    alb1k
    Left Coast
    It's good
    I will say Solo is full of shit with the "use copper anti-seize and we don't have zerks installed because it's so good". Everywhere I used to have copper anti-sieze that met real dust turned to abrasive mud. Scored the inner bolt (steel) sleeves on my bushings and nothing should be getting in there...
    shifty`, Tundra2 and FrenchToasty like this.
  8. Nov 13, 2022 at 6:06 PM
    daveeasa
    David
    Bolt worked well on the maul once I found a good size. It was actually stainless. Hah. Maul mods.
    down to a half dozen pieces. All pretty even Y shapes. Bought a wedge too but can’t seem to get it planted. Maybe my 10 lb sledge needs an 8 as backup.
    might just slice them all with the chainsaw one more time.
    Gotta figure out a plan for seasoning. It’s a big pile.
    alb1k likes this.
  9. Nov 13, 2022 at 8:44 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I’ve always found that loose piling is best for seasoning, not a nice tight stack, you want some airflow. I usually leave it in a big messy unstacked heap, but you could loosely stack it too, just not too tight.
    It’s some hardwood right? Might be ready next year, hardwood takes a while.
    daveeasa[QUOTED] likes this.
  10. Nov 13, 2022 at 10:52 PM
    daveeasa
    David
    So you’re encouraging me to be lazy? :)
    My OCD and the amount of rain we get here are pushing towards some sort of organized stacking.
    The tree was a honey locust. Sounds like it should be seasoned 1-2 years. We are burning a sister tree which apparently fell 2 years ago in an ice storm based on what the neighbors tell us. The top layer is good but the stuff at the bottom does not want to burn. Definitely needs something better than a stack under the deck.
  11. Nov 13, 2022 at 11:05 PM
    daveeasa
    David
    Oh and I see I’m posting bs in the “work on the truck” thread so oops and sorry.
    however, worth mentioning that if everything goes according to plan, I’ll be driving my Tundra home to Oregon in 7.5 days. I’m pretty excited to have her back home for good.
  12. Nov 14, 2022 at 8:13 AM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, couple years is probably better if you can, been a while since I’ve had anything other than soft wood to deal with. If there’s space and airflow it can dry in a stack and look more organized :)
  13. Nov 14, 2022 at 8:22 AM
    daveeasa
    David
    I’m debating between custom woodshed vs metal racks which would be more exposed but might fit under the deck. Plan to demo said deck at some point. Hmmm
  14. Nov 14, 2022 at 9:01 AM
    There's your answer, I think. If you plan to demo the deck, and you can afford to build a shed today, go with the shed.
    If not, I see plenty of Chinese companies on scAmazon selling 3'x5' sheds in the low $100s range. One unit is under $100 from "Cover-it". I found them hunting for "metal shed" on there. Could be a good interim solution.
  15. Nov 14, 2022 at 9:48 AM
    daveeasa
    David
    Yeah, I was thinking one of one or more woodhaven racks:
    https://firewoodracks.com/?gclid=Cj...wxPmEVRGLvl7UMDsnjrfQROIrfs6K0PRoCTB4QAvD_BwE
    if going metal for under deck. We would for sure rebuild a deck post demo so they wouldn't be wasted, but getting the ground level under a low overhang will be a PIA and storing wood close to the house is also not ideal. But it's the most protected spot without significant effort.
    I want a storage shed (for my excessive wheels/tires as well as garden tools and rarely used stuff) which could potentially be a combo storage/firewood shed but I'm bracing for impact on a guy bidding the work, I suspect it'll be a painful price tag I won't want to pay.
  16. Nov 14, 2022 at 9:59 AM
    My parents ended up grabbing me a rack off scAmazon for some annual-event gift (birthday?), it's basically the far left one in the 2nd pic below. Then I bought this cover for it. They sell both in 8ft versions if more space is required. I don't normally like buying shitware like this, but lumber was 3x as much, no racks made domestically, everyone selling in the US was sourcing from China... the rack has held up for 3 years now, and the cover for 2.5, which is more than I expected. Dad's got two of their 8 footers and one 4 footer.
