  1. Apr 2, 2022 at 3:39 PM
    She’s home again! Missed her so much. NOT FOR SALE. I’ll take $54k for the one one the left though……
    5N0W808, chrisb, sn_85 and 8 others like this.
  2. Apr 2, 2022 at 7:09 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    anyone have photos of the center console vents in a access cab? im curious how the right side is attached. (yes my center console will have rear heat for the non existent back seat area)
  3. Apr 2, 2022 at 8:50 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Below/inside the console?
  4. Apr 2, 2022 at 8:50 PM
    empty_lord
    05 rollover special
    yea. ive got the driver side piece that allows it to attach. cant tell how the passenger side attached unless it goes where my vent just dumps.
  5. Apr 2, 2022 at 8:51 PM
    daveeasa
    David
    Are you going to tell us why? Why heat the rear cab?
  6. Apr 2, 2022 at 8:58 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Scrolled through my tundra pics but I never grabbed any when I was routing wiring to bypass the amp.
    If no one beats me to it, I'll try and grab some tomorrow or Monday.
    Perforated seats would be neat. Turn them into warmers/coolers.
    I tend to leave my vents settings at defrost & foot during cooler months. It'd probably help with keeping the seat/rear of the cab comfortable in colder weather, without blasting you directly with hit air.
  7. Apr 2, 2022 at 8:59 PM
    empty_lord
    05 rollover special
    only because it keeps my floor vents functional properly with the vents. otherwise the heat all will go under the console. the stock setup is blocked by the console now.
  8. Apr 2, 2022 at 9:00 PM
    empty_lord
    05 rollover special
    it likely will help spread heat out better in the winter is my hope. but its really just so i can keep the floor vents working right
  9. Apr 2, 2022 at 9:09 PM
    daveeasa
    David
    I like the idea of a vent extension (noogle?) for heated / cooled seats.
  10. Apr 2, 2022 at 9:20 PM
    empty_lord
    05 rollover special
    it could be done.. i wouldnt do heat.. but cooled is doable if you get creative
  11. Apr 2, 2022 at 9:36 PM
    daveeasa
    David
    Anyone contemplate yanking both airbags for good? I assume there is some way to neuter the entire airbag system? Pull a fuse perhaps?
    Then no concerns about accidental discharge while wheeling? But greater risk of injury or death? And wouldn’t be legal to sell?
  12. Apr 2, 2022 at 9:37 PM
    empty_lord
    05 rollover special
    our trucks dont have the same sensors as newer trucks.. you dont need to worry as much about them going off.
    daveeasa[QUOTED] likes this.
  13. Apr 2, 2022 at 9:40 PM
    daveeasa
    David
    Is there an age at which time it’s important to get it repacked or something? Like a parachute?
  14. Apr 2, 2022 at 9:43 PM
    empty_lord
    05 rollover special
    Technically airbags are suppose to be replaced every 10 years.... but meh
    NUDRAT[OP] likes this.
  15. Apr 3, 2022 at 12:19 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    F84B1E54-957D-403C-ACC9-CB74D5F12853.jpg Not sure if that captured what you’re after or not
  16. Apr 3, 2022 at 12:31 AM
    empty_lord
    05 rollover special
    na, the ones that go under the center console. just me being curious.. mine havent come in yet.
    appreciate it though
  17. Apr 3, 2022 at 7:45 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    @daveeasa There's the RSCA off button to turn off the side curtain bags. So when you wheel at extreme angles if the truck thinks it's rolling over it doesn't deploy the side curtains. I'm not sure if that also turns off the front bags. Don't know what year the side curtains/RSCA system started.
    But there is a system in the trucks, so you should be able to create an on/off switch.
  18. Apr 3, 2022 at 8:00 AM
    You take care of you, shithead! :rofl: You know folks here got your back if you need it, you just gotta say the word.
    But one request, with zero intent to guilt: At least reply to one of us to let us know you're alive next time, even if you just K.I.S.S with "just dealing with some personal stuff". Even if you don't want to say anything, just a logged-in session here on the forum so folks can see you were here would probably suffice. I'll say no more on it.
    I'm happy to see you made it into your 20s before you had a shit b-day. My first was at age 11. And I've pretty much hated/avoided birthdays ever since. The one time I thought, "Ah, I'm being stupid" I opened the door to another the year following. Birthdays are shit.
    chrisb, RUSTYNUTS and FrenchToasty like this.
  19. Apr 3, 2022 at 8:19 AM
    daveeasa
    David
    Yeah I bought a used switch panel with the RSCA button but it doesn’t fit mine, nor is there any harness to connect to. Pretty sure my 2002 doesn’t have side curtain airbags but Dan might correct me on that. I’ve had the A pillar off recently for the scangauge and I don’t remember seeing them.
  20. Apr 3, 2022 at 9:17 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I had a Great Uncle (long passed) used to change the filter on a regular basis, but only changed the oil once every couple of years. He'd just change the filter and top up the oil. He was a farmer and rancher and actually wore out pickups, but I never heard of him having engine problems.
    RUSTYNUTS and Darkness like this.
  21. Apr 3, 2022 at 9:20 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Interesting. Gotta be a quick and messy change though
  22. Apr 3, 2022 at 9:43 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Probably not much worse than a normal change. Most of the oil ends up back in the pan after shutdown.
    Darkness likes this.
  23. Apr 3, 2022 at 9:48 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    In the spirit of #ironman #mangleopolis and #panhandlemonium, I’m going to try to mount this in a spot with no room for wrenches this morning…
    chrisb, txagg, RUSTYNUTS and 2 others like this.
  24. Apr 3, 2022 at 9:50 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hopefully you’ve been doing your finger yoga!
  25. Apr 3, 2022 at 9:52 AM
    alb1k
    Left Coast
    It's good
    I was yoga fingering all night. I'm ready, or not.
  26. Apr 3, 2022 at 9:54 AM
    Tried to drive the 2000 Tundra to the airport this morning for a work trip. Just got it back from my son who used it for 4x4 winter duty. Made it 1/2 a block before the incredibly loud Wawa sounds from the front end overpowered my senses. The front bearing(s) are definitely shot now. Turned around and parked it. Took the 19 instead. Looks like I’ve got a more immediate project to add onto the front bumper replacement. Hopefully I can find a local shop to do the press work. I’ll pull the spindles and take them in. Might as well replace the ball joints while I’m in there. My not Toyota ball joints don’t give me the good feels.
    chrisb, txagg, RUSTYNUTS and 4 others like this.
  27. Apr 3, 2022 at 11:23 AM
    alb1k
    Left Coast
    It's good
    These are smaller in person than specs look like. Still, may be awesome.
  28. Apr 3, 2022 at 11:30 AM
    NUDRAT
    SW CT
    Oh - wait, don't you have the key off passenger airbag switch? I think all the airbag vehicles with no back seat have them & most all pickup trucks.
    Surely that can be replicated on the driver side.
  29. Apr 3, 2022 at 12:14 PM
    alb1k
    Left Coast
    It's good
    I don’t think I should put this here.
    chrisb, des2mtn, Darkness and 3 others like this.
  30. Apr 3, 2022 at 12:30 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Just put a biological hazard sticker on it and you’ll be fine; nobody will take it.
    Darkness, alb1k[QUOTED] and KK6PD like this.
