  1. May 18, 2022 at 8:53 AM
    Well that is not the reply I expected. Sorry you are dealing with that huge loss in your family. My condolences sir. I talked with my kids about it often when we lost my Dad and my FIL....just in case they needed to get some things off their chest. I dialed my dad's number the other day and wanted to ask him about something and it hit me....
    PM me. There is a roadmap to becoming a vendor and I can help you with that.
    shifty` and papasmurf[QUOTED] like this.
  2. May 18, 2022 at 9:05 AM
    daveeasa
    David
    So, I'm close to pulling the trigger on hammer hangers, crossmember and shackles, and resi brackets from archive garage for my leafs which I have to get re-arched.
    Curious if I'm missing anything which would be appropriate to do at the same time since the leafs will come off. I spent 6+ months waiting on the rear shocks so I'm stuck with what I have, adjustable 8" travel fox 2.5's with remote resi.
    Sort of like how I did LBJ's up front then LCA's and could have converted both to the big ball 2005+ as I did with taillights but I f'd that one up. Trying to do a best of breed / minimize mistakes.
    Any advice welcome. I think I'm nearing completion of this '02 build really, minus all the lighting and electrical and such.
  3. May 18, 2022 at 9:08 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Bump stops. Prolly don't need to go as far as hydrobumps, but something like Durobumps or Timbrens.
  4. May 18, 2022 at 9:09 AM
    daveeasa
    David
    Durobumps were ordered but likely in the package which went to the scammer. @memario1214 can confirm. I may have to re-buy them.
    des2mtn[QUOTED] likes this.
  5. May 18, 2022 at 9:10 AM
    des2mtn
    Shady Grove
    Tonto cover
    For the rear too? Meant rear bump stops specifically. On the rears you need to loosen the u-bolts, so when you do the leafs is the perfect time to do them.
    Fronts can be changed out much easier without removing any other parts.
    FrenchToasty likes this.
  6. May 18, 2022 at 9:16 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Archive has a decent set up for their rear bumps if he gets their u bolt kit I think
  7. May 18, 2022 at 9:17 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I was thinking similar. I've been using the little shaft rubber on my shocks as a guide as to how far they are compressing. I never got under 1-1/2" of remaining shock shaft on compression until I loaded heavy and hit them hard. They just I bottomed them out under load and although it was a kiss and not a hard clunk, I'm spacing my rear bumps higher. I think that will be perfect. But to @des2mtn 's point, good bump stops set at the right height can be pretty crucial.
  8. May 18, 2022 at 9:21 AM
    alb1k
    Left Coast
    It's good
    The Archive u-bolt flip allows for several brands of bump stops - I'm using theirs (yellow). What's nice is you have some spacer adjustment without pulling u-bolts. I'm putting in the bigger spacers in today.
    edit for pic with the spacers in. Note, I think there are different top plates depending on the bumps you use. If I did it again, I would get the heaviest bumps, but these are really good as well
  9. May 18, 2022 at 9:22 AM
    daveeasa
    David
    I thought it was a full set, front and rear.
  10. May 18, 2022 at 9:23 AM
    daveeasa
    David
    So, U bolt flip is worth a look too?
  11. May 18, 2022 at 9:26 AM
    FrenchToasty
    Mo
    Bone stock
    YAZZZ
  12. May 18, 2022 at 9:27 AM
    des2mtn
    Shady Grove
    Tonto cover
    I was bottoming out on my stock bumps when loaded and going over speed bumps, it was uncomfortable enough for me to want to swap them out. I don't think I've fully compressed the Timbrens yet (hard to tell without putting a camera back there), but I have about 1/4"-1/2" of clearance at ride height before they contact. Much less than the stock ones, the Timbrens are pretty dang tall. I've read about some dudes buying two sets and cutting one in half and putting those on when hitting the trail. Durobumps might be the same way, but I believe with Timbrens you can unscrew them from the perch that's held down by the u-bolts.
    FrenchToasty and alb1k[QUOTED] like this.
  13. May 18, 2022 at 9:28 AM
    alb1k
    Left Coast
    It's good
    It's worth a look. it has been really good for me and in my setup has allowed for +1/2" of bump stop adjustment that I didn't even realize I might need when I got them.
  14. May 18, 2022 at 9:29 AM
    alb1k
    Left Coast
    It's good
    separate
  15. May 18, 2022 at 9:29 AM
    daveeasa
    David
    As in I thought I ordered both.
  16. May 18, 2022 at 9:49 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Correct. You ordered Front and rear bumps. Didn't receive, but ordered/shipped... :bananadead:
    alb1k likes this.
  17. May 18, 2022 at 9:52 AM
    alb1k
    Left Coast
    It's good
    Is it ok to say what rear bumps?
  18. May 18, 2022 at 9:58 AM
    memario1214
    Colton
    Missoula, MT
    Lol yes. He bought Durobumps 3.5" rear bumps from us as well as a pair of Durobumps fronts.
  19. May 18, 2022 at 10:01 AM
    alb1k
    Left Coast
    It's good
    @daveeasa, The bumps you ordered that sound like they are lost, likely work with the u-bolt flips - but you don't need the flips, it's something you could get later if you decide to and there should be an option for any of the main bump stop types.
    NUDRAT[OP], daveeasa and FrenchToasty like this.
  20. May 18, 2022 at 12:05 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  21. May 18, 2022 at 1:00 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Wow. That look a helluva lot better than the OEM ones stuck on with double sided tape.
    alb1k[QUOTED] and des2mtn like this.
  22. May 18, 2022 at 1:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. May 18, 2022 at 1:17 PM
    des2mtn
    Shady Grove
    Tonto cover
    For comparison's sake, here's what I'm working with using Timbrens.
  24. May 18, 2022 at 1:29 PM
    Jack McCarthy
    Bill
    North of Boston
    Is the rubber piece bolted to the plate?
  25. May 18, 2022 at 1:36 PM
    des2mtn
    Shady Grove
    Tonto cover
    It's been awhile since I did the install, but I want to say yes. Pretty sure you can remove it with a 10mm allen wrench without removing the plate/ ubolts. What I was talking about in a previous reply was ordering a second set and cutting it here or maybe a bit higher to see how it feels offroad.
  26. May 18, 2022 at 1:38 PM
    alb1k
    Left Coast
    It's good
    Those look really good. Especially for a DC
  27. May 18, 2022 at 1:40 PM
    alb1k
    Left Coast
    It's good
    @des2mtn what rear springs are you running?
  28. May 18, 2022 at 1:41 PM
    des2mtn
    Shady Grove
    Tonto cover
    Let's not go there. :pout:
  29. May 18, 2022 at 1:41 PM
    alb1k
    Left Coast
    It's good
    Then they look really good on your DC, or I should say I bet they work great. :)
  30. May 18, 2022 at 1:45 PM
    des2mtn
    Shady Grove
    Tonto cover
    They're the stockers still and they're a bit flat. Both sides have a shit-Tec add-a-leaf with both the ends sheared off. I've barely touched the rear because I've always wanted to do a cantilever setup.
    They still work great, but my rear does sag.
    alb1k[QUOTED] likes this.
