  1. Mar 28, 2022 at 1:33 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    wEiRd.
    I tHOuGhT yOu WeRe dOiNg gReAt. :D
    Darkness and des2mtn[QUOTED] like this.
  2. Mar 28, 2022 at 1:47 PM
    Sunnier
    Sunny
    San Diego, CA
    Darkness likes this.
  3. Mar 28, 2022 at 2:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought that too but I read 6 years on Tundra Solutions. Weird.
    Dude I'm the Mangler. I have zero desire to attempt the timing belt job. A few years ago I broke the rear wiper arm on the Rav4. Last week I finally got a new one from Toyota and broke it in the same exact spot while trying to install it. Terrible design but I stayed true to my name. I'll happily fork out the $1000 on this job.
    https://youtu.be/CG2cux_6Rcw
    chrisb, alb1k, Darkness and 4 others like this.
  4. Mar 28, 2022 at 2:12 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Good to know, maybe something weird with mine. This was on the rehabbed Sequoia so could have been other issues also. When I replaced the cam bolts, the boots on both inner tie rods were torn and one the passenger outer tie rod was pretty floppy so maybe that was the problem and not the cam bolts. I replaced the boots, and both inner and outer tie rods at the same time so that could be why it drives much better.
    The firestone guy said he couldn't get the SPC bolts torqued, but he must have been using a ridiculous torque because when I removed them I had to stand on the wrench to loosen them.
    Darkness[QUOTED] likes this.
  5. Mar 28, 2022 at 2:13 PM
    rock climber
    How much tighter is the turning radius?. That's my only complaint with my DC is turning radius. The sequoia is so much easier to park.
  6. Mar 28, 2022 at 2:34 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I can’t say for sure. There’s an intersection at the end of my street I u-turn in all the time. Normally I go as wide as I can and still come close or hop the last sidewalk corner. I did it today and it was a pretty easy clear all around. I did set up wide like normal but that last corner wasn’t even a chance of running into.
  7. Mar 28, 2022 at 2:39 PM
    daveeasa
    David
    This is honestly what I was most hoping for out of that $1k spend.
    My biggest complaint on the Tundra is turn radius.
    I also pinged Billy @ BFF on front bumper as I'm wondering if the stock one might rub on the wheels with the solos...
  8. Mar 28, 2022 at 2:40 PM
    rock climber
    I think it's time to for me drop $5k on the DC!
    OME shocks, Jba UCA, Solo LCA (other stuff I don't need but really want)
  9. Mar 28, 2022 at 2:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    350 is more than enough to embarrass enough people.
    alb1k, Darkness and 5N0W808 like this.
  10. Mar 28, 2022 at 3:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That should be a youtube channel. Just get some of us working on trucks and let Empty narrate it. He could do something like this.
    Could be, but when I looked at the spc kit I had some doubts of it holding well. They do need to get He-Man mega tight, I noticed the tabs that they pass through bending slightly as I torqued them. I think the stupid plastic sleeves they use is the weak point, if they aren't cut to exact length it might be bad. I wish they spent a few more pennies on brass sleeves.
    I've been embarrassing people with far less. 350 would be a lot of fun. I think thats plenty for a car that light.
    bmf4069[QUOTED] and alb1k like this.
  11. Mar 28, 2022 at 3:32 PM
    empty_lord
    05 rollover special
    2600lbs is the guess as of now. We’ll see what the total ends up being and how the distribution is. This engine typically leads to being closer to a 50/50 split
    chrisb and alb1k like this.
  12. Mar 28, 2022 at 3:36 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think my GTI is about 2800lbs and runs roughly 220 horses, even with the really long gears it flies. Your car is gonna rip hard if you're in the 300 horse range. Just be careful with the snap oversteer.
    chrisb, bmf4069, alb1k and 1 other person like this.
