  1. Jun 13, 2020 at 12:57 PM
    #3421
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I know you tow, I bet that rear helps out a lot?
  2. Jun 13, 2020 at 12:59 PM
    #3422
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hey, just wanted to try something out.
    Let me know what you guys think?
    Obviously, for the bed I don't really care about overspray since it will all be hidden.
    https://youtu.be/9NfkJlYbX9c
  3. Jun 13, 2020 at 1:00 PM
    #3423
    FrenchToasty
    Mo
    Bone stock
    I like it, I’m surprised you were able to get that much paint out of the can at those weird angles.
  4. Jun 13, 2020 at 1:00 PM
    #3424
    Professional Hand Model
    Hand Protectors
    It helps with towing, too. That rear stays planted towing or not. Highway speed lane changes are very crisp. Curves are a breeze. More women look my way and better MPG, as well!:D
    NUDRAT[OP], bmf4069 and Hooptytrix like this.
  5. Jun 13, 2020 at 1:01 PM
    #3425
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That's my magic Amateur fingers :thumbsup:
  6. Jun 13, 2020 at 1:01 PM
    #3426
    FrenchToasty
    Mo
    Bone stock
    Haha they need to add that last line into their sales pitch!
  7. Jun 13, 2020 at 1:06 PM
    #3427
    Hand Protectors
    I’d say its my top performance mod (other than having the entire front end rebuilt due to tiredness). Brakes conversion from WE to WL are my second. You may have some seized calipers from age going on. Mine were bad.
    Tundra2 and FrenchToasty[QUOTED] like this.
  8. Jun 13, 2020 at 1:08 PM
    #3428
    Hand Protectors
  9. Jun 13, 2020 at 1:09 PM
    #3429
    Hand Protectors
    Tundra2 likes this.
  10. Jun 13, 2020 at 1:09 PM
    #3430
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Today just got a little better. USDA choice Porterhouse was on sale $9.90 lb
  11. Jun 13, 2020 at 1:11 PM
    #3431
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's nothing. I did an illegal wet change on a 6" city sewer main to replace a busted saddle. I went through the asphalt, dug down a foot under it, pre dabbed an ABS section to swap in. I had a labor guy holding two shop vac hoses in the hole and I rigged two sets of chain snaps connected and popped on both ends. Yanked, stomped the ABS in, no hubs on and done.
    Next day the city showed up. They got a complaint about jack hammer's in the alley and came to inspect. When I told them what I did his face was absolutely priceless. He made me dig it back up and replace it with clay pipe.
  12. Jun 13, 2020 at 1:17 PM
    #3432
    FrenchToasty
    Mo
    Bone stock
    So your a plumber huh?!
    At first I read it as you used none no hub couplings, I was like how the fuck did that work out?!
    and clay sucks, I used a grinder to score and hammer to bust out the rest, when I did my kids school main line, 4”
    Tundra2 likes this.
  13. Jun 13, 2020 at 1:27 PM
    #3433
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fernco actually, the clay to ABS kind. I was a service plumber for 6 years or so, did a lot of wild shit.
    Some highlights include getting lowered into a grease trap at an IHOP to replace a busted tee, no fancy harness, I hooked a ratchet strap to my bumper and had a buddy back up slowly, the tee was about 4 feet below ground level and too far to reach any other way.
    My 3rd day on the job I helped a guy pull a run of rolled copper through an old water line. We dug up an area near the house, dug an area at the meter, used steel cable and made a spear on the end of the copper where the cable went through. The steel cable went through the old water line and to the bumper of the truck, I held the roll and unwound it while he drove away in the truck. The line broke half way through, we had to dig it up and start again but it made it under a 3 car driveway. Next day my trainer asked what I learned, when I told him his face was priceless too. I forget the name of the old piping, it was a blue plastic, almost like a brittle version of Pex.
    I can't remember all the wild crap. I do remember a lot of sketchy jobs though and weird people I ran across.
  14. Jun 13, 2020 at 1:29 PM
    #3434
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Jun 13, 2020 at 1:33 PM
    #3435
    FrenchToasty
    Mo
    Bone stock
    Lots of weirdos in the service industry; sorta like the 1st gen crew;)
  16. Jun 13, 2020 at 1:44 PM
    #3436
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not an electrical leak but I rewired the pavilion at my Aunt's picnic pavilion yesterday. Some genius managed to make 6 outlets work off of 1 GFI wired from 1 breaker. 14-3 Romex with red and black tied to 2 separate breakers sharing the neutral.
