1st Gen Key Fob Programming
Discussion in '1st Gen Tundras (2000-2006)' started by Off Tarmac, May 1, 2022.
  1. May 1, 2022 at 9:29 AM
    Off Tarmac
    Off Tarmac [OP] Semi-Amateur Mechanic
    Boulder County, ColoRADo
    2002 Thunder Gray Metallic Tundra TRD
    Bilstein 5100’s with leveling lift, 2021 Tacoma TRD Rims, JDM interior/exterior LED’s, Nakamichi Apple CarPlay receiver, Alpine speakers, Access Tonneau Cover, KSP 1 1/4” wheel spacers, Borla exhaust, Line-X spray-on bed liner, WeatherTech floor mats and bug shield.
    Hi All, I have been researching replacement key fob programming for my 2002 AC with the RS3000 factory installed keyless entry module. I have one original key fob with FCC ID BAB237131-022. This helped me identify the factory keyless system.
    The main reason for this odyssey was the original fob only functioned within 5-10 feet from the door. No good. I did try the recommendation of placing the fob next to my jaw. It actually worked, but not a solid resolution. I upgraded to new fobs and the range is better than 50 feet!
    Here are a couple of sites that helped streamline the process for me:
    Replacement fobs, $73 delivered for the pair:
    https://www.remotesremotes.com/Key-Fob-Keyless-Entry-Remote-for-2002-Toyota-Tundra-s/6175.htm
    Simple instructions for programming this new fobs-30-minute install:
    https://youtu.be/XjcBbyZVcZg
    Hope this helps
    bmf4069 and FrenchToasty like this.
  2. May 1, 2022 at 9:33 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I hoped you replaced the battery before you made this decision. My range was about 10 ft before I replaced it with an energizer battery and now it’s back to its old range of 30-40 ft.
  3. May 1, 2022 at 10:20 AM
    Off Tarmac
    Yessir! Battery replacement was actually the first step for me. Unfortunately, the range did not improve.
    Jack McCarthy likes this.
  4. May 1, 2022 at 12:25 PM
    bmf4069 and Off Tarmac[OP] like this.
