1st Gen General Questions
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Nov 21, 2018.
  1. May 19, 2019 at 6:58 PM
    #151
    Casper421
    In the woods
    06 DC
    A molle rack lining the rear ceiling using the grab handles as mounts. Similar to this:
    KarmaKannon, TX-TRD1stGEN and Sunnier like this.
  2. May 19, 2019 at 7:14 PM
    #152
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    add some side streets that run back to those hanging hooks over the back window.
    Sunnier and Casper421[QUOTED] like this.
  3. May 19, 2019 at 8:02 PM
    #153
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    That's a cool idea. How can I help?
    Casper421[QUOTED] likes this.
  4. May 19, 2019 at 8:05 PM
    #154
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    How are the grab handles attached? Can you remove them and screw in that way? If so you could really make a solid mount.
  5. May 19, 2019 at 8:11 PM
    #155
    Casper421
    In the woods
    06 DC
    Once I make a prototype for my dc, i want to test fit on your ac. I don’t even know where the rear grab handles are in an ac. They might not match up at all.
  6. May 19, 2019 at 8:12 PM
    #156
    Casper421
    In the woods
    06 DC
    That’s the plan.
  7. May 19, 2019 at 8:27 PM
    #157
    Sunnier
    Sunny
    San Diego, CA
    :spy: This is one of those times I wish I lived nearer. The Hulk really likes to help with stuff like this.
  8. May 19, 2019 at 9:42 PM
    #158
    Mike Tread lightly.
    south carolina
    Hell I would like one in my access cab and my FJ cruiser...
  9. May 19, 2019 at 11:10 PM
    #159
    FlightSimGuy
    If you figure it out I would definitely be interested in one.
  10. May 20, 2019 at 2:40 PM
    #160
    Brown Bear
    Nor cal
    03 TRD offroad
    Yeah no problem. That would be sweet. Just let me know when and we can meet up for you to measure whatever you need. I actually might be moving to your neck of the woods in the next month or so.
  11. Jun 28, 2019 at 9:55 AM
    #161
    FlightSimGuy
    Any ideas on how to find an exhaust leak?
  12. Jun 28, 2019 at 10:15 AM
    #162
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Ahhh take it off, u don't need it :benchpress:
    I have heard seafoam would work
  13. Jun 28, 2019 at 10:28 AM
    #163
    Professional Hand Model
    Hand Protectors
    Start checking the obvious areas like where the flanges bolt up. Mine had some corrosion that I addressed with two-part epoxy. Also had a side wall blow out that I patched with aluminum and said epoxy on the muffler. Holding well and that little leak spitting sound is gone.
  14. Jun 28, 2019 at 10:30 AM
    #164
    FlightSimGuy
    Haha! I actually run Seafoam every 4-5 tanks of gas.
    Thanks! I'll start there.
  15. Jun 28, 2019 at 12:52 PM
    #165
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    FlightSimGuy[OP] likes this.
  16. Jun 28, 2019 at 1:06 PM
    #166
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Where'd you get them?
  17. Jun 28, 2019 at 1:44 PM
    #167
    Hooptytrix
    Dirty South
    eBay of course
  18. Jun 28, 2019 at 3:24 PM
    #168
    Outbound
    Aaron
    Northern Alberta
    So even though I should probably save the money, my headlights are badly in need of replacing. The main housings are fogged right up and corner housings are full of moisture.
    RockAuto has OEM style replacements, but by the time I have all I need I'm looking at near $400. I came across these on Ebay. I think the black will add a neat look to my truck and they're way cheaper. I'm also planning on adding Beamtech LED bulbs for the headlights and I'll stick LED in the marker lights. I want to avoid hyper flash so I think I'll avoid LED for the turn signals unless someone has a good option for those.
    What are your thoughts on my plans?
    https://www.ebay.ca/itm/Headlights-...ash=item41bc4ba413:g:nYIAAOSw2NBbSBc2&vxp=mtr
    https://www.amazon.ca/dp/B073ZD9ZPX...olid=2DMDH1EHWK0EX&psc=1&ref_=lv_ov_lig_dp_it
  19. Jun 28, 2019 at 3:29 PM
    #169
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think those smoked lenses would look great. I'd go for it.
  20. Jun 28, 2019 at 3:31 PM
    #170
    Hand Protectors
    Housings look good. Our models differ in the headlights, so can’t vouch there.
    Why not try Katanas LED bulbs? For your turn signals, just buy brand new incandescents (cheap) with the amber coating. New incandescents coils will put out much brighter light. The amber coatings were flaking off of mine.
    Outbound[QUOTED] likes this.
  21. Jun 28, 2019 at 3:44 PM
    #171
    Outbound
    Aaron
    Northern Alberta
    The Katanas were my first choice. Unfortunately, they don't seem to be available on Amazon Canada or elsewhere in Canada. I think I need H4 (9003) hi/lo for my application if I'm not mistaken. These are the ones that come up on Amazon for me.
    https://www.amazon.ca/KATANA-Headli...ds=katana+led&qid=1561761659&s=gateway&sr=8-5
  22. Jun 28, 2019 at 4:03 PM
    #172
    Hand Protectors
  23. Jun 28, 2019 at 4:43 PM
    #173
    Outbound
    Aaron
    Northern Alberta
    Sunnier likes this.
  24. Jun 28, 2019 at 5:04 PM
    #174
    Hand Protectors
  25. Jun 28, 2019 at 5:05 PM
    #175
    Outbound
    Aaron
    Northern Alberta
    Awesome. I just placed the order for the housings as well. Total for housings and bulbs came to about $300 and change when converted to Canuckistani pesos. Not bad, certainly cheaper than OEM.
  26. Jun 28, 2019 at 5:16 PM
    #176
    Hand Protectors
    Different housings on the 2002 were about $115USD.
    The Katanas about $49USD.
    Total $165USD.
  27. Jun 28, 2019 at 5:39 PM
    #177
    Hooptytrix
    Dirty South
    I purchased those headlights for my 2001 & 2005. They look really good. On my 01 no issues what so ever, 05 the side lenses are fogging up.
    As for the bulbs, I have a similar set on my 05. The little notch below the led does a great job of keeping low beam to top of lense. Not as bright as other styles but definitely an upgrade from the halogen bulbs.
    Outbound likes this.
  28. Jun 29, 2019 at 10:06 AM
    #178
    FlightSimGuy
    Hooptytrix likes this.
  29. Jun 29, 2019 at 10:15 AM
    #179
    Hooptytrix
    Dirty South
    That damn nut is a bitch to get off. Air compressor and a quality impact gun will make life easier. Don't forget the beer, you're gonna need at least 4
  30. Jun 29, 2019 at 10:17 AM
    #180
    FlightSimGuy
    Ok. Do you happen to know the size of that nut?
    I'll make sure the cooler is full. :D
