  1. May 24, 2022 at 7:01 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes, Randy can work a camera! He took these: 09197E98-13F6-4377-8722-32FE510853E0.jpgD20FB082-E200-40B5-931B-D212A0E9013C.jpg
    Unfortunately, I haven’t been able to buy print-quality versions. Bruce and I would love to have ‘em to mount and frame, we’re both so proud of the Hulk in action.
    5N0W808, bmf4069 and FrenchToasty like this.
  2. May 24, 2022 at 7:03 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I love that top pic. Why can't you get high res? Or just run them on canvas perhaps.
  3. May 24, 2022 at 7:13 PM
    Sunnier
    Sunny
    San Diego, CA
  4. May 24, 2022 at 7:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is Bruce a full time fabricator? Or just homies kinda thing?
  5. May 24, 2022 at 8:10 PM
    Sunnier
    Sunny
    San Diego, CA
    Homies. He’d love to build a shop— and has space on his property to do it, so it’ll probably happen eventually— to accommodate more homies and more fun builds, but he’s got a real “adult” full time gig that requires a lot of travel, is an active military reservist, and has a lovely wife he wants to keep— so since he got this job, he’s kinda scaled back on some of the driveway truck builds. A talented guy though, and he loves wrenching, so he’ll probably continue to do builds and fabricating as time permits.
    shifty` and FrenchToasty[QUOTED] like this.
  6. May 24, 2022 at 8:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I only turn OD off if the transmission starts hunting.
    Even towing 7000 lbs I’ve yet to have the transmission start hunting.
    Sunnier likes this.
  7. May 24, 2022 at 8:50 PM
    empty_lord
    05 rollover special
    More progress on the engine. Pretty much assembled. Also ordered a new transmission from Toyota. I give up trying to deal with these junkyards for a used transmission. I’ll still piece an e153 together. But fuck it, brand new LSD e153 coming from Toyota. Hopefully soon. I’ll know shortly.
    [​IMG][​IMG][​IMG]
    NUDRAT[OP], alb1k, Sirfive and 3 others like this.
  8. May 24, 2022 at 9:39 PM
    daveeasa
    David
    Remind me, stock gears still?
  9. May 24, 2022 at 10:02 PM
    daveeasa
    David
    Random thought of the evening, is it possible to stuff a 4wd rear only kit into a 2wd to get 2 lo, or is that all in the transfer case at which point doing a full 4x4 conversion makes more sense ?
  10. May 24, 2022 at 10:08 PM
    Sunnier
    Sunny
    San Diego, CA
    I’m not sure what you’re asking but I don’t know what 2 low is.
    You can add a locker to a 2wd which would allow you to lock the rear wheels of a 2wd… and that would add capability in a lot of situation. Like the Tacomas have licking diffs in back.
    But a 4x4 conversion, while fun and we all want to see one… so please spend that money and post a lot of pics!… doesn’t make a lot of sense; buy a different truck if you have a 2wd and want the same truck but with 4x4.
    KK6PD and daveeasa[QUOTED] like this.
  11. May 24, 2022 at 10:14 PM
    daveeasa
    David
    I am just trying to understand options on a 2wd. I have 1 of them and don’t plan to do anything but street with it. The other two are both 4wd already.
    but, thinking out loud, is adding a TC significantly more work to the point that a 4x4 conversion makes sense or has anyone ever done a TC for 2wd? Assuming the TC provides low vs high gear?
  12. May 24, 2022 at 10:16 PM
    daveeasa
    David
    And clearly a locker in a 2wd makes sense and adds legit capability. But low gear range has to be worth something too, right? So my question is where does that low gear live? TC or diff?
  13. May 24, 2022 at 10:19 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    yea, low is in the tcase. I havent looked too hard, but i should be able to do a switch to the ADD to gimme 2 low.
    or, have a look at a gear vendors.
    https://www.gearvendors.com/index.html
    *insert ric flair gif*
    I think the last time i looked they were around $1k. They are now over $3k…
  14. May 24, 2022 at 10:31 PM
    empty_lord
    05 rollover special
    Yes.
