  1. Oct 23, 2022 at 11:15 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, for day to day. But for trail runs, I pack an impact. That vibe of 10 trucks waiting, feels less stressful I can show I was “prepared”. Plus, it just goes a lot quicker.
    RUSTYNUTS, txagg and shifty`[QUOTED] like this.
  2. Oct 23, 2022 at 11:16 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    pit stop vid?
  3. Oct 23, 2022 at 11:32 AM
    Sunnier
    Sunny
    San Diego, CA
    It was dark, everyone pitched in so it didn’t occur to anyone to grab vid. Changed one of Hulk’s tires on Greasy Spoon near Sedona in just over 2 minutes from when I put it in park ‘til when I got back in and put it in drive. By the time I’d climbed into the bed, and pulled off the top spare, my trail mates had already positioned a Pro Eagle and loosened the lugs using an impact (maybe 2, simultaneously). I bounced the tire down, someone rolled it over as the truck was getting jacked up, and they had the replacement on, destroyed tire handed up to me, and the Jack down, out from under, and stowed by the time I finished securing the departed tire where the spare had been. I’m not saying this is normal, but it was very cool.
    No pics though, so yeah, I know…
    this never happened.
    RUSTYNUTS, txagg, bmf4069 and 3 others like this.
  4. Oct 23, 2022 at 2:08 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Today I learned that partially filling a broiling tray with water helps to prevent grease splatter when broiling.
    Sometimes I feel like such a noob when it comes to cooking especially when I think of all the grease fires I’ve dealt with in the past.
    Sunnier and shifty` like this.
  5. Oct 23, 2022 at 2:18 PM
    It also helps keep humidity around the meat, which prevents moisture from needing/wanting to leave the meat. As long as humidity outside the meat is higher than humidity inside the meat, less moisture will evaporate out. I didn't know this until I started smoking with a propane smoker.
  6. Oct 23, 2022 at 2:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Water baths are crucial, and it helps with natural convection
    shifty`[QUOTED] likes this.
  7. Oct 23, 2022 at 2:21 PM
    Jack McCarthy
    Bill
    North of Boston
    Yep, I noticed my sirloin strip steak was juicier as a result.
    shifty`[QUOTED] and FrenchToasty like this.
  8. Oct 23, 2022 at 2:45 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My buddy came over to ride my bike today. He's hooked. Awesome fall day here.
  9. Oct 23, 2022 at 3:40 PM
    Man that thing looks tiny. How big is your friend?
    RUSTYNUTS likes this.
  10. Oct 23, 2022 at 4:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's not a big bike. Sort of the beauty of it I guess. It's surprisingly fast though. He's 6'0 185-200lbs.
  11. Oct 23, 2022 at 7:23 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I see they've "encapsulated" the asbestos with duct tape where it's starting to fail on the pipes. :rofl:
  12. Oct 23, 2022 at 7:32 PM
    Sunnier
    Sunny
    San Diego, CA
    The best achievement I scored today was not buying this:67A42EDA-2D79-4383-BA3F-B5EC17A6F4A6.jpgDon’t get me wrong: I looked it up, checked out the 3/8” version that would make sense for me, but managed to take mental inventory of everything I already have, and recognize, I don’t need it. #adulting gets easier with practice.
    RUSTYNUTS, FirstGenVol, txagg and 3 others like this.
  13. Oct 23, 2022 at 7:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    @french
    adulting sucks
  14. Oct 23, 2022 at 7:42 PM
    NUDRAT
    SW CT
    Well there are a couple parts of it that don't ;-)
    Although the good parts usually involve acting like a kid. But generally - yeah.
    Sunnier likes this.
  15. Oct 23, 2022 at 7:44 PM
  16. Oct 24, 2022 at 3:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  17. Oct 24, 2022 at 5:39 AM
    Yeah, along with a lot of people flaming the OP about how they're full of shit.
    Reddit never ceases to amaze me...