  13. Mar 28, 2022 at 3:44 PM
    alb1k
    Left Coast
    It's good
    Here’s a soon to be working fill station. I need to change up that outboard valve, it’s too proud.
    chrisb, 5N0W808, bmf4069 and 3 others like this.
  14. Mar 28, 2022 at 3:49 PM
    daveeasa
    David
    Better start dieting now, @empty_lord, you don't want to add an extra percent or two to your MR2's weight :)
    Darkness, bmf4069, empty_lord and 2 others like this.
  15. Mar 28, 2022 at 3:51 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I need to run across some scales, cause i’ve got no clue what it weighs.
  16. Mar 28, 2022 at 3:52 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    the buell is so much better after a healthy BM.
    chrisb, txagg, bmf4069 and 1 other person like this.
  17. Mar 28, 2022 at 4:01 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    These bad boys came in today, pretty stoked to not need a steel plate under my HF stands so they don’t sink in the gravelDF3200F4-7B0A-4ABD-AD20-BAFA2DA6D081.jpg
    chrisb, des2mtn, Siebler and 6 others like this.
  18. Mar 28, 2022 at 4:04 PM
    alb1k
    Left Coast
    It's good
    I really should have locked a turn and measured the diameter before swapping. The lack of stops and the turning radius weren’t really a concern of mine. But, muscle memory is funny. Today I cranked a turn for a back into a spot and the wheel kept turning after my brain said it would stop. It can’t be a huge difference but it’s there. I did notice on the Moogs I pulled off the stops were clean and some other part of the arm was the limiter.
    rock climber likes this.
  19. Mar 28, 2022 at 4:09 PM
    daveeasa
    David
    My pavement princess haole FGT is excited about her new abilities waiting once the solo box is unpacked.
    So, to summarize, your install was awesome and an alignment after was the only piece needed? So I should do the same?
    rock climber and chrisb like this.
  20. Mar 28, 2022 at 4:18 PM
    empty_lord
    05 rollover special
    Oh I know that sensation all too well.
    chrisb and Darkness[QUOTED] like this.
  21. Mar 28, 2022 at 4:27 PM
    Casper421
    In the woods
    06 DC
    I wonder if I’ll still need to tub the firewall for 35’s if I go with solo lca’s? :monocle:
  22. Mar 28, 2022 at 4:42 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, cabin air filter was past due.
    At least there was no rat poop.
    des2mtn, 5N0W808 and bmf4069 like this.
  23. Mar 28, 2022 at 4:43 PM
    FrenchToasty
    Mo
    Bone stock
    Do you paint the new one black before you put it in? Faster air flow?
    chrisb, 5N0W808, bmf4069 and 5 others like this.
  24. Mar 28, 2022 at 5:06 PM
    empty_lord
    05 rollover special
    It would be a lot less for shre
    chrisb and Casper421[QUOTED] like this.
  25. Mar 28, 2022 at 5:18 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No maaaaan don't be silly. Paint would clog it up faster. Black paint has a lot of good places to be but not in an air filter.
    I use black dye. :D
    Sunnier, bmf4069, NUDRAT[OP] and 3 others like this.
  26. Mar 28, 2022 at 5:38 PM
    alb1k
    Left Coast
    It's good
    Yes. I still haven’t measured the height in the front, but it looks the same after alignment. Obviously I haven’t run it much, but it feels good.
  27. Mar 28, 2022 at 5:47 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    i think we need a where's Noah survey.
    My vote is bail's too high & we need a fundraiser.
    chrisb, KK6PD, des2mtn and 5 others like this.
  28. Mar 28, 2022 at 5:48 PM
    FrenchToasty
    Mo
    Bone stock
    I vote; the Sasquatch got him, or he’s hanging out with Heather….
    chrisb and Darkness like this.
  29. Mar 28, 2022 at 5:48 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    He’s loading animals?
    chrisb, Darkness and 5N0W808 like this.
  30. Mar 28, 2022 at 5:49 PM
    NUDRAT
    SW CT
    OH! Did anyone check the 'on vacation' thread?
