  1. Oct 5, 2022 at 1:44 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You had me at lumens
    bmf4069[QUOTED] likes this.
  2. Oct 5, 2022 at 1:54 PM
    daveeasa
    David
    They are cheapo LED shop lights. Light helps a lot with the tiny plastic connectors, especially when de-pinning things. I worked for a while with a headlamp and the old garage I overspent on 9 panels to get enough light. I may redo those in a bit but they are directly over where I had my workbench and it’s helpful.
    Hopefully, even though it’ll be expensive, I can build on the east side. That’s a project for another day though.
    bmf4069 and Jack McCarthy like this.
  3. Oct 5, 2022 at 2:05 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Personally if I owned a garage and had space concerns, I’d have my bench and tools in a cage that could be put on rollers and moved around if necessary to adapt to new situations. You can lock it up from the kids too and have lights at the top of the cage with drop down moveable power cables suspended from the ceiling.
  4. Oct 5, 2022 at 2:24 PM
    daveeasa
    David
    Yeah, my biz stuff is on a workbench with wheels, as is the primary toolbox, both lockable.
    The part which won't move around is the 5 costco shelves, they are heavy AF and that's where all the bins go with all the materials (mostly connectors, plugs, seals, terminals, tubing, heat shrink....)
    Jack McCarthy likes this.
  5. Oct 5, 2022 at 2:27 PM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    no, stock RC with 6 foot bed
  6. Oct 5, 2022 at 5:12 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Any chance for storage up in these spaces?
  7. Oct 5, 2022 at 5:14 PM
    Floor coating looks good btw
    KK6PD likes this.
  8. Oct 5, 2022 at 5:21 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    What about a garage door bump out? @shifty`
    FirstGenVol likes this.
  9. Oct 5, 2022 at 5:24 PM
    daveeasa
    David
    That's the gearwall + shelves. Yes. It had shelves before, $1 metal brackets with slotted screws. Took me a while to get that crap down and out. I prefer 100 lb shelves:
    https://www.gladiatorgarageworks.com/products/45-gearloft™-shelf#:~:text=Holds up to 100 lbs.
    I should have / wanted to do that first but the wife offered to help move shelves in. After her reaming me for "not making a decision" we went with 3 shelves on the right wall (East) and the option to park a truck on the left side (single bay). Right now that's where we stash her bike. Dunno about the tandem quite yet I would like to hang it from the ceiling somehow.
    I can get some photos of this midway state. Need to get the fridge in and it'll be an extension cord situation for it for now. Then moving all the crap back into the shelves...
    shifty`[QUOTED] likes this.
  10. Oct 5, 2022 at 5:29 PM
    I have a 2nd story deck above the garage. Complicates things.
    NUDRAT[QUOTED][OP] likes this.
  11. Oct 5, 2022 at 5:38 PM
    NUDRAT
    SW CT
    So you've got 3/4 of the bump out roof already built! :)
  12. Oct 5, 2022 at 5:42 PM
    Yeah, I wish it was honestly that simple.
  13. Oct 5, 2022 at 6:49 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Installed the first TRD lift on a turd gen at work. $4000 kit. Oof. New axles, lower knuckle ball joint things, tie rods, shocks, front springs, rear spring spacer seat, brake lines, upper control arms..
    Honestly kinda impressive until you see the price
    [​IMG] [​IMG]
    tokolosh, bmf4069, txagg and 2 others like this.
  14. Oct 5, 2022 at 7:30 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Honestly I'm surprised it's not more. That sounds like a lot of labor, and parts. Probably quality parts too I would imagine. Many guys here have close to that much money in their suspension.
  15. Oct 5, 2022 at 9:25 PM
    empty_lord
    05 rollover special
    Oh… that’s just parts. Labor is uh… 1300 I believe
  16. Oct 5, 2022 at 9:26 PM
    empty_lord
    05 rollover special
    The geometry correction stuff in the kit is neat. But I’d never pay for all that
  17. Oct 5, 2022 at 10:53 PM
    daveeasa
    David
    Is this a new kit? Or the original with block in the back?
