  1. May 4, 2022 at 8:37 PM
    Sunnier
    Sunny
    San Diego, CA
    https://www.indumar.com/products/leak-sealing/stop-it-hp/
    I’m not as certain about this one, but it’s cheap, available at a big box store, and if it works, that will be awesome: https://www.lowes.com/pd/J-B-WELD-WaterWeld-White-Epoxy-Adhesive/3389026
  2. May 4, 2022 at 8:47 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    PTFE tape is clean cheap and easy, and works great on perfect fittings. Purpose specific paste/sealant is generally more reliable IME. What are your fittings? PVC, brass, something else?
    https://rectorseal.com/rectorseal-no-5-pt-cans/. this comes in a little tube for $5.
    If you use it, let it dry for a while (an hour to overnight)
    Sunnier[QUOTED] likes this.
  3. May 4, 2022 at 8:52 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    I have rarely ever had a problem with using the Teflon tape in a water fitting. The few times I did, it as because A-Not enough tape used, B-Fittings were damaged, C-Incompatible fittings, OR I simply did not torque it enough to get a proper seal. Are you using Unions at the in/outs of the pump? Are the O-Rings good??
  4. May 4, 2022 at 8:54 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Haha, this hits close to home. Every single cover plate in my house has the screws aligned.
  5. May 4, 2022 at 8:55 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Even in commercial I put it ground down, unless it's in the specs ground up. And if it's horizontal it's hot(skinny one) down. That switch you changed may have been a 3 way. Did it switch from another spot? Or were the screws on the left when you opened it?
    NUDRAT[QUOTED][OP] likes this.
  6. May 4, 2022 at 8:56 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You're an engineer, you don't count. You make shit difficult just to make shit difficult.
    NUDRAT[OP], GODZILLA, txagg and 5 others like this.
  7. May 4, 2022 at 9:06 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Mountain of virgins baby, a whole damn mountain.
    I spent 5 years pulling fire alarm wire through emt that you box jockeys were in charge of installing.
    That’s enough to make anyone go back to school.
    GODZILLA, chrisb, Sirfive and 4 others like this.
  8. May 4, 2022 at 9:36 PM
    Sunnier
    Sunny
    San Diego, CA
    Rector seal.
    Um. I typed out an entirely different post… but I chickened out. If one of you fellas wants to take this…. My second point was gonna be to clarify that the question posed pertained to a pool, whereas the alternative that may have come to mind would have been more useful in a Jacuzzi… application.
    Darkness and bmf4069 like this.
  9. May 4, 2022 at 9:41 PM
    alb1k
    Left Coast
    It's good
    omg @Sunnier, lol. I'm just getting over realizing what a fleshlight is.
    FrenchToasty, Darkness and bmf4069 like this.
  10. May 4, 2022 at 9:52 PM
    Sunnier
    Sunny
    San Diego, CA
    The top, single most embarrassing thing I have EVER said in my life, was a post I made on this forum. Participating in a conversation that was easy outside my realm of knowledge, and saying I’d be willing to do something… I would not do… that I came to understand had a totally different meaning than why I thought. Mortified. As in embarrassed to Death.
    This was more equivalent to what I might say at a campfire, with a bit of wine on board, now that we all know each other. :rolleyes: Except that usually, someone else will blurt it first. (San G….)
  11. May 4, 2022 at 10:03 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did we change the subject to butt plugs now?
    NUDRAT[OP], 5N0W808 and Darkness like this.
  12. May 4, 2022 at 10:04 PM
    alb1k
    Left Coast
    It's good
    I can only imagine, i've blocked out the mortifying experiences I've created. #lifeskills #checkyourselfbeforeyourectyourself.
    GODZILLA, Darkness and bmf4069 like this.
  13. May 4, 2022 at 10:05 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    FTFY
    GODZILLA, shifty` and alb1k[QUOTED] like this.
  14. May 4, 2022 at 10:14 PM
    alb1k
    Left Coast
    It's good
    Blunt -er. lol
    GODZILLA and bmf4069[QUOTED] like this.
  15. May 4, 2022 at 11:08 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    For those of us that missed it…… let’s hear it huh?
    GODZILLA, 5N0W808 and TheDanimal like this.
  16. May 5, 2022 at 12:12 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    When I was training new guys at the plumbing shop I would tell them to ask our vendors for rectum seal. I could hear them laugh from across the shop.
  17. May 5, 2022 at 12:13 AM
    alb1k
    Left Coast
    It's good
    This might be naive of me, but I'm thinking embarrassed to death means that story won't be told here. Doesn't sound like something for sharing.