  15. May 24, 2022 at 10:32 PM
    empty_lord
    05 rollover special
    All you need to do is trick the ADD into thinking it’s engaged to make 2lo a thing
    Sirfive[QUOTED] likes this.
  16. May 24, 2022 at 10:39 PM
    daveeasa
    David
    But a 2wd prerunner won’t have a T case right? So no low gear? And the benefit of going locker plus low is x vs fully 4x4 conversion as y and x is close enough to y that everyone goes y?
    CodyP likes this.
  17. May 24, 2022 at 10:45 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I guess it depends what you want to do. Offroad? 4x4 is much better.
    Drag a loaded shipping container across pavement? 2 low should get you there.
    snowbobs truck did some impressive things in 2wd with the locker on. My 2wd atv made it through a level 4 trail, and so did my buddies ozark 250. 4wd would have been helpful in the gravel and sandy bits, but where traction was available, 2wd was fine. (But live axle locked 2wd)
    daveeasa likes this.
  18. May 24, 2022 at 10:47 PM
    empty_lord
    05 rollover special
    there is no transfer case yea. so no. there is no "low" gear. (technically any gear that isnt 1:1 is a low gear though... high gear if its above 1:1)
  19. May 24, 2022 at 11:02 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  20. May 24, 2022 at 11:03 PM
    empty_lord
    05 rollover special
  21. May 24, 2022 at 11:19 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    True dat. I dont know why i was picturing the 2wd trans like i was. I know ive seen a trans without a separate tailhousing, but brainfart as to what it was in.
    buick dynoflo
  22. May 25, 2022 at 3:35 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I strangely feel compelled to clean the rust of those pulleys and it's not even my engine. :ballchain:
    I need help. haha :help:
  23. May 25, 2022 at 5:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  24. May 25, 2022 at 7:15 AM
    ... that dipstick proximity to header!
  25. May 25, 2022 at 7:17 AM
    So ... this is a complaint from a lot of folks driving the damn things, inability to see things over the absurd hood bulges. How much longer y'all think before the NHTSA forces auto makers to stop doing this BS design where you can't see over the front of the hood?
    It's one of the main reasons I love our trucks, and really find the post-1GT models ugly af. This is really not ok...
    KNABORES, 5N0W808, KK6PD and 3 others like this.
  26. May 25, 2022 at 7:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    KNABORES likes this.
  27. May 25, 2022 at 7:18 AM
    PS - this actually happened over the weekend. I had to fab up some stuff under my bathroom sink, and I actually had the spare wood on-hand.
  28. May 25, 2022 at 7:47 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I feel this one. I'll never resist the urge to take a good 2x4 from the scrap pile, even if it means pulling a few nails.
  29. May 25, 2022 at 7:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    No kidding. Back when lumber shot up we went to replace a motor on a generator. It was a crate motor so it came wrapped in plywood nailed to a 2x4 frame. You're damn right I kept every piece of that. My coworker said trash it.
    KK6PD, RUSTYNUTS and shifty`[QUOTED] like this.
  30. May 25, 2022 at 8:18 AM
    I'm having major issues right now just driving through my neighborhood. 2 dozen houses going up, along with hundreds of townhome/condo/apt within 2 blocks, and 6,000 of the latter within 10-12 blocks. Every time I walk the dog I walk past one of the houses, tons of scrap 2x (4/6/10) laying around. Not enough room in my garage to keep it all, but I've picked out a few choice pieces, and mroe will probably land in the attic. May end up finishing out the rest of my attic floor before long.
    This weekend, I needed to build a curb around a cutout for p-traps under my master sink. Ran down to the shop, "I know I got this!". Sure enough, I had 2 pieces if furring strip leftover from a door frame I built damn near back when our 1st kid was born, about 26" each piece. I only needed four 7" pieces and two 6" pieces to build my curb, perfect match. Bradded together with narrow crown, glued and trim nailed into place. Happy wife, happy life.
    Y'all don't even want to see the footlong mouse that came out before I installed the new p-trap setup. Much less smell it. If you've ever been to a hair place where someone's getting a perm, imagine crossing that smell with restaurant garbage. Wanna hurk just thinking about it.
    RUSTYNUTS and alb1k like this.