  18. Oct 5, 2022 at 11:12 PM
    empty_lord
    05 rollover special
    tundra kit is all new. still a spacer in the rear. but its a whole new spring seat.
  19. Oct 5, 2022 at 11:19 PM
    daveeasa
    David
    Ah, 3rd gen Tundra, makes sense.
  20. Oct 6, 2022 at 3:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Oh wow..Yeah that is a lot then.
  21. Oct 6, 2022 at 5:39 AM
    I'd hafta see the before/after to know if it's worth it. I know guys who'd pay $5k installed for a lift kit that's sanctioned by the OEM, doesn't invalidate factory warranty, and gives you the altitude adjustment you need.
    If there was a TRD lift kit for our 1st Gens targeted at baja or crawling, best be sure it'd consider it as an option, at least, depending on the price.
  22. Oct 6, 2022 at 7:28 AM
    empty_lord
    05 rollover special
    For serious off-roading with the weight of these new trucks. These 2.0” shocks will overheat quick. It’s a street lift. But replace the shocks with something beefier and it’s probably pretty capable without destroying street ability.
  23. Oct 6, 2022 at 7:35 AM
    tokolosh
    J
    SF Bay Area
    new driver
    2.0's! Even the Tacoma TRD kit is 2.5's I believe, 2.0 on the Tundra is sad
  24. Oct 6, 2022 at 7:46 AM
    Sunnier
    Sunny
    San Diego, CA
    The 3rd gen design change I wondered about, when I saw one at T2S, was the mount where the top of the shocks attach. Unlike earlier gens, it is welded to the frame— so replacing those with gusseted after markets didn’t look very possible… and would require cutting out the old and welding in new. And it did not appear robust enough to hold up to fast off-road driving. So, whereas most of us know that no suspension upgrade automatically voids a warranty, that one would. I made an immediate decision that it would never be an equivalent truck for off-roading, compared to earlier generations, because of this significant limitation.
  25. Oct 6, 2022 at 8:13 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Aluminums strength degrades at a much quicker rate. The more you stess it, the more brittle it gets. I know its just an appliance, and you move to something else when the check engine light comes on, but id prefer things that outlast their welcome. When my timing belt breaks, i'm getting a sbf or a 5.3 ls... or a anything else. Instead of trying for 400 hp with a toyota. No boost, but maybe watermeth. Strugglebus up over the continental divide.
    bmf4069 and shifty` like this.
  26. Oct 6, 2022 at 8:39 AM
    bmf4069 and GODZILLA like this.
  27. Oct 6, 2022 at 8:50 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    A 'godzilla' 7.3 and whatever slushbox 10 spd / tcase would be fine. Even the upcoming 6.8 v8
    it might not have a clutch pedal, but ?triple? Overdrive would let it eat down deep. Loud pipes area. And let me fit a proper full front bench.
    dont know if i can fit a diesel capable trans without replacing the cab floor. I like the sound of the 5 cyl mb's, would probably fit.
    forgot i wanna do a 1-2" bodylift before doing bumpers and sliders. Might be able to fit a big eaton or spicer or more likely a light duty trans and a 4:1 tcase.
    txagg likes this.
  28. Oct 6, 2022 at 9:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The noise seems to be getting worse so today I jacked it up and took off the front wheels.
    The passenger side outer tie rod looks like it's spewing grease but not sure if that would cause a popping noise. Also noticed the LCA bushings are starting to show their age. The sway bar links were replaced last year but I didn't use OEM. That might be the issue. Sort of a mystery at this point.
  29. Oct 6, 2022 at 9:50 AM
    This is one of those times when rolling next to the vehicle on a skateboard may prove handy. Or GoPro.
  30. Oct 6, 2022 at 10:23 AM
    Casper421
    In the woods
    06 DC
    Check the sway bar links for play. Normally the cause of popping noises over bumps. They’re a year old but could be toast if they were a shitty brand.
    txagg likes this.