    Sunnier and Darkness like this.
  18. May 5, 2022 at 12:28 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You need a pipe dope of some kind. Rector seal works well on PVC. You also need to be sure that the fittings are not damaged. If you torque too hard it is easy to crack the female fitting.
    I generally don't like to use Teflon tape, I never use it on plastic because it slips and can cause leaks. Tape isn't meant to create a seal, it is just to lube the threads so that they don't bind from friction(works well on metal fittings). I've never had plastic to plastic bind unless threads were bad. Guessing you have a schedule 80 nipple, get some Rector seal on there and a pipe wrench or some big boy channel locks and snug it up.
  19. May 5, 2022 at 12:45 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Oh but that ship has sailed my friend. “it was a post made in this forum”. Anyways, I was joking really. I didn’t expect him to repeat it.
    chrisb, alb1k[QUOTED] and Darkness like this.
  20. May 5, 2022 at 5:44 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    This!
    Everyone thinks more tape is a better seal, that’s not how pipe threads work. They are tapered so the threads actually mesh together creating that seal, but like you said lube is needed to get the threads to mesh and seal together!
    I don’t “pipe fit” a lot, I still don’t have the tape application down like the “plumbers” do, but my shit rarely leaks.
    Best trick I learned from this bad ass fitter we use for fire sprinklers; apply the dope first, then wrap it with Teflon……. (Me being me, I had to ask why he did it this way) he basically explained that was how he was taught, and the reason was mainly cleanliness. Dope is super messy and gets all over, so by wrapping Teflon over the dope it makes it less messy when you had off the fitting to the guy with the wrenches. The dope gets squeezed out regardless if it’s on top or below the Teflon once it’s threaded
  21. May 5, 2022 at 6:35 AM
    shifty` We call it “riding the gravy train”
    I mean ... we do know @alb1k is the king of rear plug jewels. :rofl:
    On the topic of leaks, TruBlu or the Oatey blue stuff is typically what I'm using on everything the last decade or so.
    bmf4069[QUOTED] likes this.
  22. May 5, 2022 at 7:36 AM
    alb1k
    Left Coast
    It's good
    Funny timing. I assembled and disassembled my tiny air manifold half a dozen times. Leaked like a sieve. Aluminum, brass and stainless fittings on that thing. Replaced the aluminum block and got some dope. Leaked again but slow. Reassembled again tape over dope 2 days ago. Let it sit an hour, low pressure test, good. Overnight at 60 PSI, good. 160 PSI - good.
    NUDRAT[OP], bmf4069, Sunnier and 2 others like this.
  23. May 5, 2022 at 7:38 AM
    alb1k
    Left Coast
    It's good
    No matter how fast I drive, it's still there.
    bmf4069, Darkness and shifty`[QUOTED] like this.
  24. May 5, 2022 at 8:33 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Okay, I now seriously question my dermatologist’s opinion that I needed a biopsy of what he declared a mole. I was able to pick it off like a scab to reveal either a freckle or mole that’s 1/10 the size it was originally. SMH
    I’d post here but nobody really wants to see my toes on a truck forum. :D
    I’m beginning to wonder if a lot of these derm guys are just trying to make a quick buck.
    bmf4069 and Darkness like this.
  25. May 5, 2022 at 8:35 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    You say that now.
    But we've seen feet from @bmf4069 @Sirfive @Tundra2 and me that I can recall. Lots o' feets.
  26. May 5, 2022 at 8:38 AM
    Jack McCarthy
    Bill
    North of Boston
    The outline around it is how large it was originally.
  27. May 5, 2022 at 8:39 AM
    daveeasa
    David
    I would do a biopsy every time. Risk vs reward. Negative is good news and money spent for peace of mind. Positive could save a life. I dislike most spending on healthcare but pathology and surgery seem like good ways to spend where appropriate. Pathologists are strange people but they know their stuff well beyond the level of the practitioner.
  28. May 5, 2022 at 8:39 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    AAHHHH GROSS.
    A FEET.
  29. May 5, 2022 at 8:39 AM
    Jack McCarthy
    Bill
    North of Boston
    I think on this one I’ll get a 2nd opinion.
    RUSTYNUTS and chrisb like this.
  30. May 5, 2022 at 8:43 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    @Jack McCarthy
    I’d be more concerned about that extension cord abomination.
    CodyP, 5N0W808, GODZILLA and 3 others like this.
