  1. Oct 28, 2022 at 4:02 PM
    Sunnier
    Sunny
    San Diego, CA
    Both.
  2. Oct 28, 2022 at 4:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Probably is standard movement. My problem (I think) is the slide hammer effect. Want...to...stop..that, lol.
  3. Oct 28, 2022 at 5:30 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    If its a glass pack style resonator its probably just toning down the loudest pops.
    is the trd muffler glasspack or chambered?
    its a v8. Louder is better.
    bmf4069 and 5N0W808 like this.
  4. Oct 28, 2022 at 5:57 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    https://youtu.be/1RbRLouNpX0
    Is yours that deep? Resonators might be cleaning up the higher frequency's. Mine has resonator tips, but i wouldnt say its as deep a tone as that.
    5N0W808 likes this.
  5. Oct 28, 2022 at 6:02 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Our stock resonators work to get rid of the drone from a lot of member’s experience over the years both here and on other tundra sites.
    Sunnier likes this.
  6. Oct 28, 2022 at 6:04 PM
    Sunnier
    Sunny
    San Diego, CA
    Mine is cut with a short downturn welded on, maybe 7 inches. Sounds very good, in my opinion.
    Mr.bee and Jack McCarthy[QUOTED] like this.
  7. Oct 28, 2022 at 6:08 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @alb1k hi. Fellow 2WD guy here. I think you’ve got it figured, but to comfirm, the 2WD driveshaft is bolted to the flange at the rear, the carrier bearing in the center, and no bolts at the front, so with any front to rear movement of the driveshaft, the front end of it (slip yoke) slides within the transmission tail. Right? Right. So let me throw out a possibility that I haven’t seen mentioned yet; since you’ve changed all that is your rear suspension, could it be that the slip yoke is bottoming out in the transmission, and causing the bump that you’re experiencing? Like , if somehow the rear axle is sitting even 1/2” forward from where it was with everything stock, and it runs out of travel room thru articulation. That would also explain the motor being bumped forward if I’m understanding correctly. Si o no?
    NUDRAT[OP], FrenchToasty and Sunnier like this.
  8. Oct 28, 2022 at 6:10 PM
    Sunnier
    Sunny
    San Diego, CA
    Hmmn. A guy who probably knows the answer to this, from experience and observation of numerous other vehicles, would be Keith at Dirty Deeds. He runs long travel on a 2WD and definitely gets enough articulation to have encountered this, if it is a thing.
    Edit: I’m not implying that you boys can’t figure this out for your own selves, only suggesting that Keith is a guy with relevant experience, it might save a bit of time figuring it out.
    RUSTYNUTS[QUOTED] likes this.
  9. Oct 28, 2022 at 6:12 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Seems possible. There’s nothing holding the shaft into the transmission at the correct depth, other than where it’s bolted to the rear diff
  10. Oct 28, 2022 at 6:13 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    My bad, i was thinking the 2wds were a 1 piece DS. W/o carrier bearing.
    Sequoia had 1 piece.
  11. Oct 28, 2022 at 6:24 PM
    alb1k
    Left Coast
    It's good
    I like it but my motor is slipping to the back. At rest and stop it sits forward (or the lower part of the engine sits forward, then shifts back as the trans mount moves up). The trans mount is moving up maybe 1/2" or so, I don't think that could be enough to bottom it out - but, I need to learn more about it. There may be more I'm not thinking about. Also, my picture was bad, I should have turned the shaft 90 degrees.
  12. Oct 28, 2022 at 6:53 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah, it sits forward at rest and stop. What I’m saying is its possible that when the motor (and tranny) shift back toward the rear, if the shaft is too far forward, it would bottom out in the tranny and ultimately be what limited the engine shifting back, before the mounts actually stopped it. I’m probably not explaining it well but I may be wrong anyways
    Sunnier likes this.
  13. Oct 28, 2022 at 7:18 PM
    alb1k
    Left Coast
    It's good
    oh, you explained it well, I read poorly. Sounds like you may be under your truck tonight? bummer, good luck.
  14. Oct 29, 2022 at 9:07 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Everyone gonna check your kids candy this year?
    Make em donate what they get, and buy em some good candy.
    txagg, 5N0W808, bmf4069 and 1 other person like this.
  15. Oct 29, 2022 at 10:32 AM
    Jack McCarthy
    Bill
    North of Boston
    Should I be giving out reheated chicken nuggets instead for Halloween?
    If I buy them in bulk, it’s cheaper than candy unless they’re candy corns; nobody wants those.
    bmf4069, 5N0W808, Mr.bee and 4 others like this.
  16. Oct 29, 2022 at 12:33 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Ooh - I'll take everyones candy corn. ...and black licorice too!
  17. Oct 29, 2022 at 12:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Gross
  18. Oct 29, 2022 at 12:37 PM
    NUDRAT
    SW CT
    LOL - no this is what gross looks like
    bmf4069, CodyP, RUSTYNUTS and 3 others like this.
  19. Oct 29, 2022 at 12:39 PM
    FrenchToasty
    Mo
    Bone stock
    NUDRAT[QUOTED][OP] likes this.
  20. Oct 29, 2022 at 12:43 PM
    NUDRAT
    SW CT
  21. Oct 29, 2022 at 3:17 PM
    daveeasa
    David
    Looking over u bolts in more detail, I can see how the stock setup with nuts low is easier to tighten up with wheels on.
  22. Oct 29, 2022 at 3:19 PM
    FrenchToasty
    Mo
    Bone stock
    Either isn’t bad, you gotta get on your back regardless
    RUSTYNUTS likes this.
  23. Oct 29, 2022 at 3:34 PM
    Sunnier
    Sunny
    San Diego, CA
    I like both. Especially the licorice.
    RUSTYNUTS and NUDRAT[QUOTED][OP] like this.
  24. Oct 29, 2022 at 3:34 PM
    Sunnier
    Sunny
    San Diego, CA
    We are on the same page x all three pictured ingredients.
  25. Oct 29, 2022 at 3:36 PM
    Jack McCarthy
    Bill
    North of Boston
    How can ANYONE get used to the taste of candy corn?? I don’t get it.
    GODZILLA, NUDRAT[OP] and FrenchToasty like this.
  26. Oct 29, 2022 at 3:37 PM
    FrenchToasty
    Mo
    Bone stock
    Eww!!!
    Jack McCarthy likes this.
  27. Oct 29, 2022 at 3:42 PM
    NUDRAT
    SW CT
    i was the youngest by several years - probably the only candy I could get hold of as a kid - LOL
  28. Oct 29, 2022 at 3:43 PM
    FrenchToasty
    Mo
    Bone stock
    Please sir!
    Sunnier and NUDRAT[QUOTED][OP] like this.
  29. Oct 29, 2022 at 3:46 PM
    Jack McCarthy
    Bill
    North of Boston
    Then you had horrible, cheap neighbors on Halloween. I made the effort to avoid those homes as a kid trick or treating. :rofl:
    FrenchToasty and 5N0W808 like this.
  30. Oct 29, 2022 at 3:48 PM
    Jack McCarthy
    Bill
    North of Boston
    I seem to be the only cool guy giving out Hersey kisses and mini chocolate bars. :cool:
    At least that’s what the kids visiting say. lol
    bmf4069, GODZILLA, 5N0W808 and 2 others like this.