  18. Oct 24, 2022 at 6:44 AM
  19. Oct 24, 2022 at 11:06 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hey, before reapplying wool wax is there a preferred method of pre-cleaning? Should I just wash off everything as well as I can with the hose, or should I use a pressure washer? Any risk of getting water in the wrong places with the pressure washer if I go that route?
    NUDRAT[OP] likes this.
  20. Oct 24, 2022 at 11:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  21. Oct 24, 2022 at 3:15 PM
    NUDRAT
    SW CT
    generally people will tell you to pressure wash.
    Use prudence. you're looking to get the road schmutz that kicked up off, so you don't need to try to 'scrub' the vehicle clean - just knock off the surface grit.
    I will say give the area at the bottom of the radiator & any direct line of sight under the front bumper a focused wash. That area (behind/below the front bumper) gets a lot of salt water spray & road debris.
    The back lower corners of the bed hold a lot of cr*p, but you're better using your fingers & a running hose to clean that out. Don't forget inside the trailer hitch if you have one.
    Thanks @Jack McCarthy for the image :)
    Look where the bed is rusting - be sure to get all those areas sprayed from below. they are the common rust spots on the bed.
    When spraying don't forget to get inside the front edge of the hood & it's rear end by the hinge mounts. inside the cross beams for the bed (3?). The bed - wheel arches/bed sidewall, above the wheel well liner but from under the truck. below the radiator. inside the tailgate. Let me try to find a picture of a Boston Bed to highlight where they rust so you know where to shoot from below. Oh- remove the spare, leave the cable dangling to spray. Not a terrible idea to spray the spare tire rim, they rot too.
  22. Oct 24, 2022 at 3:20 PM
    PenderBen
    2003 Tundra AC 4x4
    Awesome, sounds like good advice and direction to follow, thanks.
    NUDRAT[QUOTED][OP] likes this.
  23. Oct 24, 2022 at 3:33 PM
    Jack McCarthy
    Bill
    North of Boston
    A skid plate is worth having if you don’t have one. It helps keep salt out of the underside of the engine bay area.
  24. Oct 24, 2022 at 3:41 PM
    Should be able to find one at a JY, but I also know someone with a spare if your truck is 4WD. I swore someone on here couldn't fit a 4WD skid onto their 2WD, bolt hole differences or something.
    Tundra2 likes this.
  25. Oct 24, 2022 at 3:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was @jpink because his trucks frame was tweaked I believe. I offered to buy his aftermarket skid plate, but no go...
    jpink and shifty`[QUOTED] like this.
  26. Oct 24, 2022 at 4:08 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Didja wdh your trailer yet. Wanna roadtrip with the dog up the prarie, maybe all the way to the devils tower. If it was summer or fall, coulda done it on the bike, more comfortably. Need to order some dot rated aftermarket lights. Motorcycle stuff for extra bright and blinkers, and jeep jk stuff for lo/hi. Ive got a set of chains, but if i get caught in it, i could carry a bag of studs for the front. Running a decorated beta sign to keep heat in the radiator if i run to alaska.
    RUSTYNUTS and Tundra2 like this.
  27. Oct 24, 2022 at 4:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Nah, I haven't done anything to the trailer in a hot minute except flood all the water lines with RV anti-freeze..
    Mr.bee[QUOTED] likes this.
  28. Oct 24, 2022 at 4:58 PM
    NUDRAT
    SW CT
    @Tundra2 Didja get it up into the hot water heater, or at least drain the water out of it? That gets people.
    Tundra2[QUOTED] likes this.
  29. Oct 24, 2022 at 5:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeah its in the hot water heater. Looked like to me that the anode rod was original. As there was no anode left... Inside of the hot water heater looks rusty as hell. I might put it on the docket for replacement eventually...
  30. Oct 24, 2022 at 5:34 PM
    NUDRAT
    SW CT
    I've been wondering if there'd be any value in wrapping barbed wire around the trucks Cat's? You'd have to make it thicker than the length of the blade to be of any value I suppose?
    https://youtu.be/g7f6HiQ2LuU?t=45
    always wanted one of those cadillacs in dark green.