  17. Nov 14, 2022 at 10:38 AM
    Had to dump some of my truck slush into SS and our remodel this week, so it's probably the worst time to be checking out Black Friday deals.
    I poked around anyway and I'm pushing this out there in case anyone else is interested...
    • Dirty Deeds: Exhaust system for $1,275 with code BlackFriday and veterans get an extra $50 off. Maybe the code works for other stuff? (link)
    • Toytec: 10-15% off select suspension items, Method wheels 15% off, Aluma series lift kits supposedly 15% off w/coupon BFTOY15 (code didn't work for me!) ( )
    • Dobinsons: 15% off select suspension items (email Sales@dobinsonusa.com and mention )
    • ESP Truck: Free shipping and 15% off ESP branded items using code BLACKFRIDAY22 (link)
    • Desert Does It: 15% off with code DDIVIP, could be a good time to get those SeatJackers (link)
    • RCI Offroad: 20% off all RCI branded product with code NOV22 (link)
    • CBI: 20% off Black Friday, in case AC owners are looking for the Prinsu rack, basically $100 off (link)
    • Fifteen52: 35% off wheels while supplies last, Turbomac HD looks pretty cool (link)
  18. Nov 14, 2022 at 10:47 AM
    Casper421
    In the woods
    06 DC
    Anyone looking for a slightly used rear ARB locker?
    bmf4069, 5N0W808 and FrenchToasty like this.
  19. Nov 14, 2022 at 2:58 PM
    Sunnier
    Sunny
    San Diego, CA
    Maybe. What’s the backstory? What’s the cost?
    FrenchToasty likes this.
  20. Nov 14, 2022 at 3:09 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  21. Nov 14, 2022 at 5:28 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    :annoyed:Looks like the sequoia is suffering from the wiper cowl leak. Figure it would show itself sooner or later. Had it on the to do list at some point after having to do my tundra. Just havent got around to it. Just took priority now :bananadead:
    shifty` and NUDRAT[OP] like this.
  22. Nov 14, 2022 at 5:41 PM
    Casper421
    In the woods
    06 DC
    I bought it used from AL_TUNDY last November for $700. Been sitting in my garage and needs a new owner.
    RUSTYNUTS and 5N0W808 like this.
  23. Nov 14, 2022 at 8:22 PM
    If you need any info, gimme a shout. Been there. Done that. You'll want to have a couple of extra fasteners on hand for the cowl (and not the ones you need to reseal/replace). Can point you to part #s if you need it.
  24. Nov 14, 2022 at 8:24 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  25. Nov 14, 2022 at 9:27 PM
    Sunnier
    Sunny
    San Diego, CA
    Can we maybe, as a team, decide this one time, that we could do a dedicated side thread for the cowl problem and solution? It’s a thing. 1, A dedicated thread is nice to find in a search. 2, it can keep the riffraff outta here. 3, I’ll probably need to know this some day.
  26. Nov 14, 2022 at 9:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Tundras done for a bit. New frame for the 1998 will be here this week (last one Toyota had in stock) just waiting on the shocks to show up before that frame swap
  27. Nov 14, 2022 at 9:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Man. I’ve got several big truck projects that need doing, but that ‘year and a half we spent in Tahiti’ when we all got Covid this year, requires I abstain from most of my vices for the remainder of the year. I plan to live vicariously through you guys (and save up to splurge next summer when it’s too hot to wheel: all the stuff I have to pay others to do).
    5N0W808[QUOTED] likes this.
  28. Nov 14, 2022 at 9:36 PM
    alb1k
    Left Coast
    It's good
    bmf4069 and Sunnier[QUOTED] like this.
  29. Nov 14, 2022 at 9:38 PM
    Sunnier
    Sunny
    San Diego, CA
    NUDRAT[OP], bmf4069 and alb1k[QUOTED] like this.
  30. Nov 14, 2022 at 9:39 PM
    Casper421
    In the woods
    06 DC
    Hoping SOS has a discount for their rdc kit and find a deal on oem 14w calipers/rotors for the front.
    txagg and 5N0W808[QUOTED] like this.
