  1. Aug 17, 2022 at 1:57 PM
    I bet you're more likely to pinch a loaf than to drop one if you get tased.
    RUSTYNUTS and Jack McCarthy like this.
  2. Aug 17, 2022 at 2:07 PM
    Good point. I used to stick forks and paperclips in electrical outlets as a kid and I never felt so much as a bowel tickle from that, specifically.
    I did get hit by a 220 HO 8ft fluorescent fixture on a grocery store ceiling once, and fell off a 20ft scaffold. That didn't make me poop either.
    But I'm also not known for having a loose caboose, either, so there's that...
  3. Aug 17, 2022 at 3:52 PM
    Those fluorescent fixtures have even higher voltage transformers in them. You rode the lightening for sure that time
    FrenchToasty likes this.
  4. Aug 17, 2022 at 3:56 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Or a lot of them are usually 277 to ground
  5. Aug 17, 2022 at 5:46 PM
    IIRC, I'm pretty sure it was the high output fixtures in the freezer cases that were 277, and I vaguely remember someone telling me why that was the case, but I don't recall the logic behind it all.
    Basically the protective cover over the spring-loaded end of higher-voltage fixtures on the ceilings, and the higher-output ones in the freezer cases, would disintegrate from the low humidity and maybe low temperature in the case or high temperature of the ceiling. That end of the fixture is spring-loaded so you can wedge 8ft bulbs in.
    I can't tell you how many times over the year or so I worked for this lighting company in Orlando that re-lamped entire grocery stores overnight, that I'd go into a case and accidentally tap a plunger, that would disintegrate, and I'd make contact with the spring, as I'm leaning in the case, touching metal.
    Sometimes it was just smarts. A couple of times I found myself on the other side of the aisle opening my eyes to stars. I was young, stupid, and just took it as "eh, part of the job!" back then. I'm sure I fried a bunch of brain cells in the process, but you do what you gotta do to survive. This was long before I 'married up'.
    I'm pretty sure the fixtures on the ceiling were just 220. They used single bullet-shaped male pins on the bulb ends. The HO 277 fixtures in freezer cases had more of an oval-shaped female connector on the bulb end. Most deli cases, 2x2 and 2x4 ceiling fixtures, and standard valance aisles were mostly bi-pin bulbs. We also had to do exit lights, fire lighting, etc.
    One of many weird ass jobs in my lifetime, struggling to make ends meet. Glad those days were over, but I learned so much shit about people, work, electricity and mechanics during that time, I wouldn't trade it for anything.
  6. Aug 17, 2022 at 6:11 PM
    FrenchToasty
    Mo
    Bone stock
    Hahah damn, now it all makes sense! That’s a cool story and learning experience, I don’t think I’d give up any of the hard learning experiences in my life.
    im no expert, maybe @bmf4069 can chime in; but I think wild leg(277v) lights are more efficient? Or maybe the ballasts like to run better off 277?
    we definitely have a wild, wild leg at work, one day; Milwaukee battery chargers started to glow red hot and start smoking, while the water cooler sounded like it had a turbo charger on it, and the microwave was doing nascar laps, hahahah I couldn’t stop laughing, we plugged other chargers in, ran the microwave more.
    we’ve had other issues at campus, the electricians like to be elusive and say it was a tripped breaker……. Why were you getting 240 out of a wall outlet???!?
  7. Aug 17, 2022 at 6:16 PM
    I feel like it had something to do with the freezing cold inside the cases.
  8. Aug 17, 2022 at 6:39 PM
    FrenchToasty
    Mo
    Bone stock
    Now most are LEDs but pretty sure the boards don’t like that cold either; I mainly had warranty issues from water because the lazy sparkies never calked INSIDE the conduit; freezers will draw in moisture from any gap they can…….
    That’s why the doors and windows have strip heaters in them, keep them above the dew point
  9. Aug 17, 2022 at 7:48 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Skid Row has some “scratch and dent” front skid plates up on their website.
    I got mine through the same sale a couple years ago. It’s gonna get scratched eventually... Lol
    “1stGen10” for an additional 10% off and I think free shipping.
  10. Aug 17, 2022 at 7:49 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    It’s been a while. Hope you guys are doing well. Here is my latest upgrade. :bananadance:
    Bikeric, NUDRAT[OP], snoope and 8 others like this.
  11. Aug 17, 2022 at 8:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So basically, a HO fixture is used for cold environments. The ballasts will send out a starting pulse to kick start the tube. It fires at around 1000v, then has a steady output around 600v. They are a huge pain in the ass are are very temperamental. I had my finger on the end of the tube as a location marker and put the other end in the tombstone. The ballast fired right then and burned two little spots on my finger.
