  1. Oct 12, 2022 at 6:23 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Time to buy a 5G phone.
  2. Oct 12, 2022 at 6:27 PM
    shifty` Goons of Hazzard
    #BalljointFail
    Are these people using a specific brand that's failing?
    Could just be the shit design a lot of aftermarkets are using isn't engineered for the LCA angles Toyota uses on these trucks. It could also be the ones that are failing are all coming from warehouses in China using pot metal (or other inferior steel) to cast their parts. Or a combination of both.
  3. Oct 12, 2022 at 6:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea the ones will last 200k miles unless lifted. Aftermarket’s your lucky to get 50k stock height, less lifted
    NUDRAT[OP] and shifty`[QUOTED] like this.
  4. Oct 12, 2022 at 6:41 PM
    My factory ones were replaced at 212k miles for aftermarket ones. Have about 50k on those now. Ticking time bomb. Fine!! I’ll replace them with the front bearing change.
    bmf4069 and empty_lord[QUOTED] like this.
  5. Oct 12, 2022 at 6:47 PM
    Jack McCarthy
    Bill
    North of Boston
    Factory at 212k? Damn, my OEMs only last 80-90k on average. I’m on my third set and my truck is bone stock.
    I’ve yet to replace my original UBJs at 240k.
  6. Oct 12, 2022 at 6:49 PM
    Rust belt vs. non-rust belt?
    KNABORES and Tundra2 like this.
  7. Oct 12, 2022 at 6:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The V6s lasted like 270K or something like that. Crackies had been changed to some bastard brand that had a nylock nut on the ball joint stud instead of a castle with a cotterpin.
  8. Oct 12, 2022 at 6:50 PM
    Jack McCarthy
    Bill
    North of Boston
    Rust belt of course. Not sure how that would be an issue though.
  9. Oct 12, 2022 at 6:51 PM
    empty_lord
    05 rollover special
    My tundras originals were 200k.. after a rollover my first taco went 280k on the originals. Same setup
    Sunnier likes this.
  10. Oct 12, 2022 at 6:54 PM
    Jack McCarthy
    Bill
    North of Boston
    I must be the unlucky one here although my first set was replaced under the recall around 90k, the next set at 175k because one was leaking grease. Third set seems to be okay so far.
  11. Oct 12, 2022 at 6:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Titan is at 290k on original bj's.
    bmf4069, txagg, Sunnier and 1 other person like this.
  12. Oct 12, 2022 at 6:59 PM
    I think we can probably just agree, at the time Toyota was making these trucks, they were over-engineering just about everything. Hence the reliability.
    There's a myriad of reasons Toyota is a household name, while most aftermarket parts manufacturers aren't. I'm sure this is just one.
  13. Oct 12, 2022 at 7:01 PM
    Sunnier
    Sunny
    San Diego, CA
    Hmmn.
    I always assume it’s the bolts, all these failures we see— because that’s what failed on mine… at about ~218k.
    So I, uh, got all new OEM hardware… and … um… put the OEM LBJ’s back on. So… yeah. :anonymous:
    bmf4069, NUDRAT[OP], des2mtn and 2 others like this.
  14. Oct 12, 2022 at 7:03 PM
    Sunnier
    Sunny
    San Diego, CA
    This reassured me. ‘Hope and prayers’, reactive.
  15. Oct 12, 2022 at 7:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Ive seen a few pics where the joint had sepperated.
    RUSTYNUTS and Tundra2 like this.
  16. Oct 12, 2022 at 7:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm not sure how well this will work as a screenshot from mobile, but his is definitely NOT a bolt failure.
    See that ball? Yeah that's the joint.
  17. Oct 12, 2022 at 7:15 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Mine were replaced under the warranty at 43k then I did them and the studs at 150k, 170k currently.
    This post does a good job of covering how the LBJs and the studs are weak point on our vehicles:
  18. Oct 12, 2022 at 7:23 PM
    empty_lord
    05 rollover special
    Bolts are an issue. I don’t reuse them 04 and older. 05-06 have beefier bolts. Way less of a risk of failure
    shifty` and Sunnier[QUOTED] like this.
  19. Oct 12, 2022 at 7:27 PM
    Sunnier
    Sunny
    San Diego, CA
    But will those fit the older LBJ’s?
    Don’t get me wrong: I won’t do another bolt swap; next time, I’ll swap out the LBJ’s. But I… and internet searchers in future… want to know.
    Tundra2 likes this.
  20. Oct 12, 2022 at 7:28 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought Toyota had a recall on the ball joints? I also thought the later first gens had an improved ball joint design.
    Tundra2 likes this.
  21. Oct 12, 2022 at 7:48 PM
    empty_lord
    05 rollover special
    You’d need to swap LBJ, control arm and spindle
    Sunnier[QUOTED] and Tundra2 like this.
  22. Oct 12, 2022 at 7:48 PM
    empty_lord
    05 rollover special
    Not all vins affected. But a lot were
  23. Oct 12, 2022 at 7:49 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    fast. Only caught a glance. Looked like an attractive small / medium truck. Properly beefy. Jacked up just right.
    Was early rush hour, so traffic was tight, by the time I saw the tailgate, check it out time was pretty much over. ;-\
    txagg[QUOTED] likes this.
  24. Oct 12, 2022 at 7:53 PM
    NUDRAT
    SW CT
    yes, IRS employees to my understanding.
  25. Oct 12, 2022 at 7:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Man, I tell yall whut... if I had an unlimited budget, and the parts avaliable, I'd swap the knuckles, lbjs, and control arms on crackie for the "improved" design.
    Sunnier[QUOTED] likes this.
  26. Oct 12, 2022 at 7:57 PM
    NUDRAT
    SW CT
    yep. Dearborn yesterday, Toledo this morning, Ann Arbor till Sunday - you going to come do the valves on my 2.7?
    It's sitting until Sunday. :)
  27. Oct 12, 2022 at 8:04 PM
    NUDRAT
    SW CT
    Potentially the 'next' Mustang. I say that based on the wind pressing the plastic to the nose. Alas no shot.
  28. Oct 12, 2022 at 8:06 PM
    Sounds like a good upgrade for older 1GT to me!
    Hell, if I had unlimited budget, I'd have everything custom fabricated. If only... buy me lottery ticket, G.
  29. Oct 12, 2022 at 8:07 PM
    empty_lord
    05 rollover special
    LOL. Ship it to indiana.
    You won’t get it back though.
    shifty` and NUDRAT[QUOTED][OP] like this.
  30. Oct 12, 2022 at 8:07 PM
    empty_lord
    05 rollover special
    You’ve got the updated parts
