  1. Jul 6, 2022 at 11:29 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    When I fitted 12" shocks, the compressed distance was the concern, so they don't become bump stops. When you lift the truck, that doesn't do anything to the distance of the leaf's to the actual bump stops on full compression. Unless your lift means you can no longer compress that much, which would be odd. So, without relocating shock mounts, a bigger shock body could be a problem.
    A problem that could be solved with higher bump stops...
    RUSTYNUTS[QUOTED] and Bikeric like this.
  2. Jul 6, 2022 at 11:30 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    It should be fine so long as you don't use the shock as your bottom bump stop. It will be 15" fully compressed vs. 13", but what's a couple of inches between friends??
    FrenchToasty and alb1k like this.
  3. Jul 6, 2022 at 11:58 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Of course the bumps would need to be changed to accommodate, I was asking about the stock mounts
  4. Jul 6, 2022 at 12:03 PM
    Casper421
    In the woods
    06 DC
    With no sway bar, the steering rack is my limiter.
  5. Jul 6, 2022 at 12:04 PM
    alb1k
    Left Coast
    It's good
    Oh, well, IDK then. Seems like that would fit, but can't say other than those stems and lower bushings should be the same size.
  6. Jul 6, 2022 at 12:30 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Add more caster.
    Our low stock caster # is why steering feel is numb.
    Mr.bee[QUOTED] likes this.
  7. Jul 6, 2022 at 1:04 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Same S1 upper and E2 12mm lower mounts........;)
    RUSTYNUTS[QUOTED] likes this.
  8. Jul 6, 2022 at 2:09 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    For some dudes, maybe a couple of thrusts? :rofl:
    Bikeric[QUOTED] likes this.
  9. Jul 6, 2022 at 2:16 PM
    alb1k
    Left Coast
    It's good
  10. Jul 6, 2022 at 3:15 PM
    Jack McCarthy
    Jack McCarthy My work anxiety is my morning alarm clock
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Yes I have, but not the unsynchronized manual transmission and 2 speed rear end. That seems like a PIA unless you’re very good at doing it manually.
    tpope[QUOTED] and Leo's first like this.
  11. Jul 6, 2022 at 3:17 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    every time the carb flooded & the car died - LOL. 4,735 pounds of manual riding on 265/75 15's or so.
    tpope and Jack McCarthy[QUOTED] like this.
  12. Jul 6, 2022 at 4:54 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    You learn to double clutch, when to use the throttle and to carefully feel gears engage. Brought many a load of corn from the fields to the grain bins in a 1948 International single axle dump.
  13. Jul 6, 2022 at 5:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Enjoy some photos of the in progress exhaust for the tundra
    [​IMG] [​IMG]
    Voss, KK6PD, RUSTYNUTS and 9 others like this.
  14. Jul 6, 2022 at 5:15 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hell yeah
    Voss, RUSTYNUTS, NUDRAT[OP] and 2 others like this.
  15. Jul 6, 2022 at 5:31 PM
    daveeasa
    David
    On the subject of double-clutching, I still have much to learn. My bro in law desires his Freightliner 10spd driven without using the left foot except to start. The rev limiter is 1700 rpm though so there isn't a ton of range like there is on these light duty pickup trucks.
    The most interesting/challenging experience I had with that was one haul when his clutch brake was toast. So, you could only get into gear with the engine off after it spun down. If you forgot and left it in neutral with the engine running and came to a complete stop, you had to grind or stop and restart. We got rather adept at finding parking spots on a hill so we could roll start. Didn't seem to phase him one bit, I found it a bit of an extra challenge.
    I kinda wish I had more practice with double clutching b/c you have to be quick, the thing spins down if you're slow. I mean, I guess I got more practice in general b/c I feel like the more you drive those things, the more it starts to feel intuitive.
  16. Jul 6, 2022 at 5:32 PM
    That's just weld pr0n right there.
    Voss, FirstGenVol, KK6PD and 6 others like this.
  17. Jul 6, 2022 at 5:37 PM
    daveeasa
    David
    California would require a million parental advisory stickers / engraving. Cali, home of the exhaust haters
    FrenchToasty likes this.
  18. Jul 6, 2022 at 6:03 PM
    Fucking art.
    Voss, KK6PD, RUSTYNUTS and 3 others like this.
  19. Jul 6, 2022 at 6:24 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Who's doing your welding. That, my friend, is a work of art.
  20. Jul 6, 2022 at 6:25 PM
    NUDRAT
    SW CT
    I'm new in my town, so have to depend on references. When I ask for something like a welder people will tell me I have to go to so & so his welding is so (right image), I go & see so & so's work & it's left image at best. You've got better referrals. If you ever run out of cash - sell your little black book of tradesmen!
    5N0W808 likes this.
  21. Jul 6, 2022 at 8:25 PM
    empty_lord
    05 rollover special
    Hockman fabrication. This is costing me a pretty penny. But damnit it’ll last. And this trucks not leaving me any time soon
  22. Jul 6, 2022 at 8:31 PM
    FrenchToasty
    Mo
    Bone stock
    This winter I’ll probably extend my pipes past my bumper. Shits noisy! I’d love
    To do some cut outs in my bumper, but not sure how clean I can make that happen
    RUSTYNUTS likes this.
  23. Jul 6, 2022 at 8:39 PM
    alb1k
    Left Coast
    It's good
    Not a fan of a turndown after the muffler? LOL.
  24. Jul 6, 2022 at 8:49 PM
    FrenchToasty
    Mo
    Bone stock
    Eh not so much, I mean yes…… but no.
    It’s kind weird, it’s almost less obnoxious on the freeway just cruising, the in city up and down Rpms gets old sometimes……… I’ll definitely goose it for other “cool” Toyotas, this sweet taco got the fumes on the way home from a side job on the east side
    RUSTYNUTS and alb1k[QUOTED] like this.
  25. Jul 6, 2022 at 8:51 PM
    empty_lord
    05 rollover special
    my mufflers have the cutouts built in. he's going to see if he can get the pipe past the axle. but i'll just be dumped down with no tips. dual pipes though.. these engines love to breath like the 3.5
  26. Jul 6, 2022 at 8:52 PM
    alb1k
    Left Coast
    It's good
    Haha! I don't have an aftermarket muffler, so it's a no brainer for me...
  27. Jul 6, 2022 at 8:59 PM
    alb1k
    Left Coast
    It's good
    What they see in 3rd Gen Forum...
    What I see...
    shifty` and 5N0W808 like this.
  28. Jul 6, 2022 at 9:03 PM
    FrenchToasty
    Mo
    Bone stock
    It is great, I’ve even seen some second gens misposting in the 3rd gen section, I always assumed they were just trying to piss us off. Clearly it’s a serious disease
  29. Jul 6, 2022 at 9:03 PM
    empty_lord
    05 rollover special
    i've pretty much determined the red 2002 will be for sale once i get it done and drive it a for a month or 2 to make sure all is well
    RUSTYNUTS and 5N0W808[QUOTED] like this.
  30. Jul 6, 2022 at 9:05 PM
    alb1k
    Left Coast
    It's good