    1st 2 gang box had the GFI with the black on the line side, a single red from the load side tied into the other outlet. Then the neutral wire nutted together to both outlets plus another 14-3 with the incoming red nutted to it's red and the black to theblack on the regular outlet.
    Next 2 gang box had red to the black of a 12-2 UF cable and the 14-3 black to an outlet. Same deal with the neutral here all wire nutted together. The two outlets then wired together.
    The UF cable then went to another outlet wired correctly.
    All of this was stapled exposed to the elements, 6 space sub panel with only 4 breakers used for lights, outlets, and a pool pump. Oh and no weather covers on anything.
    I ran all new 3/4 conduit, 12 gauge wiring, added another outlet for decorative lighting, added in use covers to everything, and put every pair on it's own circuit with a properly wired GFI in each.
  17. Jun 13, 2020 at 1:47 PM
    #3437
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Fellas, will it hurt anything to cut the extra off the ends of my U-bolts?
    If I don't i will never be able to get the torque wrench on.
    Figured I would ask before going through with it.
  18. Jun 13, 2020 at 1:51 PM
    #3438
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The extra I am talking about.
  19. Jun 13, 2020 at 1:52 PM
    #3439
    Festerw
    Festerw New Member
    04 Tundra DC
    Nope chop it off
  20. Jun 13, 2020 at 1:52 PM
    #3440
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okie dokie
    Learned a lesson with this. Tape the threads before painting. Lol.
  21. Jun 13, 2020 at 1:53 PM
    #3441
    FrenchToasty
    Mo
    Bone stock
    Cut it out-Joey Gladstone
    CodyP, Darkness and Tundra2 like this.
  22. Jun 13, 2020 at 1:55 PM
    #3442
    FrenchToasty
    Mo
    Bone stock
    So many leafusus up in there!
    Darkness and YardBird like this.
  23. Jun 13, 2020 at 2:40 PM
    #3443
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Group buy long tubes. Make this happen and I’m in
    FrenchToasty[QUOTED] and bmf4069 like this.
  24. Jun 13, 2020 at 2:58 PM
    #3444
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There you are. I remembered somebody in here was a wire weasel but forgot who.
    It's amazing what people can fudge up. I've been on more than a few calls of "homeowner replaced switch and now it's not working". They put a single pole switch in a 3 way and put one of the wires on the ground screw. That or they replace a plug and put blk/wht blk/wht on the sides and wonder why the breaker is popping. Ah, the life of a service tech.
    lsaami likes this.
  25. Jun 13, 2020 at 3:04 PM
    #3445
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Well shit. Even more parts to sit around and take up space.
  26. Jun 13, 2020 at 3:05 PM
    #3446
    Festerw
    Festerw New Member
    04 Tundra DC
    Not a sparky by trade but I'm at least halfway knowledgeable. Troubleshooting wiring diagrams has helped me out more than a few times.
    Tundra2 and bmf4069[QUOTED] like this.
  27. Jun 13, 2020 at 3:08 PM
    #3447
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I love wiring diagrams. I was an electronics tech in the navy so I've seen a few of em in my day.
    Maybe it was somebody else who was a sparky....
    TX-TRD1stGEN and Tundra2 like this.
  28. Jun 13, 2020 at 3:13 PM
    #3448
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Chop them off
  29. Jun 13, 2020 at 3:18 PM
    #3449
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Both leafs are in.
    All 4 u-bolts have been chopped.
    I had to run to town, and buy another torque wrench because I didn't do my homework when I bought the first one.
    Went with the tekton ½" drive.
    ALMOST bought the Dewalt version because it goes up to 250 ft. Lbs.
    Didn't feel like dropping over $100 for a torque wrench though. Plus its like 2.5 feet long.
    This one
    https://www.amazon.com/dp/B01JVE1C84/ref=cm_sw_r_other_apa_i_Edv5EbMAY5GAY
    Hooptytrix and Darkness like this.
  30. Jun 13, 2020 at 3:20 PM
    #3450
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
