  1. Jul 13, 2022 at 11:31 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Jealousy is a stinky cologne my friend.
    des2mtn likes this.
  2. Jul 13, 2022 at 11:54 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    :cheers:
    des2mtn likes this.
  3. Jul 14, 2022 at 4:16 AM
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    No, but she thought I was which made it even worse.
    I think she was taking all her anger out on me from all the guys that dumped her.
    How could I tell? I could hear her sobbing through the walls.
    5N0W808 likes this.
  4. Jul 14, 2022 at 7:11 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Yeah! It's only 49.5% of the state, dammit!
    It's not hype if it's happened on several occasions in recent years.
    I feel like this should be in the 'what'd you do today'
    For a sec, I had to check which thread I was in. Lately, the 'what'd you do today' thread has been feeling more like the lunch table. The two threads are becoming a bit indistinguishable. Somehow, conversation of recreational tax over there right now, over here we're looking at 1st Gen suspension goodness! :D
  5. Jul 14, 2022 at 7:23 AM
    This thread is currently identifying as the “what have you done to your first Gen Tundra today?” Thread.
  6. Jul 14, 2022 at 9:12 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I need an adult.
    if i wanted to run lights under my bedrails, and wanted to use a momentary switch for the tailgate, and a switch, wired up like a 3-way in a house, where the switch reverses the momentary. So i could have the light on with the tailgate closed, or off with it open...
    possible? Do i need a fancy switch or relay?
    5N0W808 and RUSTYNUTS like this.
  7. Jul 14, 2022 at 9:25 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  8. Jul 14, 2022 at 9:32 AM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Yes, follow this diagram. you need 1- SPDT MOMENTARY SWITCH, 1- SPDT REGULAR SWITCH.
  9. Jul 14, 2022 at 9:34 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    yep, what he said ^
    KK6PD likes this.
  10. Jul 14, 2022 at 9:35 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    that napkin is the way
    KK6PD likes this.
  11. Jul 14, 2022 at 9:35 AM
    So, wait. Let me get this straight.
    You want a pin switch/plunger that will turn the lights on/off with open/close of the tailgate.
    In that same circuit, you want an override switch that you can flip on/off to turn the lights on/off regardless of the state of the pin switch/plunger?
    EDIT: N/m, @KK6PD looks like he's got you covered.
    KK6PD likes this.
  12. Jul 14, 2022 at 9:44 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    just lately huh? :rofl:
    des2mtn, FrenchToasty and 805Tundra like this.
  13. Jul 14, 2022 at 9:48 AM
    I mean ... all time is relative, I guess, at least that's what some famous German dude said once.
    It may just be me, but it seems like it's gone off on a few more tangents than normal lately. Not like I'm not guilty of derailing, I usually don't realize what thread I'm in when I reply.
    But then again, I often don't know where the hell I am these days.
  14. Jul 14, 2022 at 9:53 AM
    KK6PD
    ROAD
    I had to upgrade the post with a Post-it note.. I shouldn't draw schematics 5 minutes after waking up... revision correct!
  15. Jul 14, 2022 at 10:08 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Spdt momentary?
    explain it like i'm 5.
    not really an override. Like a 3-way circuit. Where the secondary (tailgate momentary) depends on the primary.
    can leds be driven from both sides?
    5N0W808 likes this.
  16. Jul 14, 2022 at 10:18 AM
    Not to complicate the responses, but can a DPST be used instead with both switches able to trigger the relay?
  17. Jul 14, 2022 at 10:20 AM
    KK6PD
    ROAD
    OK, components 101...
    SPDT Single Pole Double Throw. this is a switch that has a common that switches between the two poles....
    SPDT Momentary, same thing, but one side is always connected, other side needs the button to be depressed to make contact. Usually indicated with a NO, Normally Open, NC Normally Closed and a Common
    The tailgate switch would be located at the tailgate. The other in the cab.
    I would mock this up before you install it. Wire as shown, use a 9 volt battery in your mockup. get it to work on a table, then do it again on the truck. This is a pretty simple circuit.
    Can LEDs be driven from both sides????
    Not sure what you mean???
    You can run as many LEDs as you want, but they all have to be on the same side of the circuit. And I would run those LEDs in series to minimize the current draw.
    Mr.bee[QUOTED] likes this.
  18. Jul 14, 2022 at 10:22 AM
    Jack McCarthy
    Bill
    North of Boston
    single pole double throw
  19. Jul 14, 2022 at 10:27 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I need a 3 wire momentary?
    this is what ive got:
    Pressed button with the tailgate closed would turn the light on. And a switch under the bedrail near the front driver tie down would be ideal. Flip the switch and the light would be on until i open the tailgate.
    plan to run power from the reciever hitch. Relay could work.
  20. Jul 14, 2022 at 10:30 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Make everything as simple as possible, but not simpler.” Albert Einstein
  21. Jul 14, 2022 at 10:34 AM
    Jack McCarthy
    Bill
    North of Boston
    You obviously don’t know the people I have to work with sometimes. People have to be explicitly told to not spit into the hybrid module. Like it’s okay if I don’t tell them even though it’s a $10k assembly.
  22. Jul 14, 2022 at 10:35 AM
    KK6PD
    ROAD
    If all you had were DPDT's, yes you could use them, but only one (1) side of the switch would be used, and you still would need two (2) physical switches....
  23. Jul 14, 2022 at 10:38 AM
    Both a momentary and a rocker style switch could be used independently of each other or at the same time to control the lights correct?
  24. Jul 14, 2022 at 10:41 AM
    daveeasa
    David
    I wouldn’t want it as described. I would want three functional elements.
    tailgate open, auto on
    3 way rocker for on / off / auto
    or in more basic blocks:
    Pin or mercury switch for tailgate is open / closed for auto mode
    Kill switch for the above (off if using a rocker)
    On switch for “give me led”
    shifty` likes this.
  25. Jul 14, 2022 at 10:42 AM
    KK6PD
    ROAD
    Yes that would be correct, as long as both switches were SPDT minimum....!
    KNABORES[QUOTED] likes this.
  26. Jul 14, 2022 at 10:44 AM
    KK6PD
    ROAD
    What you have there is a simple SPST Single Pole Single Throw, NO, Normally Open switch.
    You would need to replace that switch with a SPDT NO Normally Open switch.
    Sunnier and Mr.bee[QUOTED] like this.
  27. Jul 14, 2022 at 10:46 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    3 way toggle is the way. On/on if open/off. Thank you.
    daveeasa[QUOTED] likes this.
  28. Jul 14, 2022 at 10:46 AM
    daveeasa
    David
    To accomplish that stuff it’s easiest with ground switching. Off floats the ground input to the tailgate switch making it useless. On grounds the LED’s directly. Auto sends ground to the tailgate switch to the led. Typically a relay is used so we are discussing feeding the negative of that relay coil. The relay itself can connect ground or power depending on what is easier but if the relay is ground switched then it needs power for the other side of the coil so may as well output power to the lights from that one feed.
  29. Jul 14, 2022 at 10:47 AM
    KK6PD
    ROAD
    Yes that would work, but you are over complicating the circuit, your Items 1 & 2 could be combined in the momentary SPDT switch and achieve what you want!
  30. Jul 14, 2022 at 10:48 AM
    daveeasa
    David
    We can disagree on the value but I do agree it’s more complicated. I would want the switch in the cab or accessible from the cab. For “s I forgot” when driving with tailgate down.
