  1. May 22, 2022 at 10:22 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    the journey is the fun part. but the destination might be pretty fun too. :rocket:
    CodyP likes this.
  2. May 22, 2022 at 10:41 AM
    Sunnier
    Sunny
    San Diego, CA
    Chris Davison at Tru-Line on Bradley in El Cajon is the best for old school alignments. He’ll get your caster numbers, doesn’t blink at long travel. Place is affordable. This is my ‘without reservations’ recommendation. As long as Chris does the alignment.
  3. May 22, 2022 at 10:46 AM
    Casper421
    In the woods
    06 DC
    @des2mtn do you happen to remember the part number for your CSF rad?
    FrenchToasty likes this.
  4. May 22, 2022 at 11:39 AM
    daveeasa
    David
    True Line, that was it, thanks. I had 8 appointments booked (kept postponing) and for some reason I think it was one calendar reminder and I wound up deleting it. Might be good to get it gross aligned now then fine tuned once the leafs are re-arched given how far it is at the moment. Thanks!
  5. May 22, 2022 at 5:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You don't need old school. @assassin10000 told me and he's right. Get a shop with a Hunter machine and tell them caster somewhere between +3-+4. Normal specs on the rest. You won't know for your truck on caster until you drive it. I'm now 3.5-4.0 guy. Maybe assassin sees this and has better intel on Toe and Camber.
    daveeasa[QUOTED] likes this.
  6. May 22, 2022 at 5:11 PM
    alb1k
    Left Coast
    It's good
    My truck is modded just enough that what I do doesn't necessarily work for someone else. Did I tell you my towers were shaving my spindle gussets?, lol.
  7. May 22, 2022 at 5:13 PM
    alb1k
    Left Coast
    It's good
    Drill the nail and push it through.
    shifty`[QUOTED] likes this.
  8. May 22, 2022 at 5:47 PM
    daveeasa
    David
    I have SPC uppers though, does that change stuff?
  9. May 22, 2022 at 6:48 PM
    alb1k
    Left Coast
    It's good
    Not at all.
  10. May 22, 2022 at 8:38 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Camber -0.1 if mostly freeway driven. If you like corners/onramps at speed -0.3 to offset outside edge tire wear somewhat.
    Total toe in .15-.20
    Nope. Specs are just what you want to achieve. The more parts you have the more ability you have to achieve them. It's not necessarily easier. Whoever is doing the work also needs to try and keep things even side to side (unless the frame is bent...).
    For the front (bumper) side adjusters I'd put inwards and rear (rack) side adjusters I'd put outwards to start.
    For the SPC uppers I'd set them so the balljoints are pointed to the motor (if looking down from above, 3 o'clock for Left and 9 o'clock for Right). And slide them all the way out.
  11. May 22, 2022 at 8:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m going in tomorrow for an alignment at a Lexus dealership, my buddy with the sequoia said they did a great job. I cleaned all my bits today to make their life easier tomorrow. Hopefully they can get rid of the rear frame rub
  12. May 22, 2022 at 8:43 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Tell them 2.7 caster minimum.
    The more forward, the better (for rub).
  13. May 22, 2022 at 8:43 PM
    alb1k
    Left Coast
    It's good
    Thanks buddy :thumbsup:
    daveeasa and FrenchToasty like this.
  14. May 22, 2022 at 8:44 PM
    FrenchToasty
    Mo
    Bone stock
    Thank you. I know I can get above 3 in the 4runner with TC uppers, I wasn’t sure what they could get on these trucks with spcs
    alb1k likes this.
  15. May 22, 2022 at 8:46 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Ohhhh. Tell them to do what I said above with the LCA adjusters and then even it out. This gets max caster from the stock lowers.
    alb1k and FrenchToasty[QUOTED] like this.
  16. May 22, 2022 at 8:48 PM
    daveeasa
    David
    My rub appears to be all up front now. And I need height. So gonna try to jump on the leaf problem and figure out a front bumper.
    NUDRAT[OP] likes this.
  17. May 22, 2022 at 8:48 PM
    FrenchToasty
    Mo
    Bone stock
    Hopefully I can talk to the actual tech, I feel like shit gets lost in translation thru the service writer. Supposedly most of the techs have modified toys, so they should understand what I’m saying
  18. May 22, 2022 at 8:52 PM
    alb1k
    Left Coast
    It's good
    And run it hard and take it back if you are not stoked. Except anything you spec - they may call bullshit. lol.
  19. May 22, 2022 at 8:54 PM
    alb1k
    Left Coast
    It's good
    IMO, front rub is way easier to tackle than rear. Many just trim their bumpers.
  20. May 22, 2022 at 9:08 PM
    FrenchToasty
    Mo
    Bone stock
    So I just went out and looked and it appears they are set how you suggested. 718F4405-7223-4369-91A9-2DDDD4C1D939.jpg6DDF9F2C-E5B3-481C-A54F-CBB31F002DEA.jpg
    My bad @assassin10000 is who I meant to quote
  21. May 22, 2022 at 9:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So has anyone done the vf tuner yet on the Vvti 4.7?
  22. May 22, 2022 at 9:19 PM
    alb1k
    Left Coast
    It's good
    I suggested no such thing! LOL. What are we looking at? And how do you eyeball alignment?
  23. May 22, 2022 at 9:23 PM
    FrenchToasty
    Mo
    Bone stock
    We’re looking at the top of the spc ball joint moved outward like assassin said, and then showing the ball joint inward towards the motor.
    Eye balling an alignment requires one wonky eye so you can truly see the line of straightness
    Sunnier likes this.
  24. May 22, 2022 at 9:27 PM
    alb1k
    Left Coast
    It's good
    Ahhh. Crazy adjustable uppers confuse me.
  25. May 22, 2022 at 9:30 PM
    FrenchToasty
    Mo
    Bone stock
    Edit: tactical Witch craft!
    bmf4069 and alb1k[QUOTED] like this.
  26. May 22, 2022 at 9:55 PM
    alb1k
    Left Coast
    It's good
    My pan is dialed. I'm the Pink's of quesadillas.
    KK6PD, Leo's first, Sirfive and 3 others like this.
  27. May 22, 2022 at 10:10 PM
    NUDRAT
    SW CT
    I leave notes on the steering wheel, back in the day I'd tape a note to the air cleaner lid - back when cars had carb's. & air cleaners were top center of the engine.
    FrenchToasty[QUOTED] and alb1k like this.
  28. May 22, 2022 at 10:15 PM
    alb1k
    Left Coast
    It's good
    This one looks like Richard took a wrong turn.
  29. May 23, 2022 at 4:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Lol. I have almost that same pic. Twice. There's something to be said for moving dirt with a machine and some good tunes.
  30. May 23, 2022 at 7:02 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I have SPCs and the guy I recommended earlier has plenty of experience with them.
    CSF 7030