    On a side note @shifty`, you can stick shit in an outlet all day long, as long as you're not grounded or touching the neutral. Just remember, the right side is hot, left is neutral. If the ground is down.
  12. Aug 17, 2022 at 8:14 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Speaking of electrical, I got some wire porn for yall.
    I need to get a job where I can run some pipe so I can make some pipe porn.
  13. Aug 17, 2022 at 8:23 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Got the driveway repave/extension done a few weeks or so ago. Happy to have the extra room/storage. You don't need less cars just more driveway! Now I want a carport too lol.
    Picked up a 12x6.5 tilt trailer as well.
    Been looking around for one for a while just to have around in case of needing to move stuff. Used the tilt function for a 4 wheeler and it's pretty nice so far. Trailer is a bit older but seems to be decent shape anyway and has a new light kit and some new metal on it. With the way the trailer market seems to be lately it seemed to be a good price.
    Gonna try and pull the hubs out and check out the wheel bearings tomorrow.
    shifty`, RUSTYNUTS, Sunnier and 3 others like this.
  14. Aug 17, 2022 at 8:31 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It's interesting that my folks still have a wired conduit sticking out of the ground with those twist tie-offs for electrical circuits. It sits right where the pump for the 30' above ground pool existed 25 years ago.
    The electrician who wired it either lost his license or maybe his green card from Ireland a year or two after it was done. It'll be interesting how that's addressed when they go to sell the house in the future.
  15. Aug 17, 2022 at 8:31 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Well, another day, another year older. At least the weather chilled out today.
  16. Aug 17, 2022 at 8:33 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :eek:
  17. Aug 17, 2022 at 8:33 PM
    Jack McCarthy
    Bill
    North of Boston
    bmf4069 and 5N0W808 like this.
  18. Aug 17, 2022 at 9:03 PM
    NickB_01TRD
    Nick
    KY
    Happy birthday! @bmf4069
    bmf4069[QUOTED] likes this.
  19. Aug 17, 2022 at 9:57 PM
    Sunnier
    Sunny
    San Diego, CA
    Happy birthday @bmf4069 . I’m sorry that, even with online reminders, we suck at birthdays. I hope it was a good day!
    bmf4069 likes this.
  20. Aug 17, 2022 at 9:58 PM
    Sunnier
    Sunny
    San Diego, CA
    Ugh. I guess there’d be no sense you buying a lottery ticket tonight.
    bmf4069 and 5N0W808[QUOTED] like this.
  21. Aug 17, 2022 at 10:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    fun fact... stoptech aero rotors are 500 bucks each. OOF..
  22. Aug 17, 2022 at 11:59 PM
    empty_lord
    05 rollover special
    oh yea. knew about it. the aero rotors never have been cheap. i've got a buddy thats trying to see what his cost is on them.
    the ones from toyota are drilled. 340 a piece my cost. but i'd rather slotted.
    (at least the old product info says drilled)
  23. Aug 18, 2022 at 12:29 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Happy bday bmf. Put that grill to work?
  24. Aug 18, 2022 at 4:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I need a new one. That one needs to be taken behind a shed and shot.
    5N0W808, Sunnier and Mr.bee[QUOTED] like this.
  25. Aug 18, 2022 at 4:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I did find one pic of some pipe I ran when I started working at the new place. Transition kick 90s (going from one axis to another while changing height, basically changing all three axiis) are a bitch. I call it the waterfall.
    Bikeric, KK6PD, NUDRAT[OP] and 3 others like this.
  26. Aug 18, 2022 at 5:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I just checked their website. Didn't see it. Just realized when I came back to post that you saw on Instagram.
    Oh, and happy belated birthday @bmf4069
    Rheywood456[QUOTED] and bmf4069 like this.
  27. Aug 18, 2022 at 6:09 AM
    Just knowing some jackass will eventually come behind you, adding something later, and will defile your art in that box, it kills me.
    Happy belated beauday. Thanks for the clarification on HO. I remember it was something with cold, but not the specifics. That was 30yrs ago now.
  28. Aug 18, 2022 at 7:22 AM
    empty_lord
    05 rollover special
    Drilled vs slotted? Slotted doesn’t tend to crack as easily
    5N0W808[QUOTED] likes this.
  29. Aug 18, 2022 at 8:19 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i bet theres a spot in the spine behind the intestines that could make someone poop.
  30. Aug 18, 2022 at 9:18 AM
    Meh, just hit 'em with the brown note.
    Vallejo206 and KNABORES like this.
