  1. Apr 12, 2022 at 8:46 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You should have said you're allergic to soy and drop on the floor kicking and writhing like you're having convulsions.
  2. Apr 12, 2022 at 8:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Apr 12, 2022 at 8:50 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is that from the Epic Mealtime guys?
    5N0W808 likes this.
  4. Apr 12, 2022 at 8:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Apr 12, 2022 at 8:56 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    No clue. Just memein’.
    txagg, bmf4069 and Darkness like this.
  6. Apr 12, 2022 at 9:10 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    When I was in my 20s I’d host Bacon Parties, it was BYOB……
    I actually had two or three of them
    Darkness[QUOTED] likes this.
  7. Apr 12, 2022 at 9:11 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I showed up to amarillo with beer, bacon, and a vise table.
    5N0W808, NUDRAT[OP], txagg and 2 others like this.
  8. Apr 12, 2022 at 9:13 AM
    FrenchToasty
    Mo
    Bone stock
    Damn, what a guest!
    When we did headers this weekend, me and the other helper pretty much brought all the tools needed for the job, he only had to get out vice grips to help loosen my oil filter
    5N0W808 and Darkness like this.
  9. Apr 12, 2022 at 9:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Apr 12, 2022 at 9:18 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My workbench vices were dads and grandpas, and i’ve had this vise for 5 years or so, and hadnt ever bolted it down. So i bolted it to my old welder cart, and it managed to come in handy for the knuckles. When i got it back home it’s already come in handy several times. I didnt know i needed this in my life.
    5N0W808, bmf4069, chrisb and 2 others like this.
  11. Apr 12, 2022 at 10:52 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Apr 12, 2022 at 12:06 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    F
    I'm telling you it does get better, even if it doesn't seem like it.
    PS - Universe go find someone else to pick on for awhile.
  13. Apr 12, 2022 at 12:14 PM
    You know, depending on how you look at this, it's possible this is a blessing in disguise.
    Finally, the universe gave the tent of pain a taste of its own medicine.
    Alternate take could be the universe is trying to say "fix yourself, not your things".
    Feel free to exchange "universe" with whatever noun you prefer.
  14. Apr 12, 2022 at 12:30 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    This a whole bunch.
    Also this, only slightly less than above.
  15. Apr 12, 2022 at 3:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Turns out that air tank I put under the bed does hold pressure. It sat over night and in the morning I put a hose to the remote quick connect at the bumper and it took a lot of push to get it in. I didn't gauge the tank, but it felt like over 100psi easy. I have a check valve to the tank which means the compressor only feels the line pressure. The line has so little volume in it just back bleed will trick the compressor into switching on and off.
    I had to pull the front wheels to adjust the coilovers, so for fun I grabbed the 1/2 impact and ran it off the tank to remove the lugs. Pretty cool.
  16. Apr 12, 2022 at 3:26 PM
    FrenchToasty
    Mo
    Bone stock
    What was your reasoning for the chikkity check?
    Darkness likes this.
  17. Apr 12, 2022 at 3:30 PM
    alb1k
    Left Coast
    It's good
    My thought was it's probably better for the compressor to not back bleed the whole tank every time I fill it. When I realized the ARB quick connect has a built in check valve it seemed like more evidence. And my hope was that if I wanted air on short notice for say an air horn, it would be in there if I didn't recently drain it.
  18. Apr 12, 2022 at 3:39 PM
    FrenchToasty
    Mo
    Bone stock
    So I don’t even have the arb chuck on mine and my tank never bleeds back, I can come back a month later and the tank is good to go. I’m guessing the pumps must use some sort of reed valve that prevents back pressure thru the compressor
  19. Apr 12, 2022 at 3:45 PM
    alb1k
    Left Coast
    It's good
    That could be. I have a strange setup with two remote fill areas, one after a tank and one on a manifold right next to the compressor. The ARB QC with the check valve in it may just be a fail safe so that you don't drain your tires if you drank too many beers at camp and forget to disconnect your hose. I don't know where I'm losing that line air, but maybe I'll pull the check valve on the tank and fill it and let it sit overnight. Soapy water hasn't shown me any leaks so far.
    chrisb and FrenchToasty[QUOTED] like this.
  20. Apr 12, 2022 at 3:49 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    i think you need an electric valve that opens an airline into a whoopee cushion. With onboard air comes great responsibility, and being able to make your truck make fart noises.
    chrisb and bmf4069 like this.
  21. Apr 12, 2022 at 4:08 PM
    alb1k
    Left Coast
    It's good
    I can jump scare the passenger by switching the compressor on since they are sitting on top of it. But farts...
    Leo's first, chrisb and Darkness like this.
  22. Apr 12, 2022 at 4:12 PM
    alb1k
    Left Coast
    It's good
    I may have over built/complicated the thing. I'm going to pull both check valves and try that. Since I can isolate the manifold from the tank or open it all up with a manual valve, that will give me either tank, or if attached, tire pressure with the same gauge...
  23. Apr 12, 2022 at 4:17 PM
    alb1k
    Left Coast
    It's good
    @NUDRAT started this thread in Jan 2020... Looks like it will have 1M views before the end of this year.
    Leo's first likes this.
  24. Apr 12, 2022 at 4:22 PM
    FrenchToasty
    Mo
    Bone stock
    Where are you able to see total views? It was actually a mod that started this thread I believe(but nudrat may have requested it)
    I love coming and seeing how many active views it’s getting, puts turd gens to shame
  25. Apr 12, 2022 at 4:23 PM
    alb1k
    Left Coast
    It's good
    On the home page there are stats by the recent threads.
    FrenchToasty likes this.
  26. Apr 12, 2022 at 4:26 PM
    FrenchToasty
    Mo
    Bone stock
    Turning my phone sideways, gets me again!
    bmf4069 and Sirfive like this.
  27. Apr 12, 2022 at 4:27 PM
    alb1k
    Left Coast
    It's good
    bmf4069 and FrenchToasty[QUOTED] like this.
  28. Apr 12, 2022 at 4:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    So he wouldn't get rikkity wrecked of course
    Leo's first, chrisb, bmf4069 and 2 others like this.
  29. Apr 12, 2022 at 4:35 PM
    FrenchToasty
    Mo
    Bone stock
    alb1k[QUOTED] likes this.
  30. Apr 12, 2022 at 4:36 PM
    alb1k
    Left Coast
    It's good
    I don't know what's going on in that gif but I think I'm good.
