  1. May 3, 2022 at 5:23 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I was about to say im gonna be a weakling when i get home, havent moved rocks in a month, but i did bring grandma some rocks from barnwell mountain.
  2. May 3, 2022 at 5:27 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You can always build yourself a stone patio to get yourself back in shape. I've been meaning to do that myself sometime.
    Darkness, Sirfive[QUOTED] and chrisb like this.
  3. May 3, 2022 at 6:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Shit bitches! Lil victories.
    20220503_071748.jpg 20220503_080709.jpg 20220503_084143.jpg 20220503_084148.jpg
    RUSTYNUTS, KK6PD, NUDRAT[OP] and 15 others like this.
  4. May 3, 2022 at 7:03 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A little heat and that bumper cover will pop back out. Heat gun works well if you have a helper to hold it while you push on the inside. If you don't, park it in the sunshine for a couple hours and that'll work too.
  5. May 3, 2022 at 7:20 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Getting after it!
    Push out that bumper corner and that's a $6k car. (around here anyway)
    RUSTYNUTS likes this.
  6. May 3, 2022 at 7:21 AM
    I was just about to say the same. May not even need heat. This is one of my OCD ticks, when I see dimpled bumpers. I legitimately have to fight the urge to reach around back of the bumper and push it out.
    w666, RUSTYNUTS, NUDRAT[OP] and 3 others like this.
  7. May 3, 2022 at 7:33 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    looks like i bought the wrong size fumoto valve and it is past the return date. bugga
  8. May 3, 2022 at 7:34 AM
    I noticed that recently - I think I bookmarked the one @FirstGenVol posted a while back. Then I went to Fumoto's website and noticed they recommended a totally different one for my '06. I meant to look into whether the older trucks used a different one or not, and what the difference was between the one he listed and the manuf'er lists.
    robabeatle[QUOTED] likes this.
  9. May 3, 2022 at 7:47 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I've been running the 1/2" and 1/4" impact in the driveway a bit off the onboard air. It's pretty awesome. I might have to scrap the under truck water tank idea and double my air capacity with the second tank and get to 10 gal air capacity. I can run water like regular people...lol.
  10. May 3, 2022 at 7:48 AM
    alb1k
    Left Coast
    It's good
    I initially bought the wrong one. Fixed that. I think there is now a higher flow option for toyota.
    EDIT: I have the F133N now. I don't see higher flow on the website.
  11. May 3, 2022 at 8:08 AM
    Jack McCarthy
    Bill
    North of Boston
    For my purposes I need a minimum 5 CFM compressor for my die grinder. The electric handheld doesn't cut it. Also, it's great using a pneumatic impact for tight spaces you can't normally get to with an electric.
    I like IRs and their two-stage units that deliver a noise level of 60-65 dB max.
    alb1k[QUOTED] likes this.
  12. May 3, 2022 at 8:13 AM
    alb1k
    Left Coast
    It's good
    I've looked a lot at 80 gal uprights with high CFM over the years. Never could pull the trigger, but I probably would have long ago if I had a big shop.
  13. May 3, 2022 at 8:25 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I keep contemplating going to Milwaukee just for the battery ratchet. Maybe I should just buy the ratchet and keep my dewalt stuff.
  14. May 3, 2022 at 8:31 AM
    You could also just have a water tank, and use the air as a source to pressurize the water output, or is that dumb/convoluted?
    alb1k[QUOTED] and chrisb like this.
  15. May 3, 2022 at 8:33 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    This guy? It's worked great for me so far.
    alb1k and Jack McCarthy[QUOTED] like this.
  16. May 3, 2022 at 8:35 AM
    alb1k
    Left Coast
    It's good
    No, that's where I've been going in my head. It's the fill and drain that are tough. But, now that I'm doing a rack, I can go conventional, and pressurize on a schrader valve.
    shifty`[QUOTED] likes this.
  17. May 3, 2022 at 8:53 AM
    daveeasa
    David
    Oh so like fill then separate valve, take from air tank to pressurize filled water manually, then compressor refills air tank. Totally independent with the same inflator as your tires? That's cool.
    How come nobody makes a spare tire shape/sized air tank? Seems like a donut would rule for that.
    Good thread here. Looks like cylinders (1-2) is the best way to go.
    https://expeditionportal.com/forum/threads/air-tank-to-replace-spare-tire.111973/
  18. May 3, 2022 at 8:56 AM
    Jack McCarthy
    Bill
    North of Boston
    No, I’ve used the Dewalt corded one. Can you get a wire cup to spin at 20k rpm under load like I can with a compressor? The Dewalt failed for that unfortunately.
  19. May 3, 2022 at 9:01 AM
    Jack McCarthy
    Bill
    North of Boston
    I just called Home Depot since the 10% off deal with their credit card coupon didn’t work so they corrected it. So for $134.10 with battery, charger and soft case you get the high speed ratchet. Seems like a great deal to me. Had I known Home Depot was going to send me 10% off coupons regularly, I would’ve gotten the card a while back.
    CodyP[QUOTED], chrisb and shifty` like this.
  20. May 3, 2022 at 9:12 AM
    daveeasa
    David
    I definitely have a mental bookmark to remember your setup when it's time to work on this project myself.
  21. May 3, 2022 at 9:13 AM
    chrisb likes this.
  22. May 3, 2022 at 9:26 AM
    alb1k
    Left Coast
    It's good
    Well it keeps changing, lol. But I have the plan and parts listed. The more I think about it the more likely I twin tank the air and a water tank low pressure on the rack...
  23. May 3, 2022 at 9:31 AM
    daveeasa
    David
    Yeah, twin air I like, though I also like my spare under the bed. My shell isn't very tall so that's where air tanks in the bed could be OK, as could water, provided the main bed space still fits 4x8 and allows nice sleepage.
    alb1k likes this.
  24. May 3, 2022 at 9:41 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So what's the deal with these ratchets?
  25. May 3, 2022 at 9:49 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    tacoguybill, 5N0W808, KK6PD and 5 others like this.
  26. May 3, 2022 at 10:06 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I've not loaded it with a wire cup just yet. But it'll spin 20000rpm with a roloc bristle disc.
    I'll try to remember to put a wire cup in there and give er a whirl this week and report back.
  27. May 3, 2022 at 10:08 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    20k dont forget your safety squints.
  28. May 3, 2022 at 10:15 AM
    Jack McCarthy
    Bill
    North of Boston
    Thanks, yeah running at 20k does a fantastic job of getting rid of surface rust and cleaning it down to almost bare metal in small spaces prior to prepping it for a rust paint coating like POR-15. You could also try a wire wheel instead if you can't find the wire cup as I generally switch between both based upon what I'm treating.
  29. May 3, 2022 at 10:19 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I did that when I stripped the 911 engine bay last time. MAPP torch and wire wheel in the right angle die grinder.
    I think the compressor was hotter than the torch. It took a beating.
    Jack McCarthy likes this.
  30. May 3, 2022 at 11:27 AM
    Sunnier
    Sunny
    San Diego, CA
    Great work, this!
    alb1k, NUDRAT[OP] and chrisb like this.
