  1. Nov 12, 2022 at 6:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    With the 2 ton, weren't you exceeding that amount? It didn't have any issues? Do you just strap it down in the bed for now?
  2. Nov 12, 2022 at 6:28 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Nov 12, 2022 at 6:29 AM
    FrenchToasty
    Mo
    Bone stock
    Exceeding the lift ammount? Maybe? But it didn’t have any issues.
    Hahah as of now I run jackless and rely on other people around me. A symbiotic relationship
    NUDRAT[OP] likes this.
  4. Nov 12, 2022 at 6:37 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Gotcha. I thought you were saying you had a Pro Eagle.
  5. Nov 12, 2022 at 6:39 AM
    FrenchToasty
    Mo
    Bone stock
    Sorry, I think both jacks we used were the HF aluminum, 2 maybe 2.5tonnes
  6. Nov 12, 2022 at 6:46 AM
    2 tons is 4,000 pounds. You would have to be lifting the entire truck to exceed that. Any corner of the truck should weigh no more than 1500-2000#
  7. Nov 12, 2022 at 6:47 AM
    FrenchToasty
    Mo
    Bone stock
    That would be quite the balancing act
  8. Nov 12, 2022 at 6:50 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Don’t you want the HD Daytona Snap-On copycat with the 3 year warranty? I think that one is $200+
  9. Nov 12, 2022 at 6:52 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Another win for solid axle trucks. Jacking moms qx80 irks me unless i use 2 jacks. (Cant lift from the diff.)
    FrenchToasty likes this.
  10. Nov 12, 2022 at 7:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I didn't realize there was a difference. Both are 3 ton. I'm happy with my Husky but the Daytona units sure do look purdy.
  11. Nov 12, 2022 at 7:12 AM
    Sunnier
    Sunny
    San Diego, CA
    Thank you, Buddy. You can pass this along on the Free thread. Thanks for hiring pause for me. :)
  12. Nov 12, 2022 at 7:12 AM
    Jack McCarthy
    Bill
    North of Boston
    Well for a 3 yr warranty you know they’re using much better quality parts. The 90 day HF warranty is too short IMO. I’d rather have a 1 yr minimum although I suppose you can buy their extended warranty.
    Personally when I finally get a home with a proper garage, I’ll splurge for the $500 Hein Warner model that I know can always be rebuilt.
  13. Nov 12, 2022 at 7:45 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Probably just lighting, but it looks like the passenger door is a different color. Is the handle black or missing? It's easy to be brutal with a car you're disinterested in, but that helps keep the purchase price right. I seem to have an eye for shading variances in car paint.
    bmf4069[QUOTED] and FrenchToasty like this.
  14. Nov 12, 2022 at 7:49 AM
    NUDRAT
    SW CT
    isn't your truck too tall for a bottle jack? How would you use it to lift a tall truck with suspension tire-off?
  15. Nov 12, 2022 at 7:55 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Good question. I'm pretty sure I tested the height in the garage one day but I should verify. I also bought some accessories for it from Safe Jack which makes it safer and taller. I keep a piece of 2x6 in the truck to use a base for uneven ground.
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-328#post-1994190
  16. Nov 12, 2022 at 7:59 AM
    NUDRAT
    SW CT
    Ah, cheater accessories. That should work. As is, I SOL if I blow a tire with the Taco, it outgrew it's jack. Need to deal with that.
  17. Nov 12, 2022 at 8:35 AM
    Sunnier
    Sunny
    San Diego, CA
    I carry a 3-ton bottle jack from Tractor Supply that will lift mine (33” tires), but gotta plan for the impressive suspension droop. So I carry it to be self-contained but, the only time I needed an on-trail tire change, my “pit crew” used a Pro Eagle. Relying on trail buddies to share equipment works well, as long as there’s at least one of everything.
  18. Nov 12, 2022 at 8:40 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    FirstGenVol, Sunnier and FrenchToasty like this.
  19. Nov 12, 2022 at 8:44 AM
    FrenchToasty
    Mo
    Bone stock
    I like the ones I linked in the 6t because they have feet tabs which helps if your working in dirt so they don’t sink so much
    NUDRAT[OP] and Tundra2[QUOTED] like this.
  20. Nov 12, 2022 at 8:54 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I seent them. I just throw a piece of plywood under em for cost savings. If I had just a concrete pad....
    When I did the front end on the silver truck, I apparently just used pavers. Either way...
  21. Nov 12, 2022 at 9:20 AM
    daveeasa
    David
    Nobody makes a Jack which works with a compressor, huh? That would be ideal.
  22. Nov 12, 2022 at 9:23 AM
    FrenchToasty
    Mo
    Bone stock
    For big rigs they do, probably nothing tactical for trail use.
    daveeasa[QUOTED] likes this.
  23. Nov 12, 2022 at 10:16 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    The HF Pro Eagle knock off is the one to get for off road IMO. Coming in December, I think they are taking pre-orders, $300 / 3T. Will work for shop great.
  24. Nov 12, 2022 at 10:17 AM
    alb1k
    Left Coast
    It's good
    @daveeasa - -thanks for the awesome write up in the wiring post!
    daveeasa likes this.
  25. Nov 12, 2022 at 10:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  26. Nov 12, 2022 at 10:24 AM
    alb1k
    Left Coast
    It's good
    I finally wrapped my head around how to grease leaf bushings with poly bushings and greasable bolts. You loosen the bolts so the grease can leave the inner sleeve and go between the frame mount and the poly bushing flange. Duh.
    NUDRAT[OP] and FrenchToasty like this.
  27. Nov 12, 2022 at 10:25 AM
    FrenchToasty
    Mo
    Bone stock
    That’s how they recommend to grease the bush on total chaos uppers. I think it also relieves some tension/pressure so you don’t pooch out the bushing
  28. Nov 12, 2022 at 10:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Handles are black and yeah, I think it's just a lighting glitch on the panels.
    NUDRAT[QUOTED][OP] likes this.
  29. Nov 12, 2022 at 10:28 AM
    alb1k
    Left Coast
    It's good
    Yup, I don't know why that didn't click earlier. Probably a good idea for the Archive shackles as well, I think I'll just do that everywhere except cam bolts to be safe. And, I'm pushing much higher PSI with the thick ass grease I'm using now.
  30. Nov 12, 2022 at 10:33 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Like this? I’ve been toying with the idea of one of these because my old floor Jack broke and I need to buy a new one anyways.
