1st Gen General Questions
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Nov 21, 2018.
  1. Feb 23, 2019 at 6:15 AM
    #91
    Aerindel
    Aerindel New Member
    Montana
    Wow....that sounds really strange....why would it work for a few days and then stop? I will have to see what happens with mine.
  2. Feb 23, 2019 at 6:16 AM
    #92
    Professional Hand Model
    Hand Protectors
    Were you able to pull any of the big relays out? The ones with the little strap around the top of them?
  3. Feb 23, 2019 at 6:17 AM
    #93
    Hand Protectors
    Maybe the computer senses something.
  4. Feb 23, 2019 at 6:18 AM
    #94
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Don't know the answer to that. I know I took pictures of what wires I had to modify .I'll check my old phone
    Aerindel[QUOTED] likes this.
  5. Feb 23, 2019 at 6:20 AM
    #95
    Aerindel
    Aerindel New Member
    Montana
    I didn't try.
  6. Feb 23, 2019 at 6:21 AM
    #96
    Aerindel
    Aerindel New Member
    Montana
    That would be useful. I have to kill them one way or another.
  7. Feb 23, 2019 at 6:23 AM
    #97
    Hand Protectors
    Let us know if you try and are successful. I’ve asked this question many times even in the ‘General’ section and no answer. Did some internet searches and nothing. Even inquired about a ‘Relay Puller’, as it seems to require a special tool to depress the tabs while pulling simultaneously, but nothing.
  8. Feb 23, 2019 at 6:26 AM
    #98
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah it's a lot of work. But once you do it right and get a good base layer of protection you shouldn't have to do it again. It's worth it.
  9. Feb 23, 2019 at 6:26 AM
    #99
    Hand Protectors
    I believe it is required by law to have DTR lights in most states if vehicle was manufactured past a certain date. Check your local laws.
  10. Feb 23, 2019 at 6:28 AM
    #100
    Hand Protectors
    That clay bar step is the real deal for a top notch detail.
    Outbound likes this.
  11. Feb 23, 2019 at 6:39 AM
    #101
    Aerindel
    Aerindel New Member
    Montana
    Not here.
  12. Feb 23, 2019 at 6:41 AM
    #102
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Here is the pics from disabling the dtrl on my 2000 . This is the main dtrl relay. Located in the center of cab under the ash tray . Disconnected the black wire with yellow stripe and taped it back.
    Aerindel likes this.
  13. May 2, 2019 at 11:25 AM
    #103
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    What would be a good way to protect these? The previous owner had them running to the bed for lights, which I don't have atm. I'd like to keep them so I can add lights later so I'm just going to zip tie them under the truck. Should I just wire nuts the ends and wrap in electrical tape or is there a better way?
  14. May 2, 2019 at 12:07 PM
    #104
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Heat shrink. Then ziptie em up outta the way.
    FlightSimGuy[OP] likes this.
  15. May 2, 2019 at 12:08 PM
    #105
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Wait a sec, is that 12/2 UF cable?
  16. May 2, 2019 at 12:10 PM
    #106
    FlightSimGuy
    :facepalm:Didn't think of that. And I have a bunch in my airsoft kit.
  17. May 2, 2019 at 12:10 PM
    #107
    FlightSimGuy
    Not sure, I'll check.
  18. May 2, 2019 at 12:11 PM
    #108
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    That's what it looks like! :rofl:
  19. May 2, 2019 at 4:30 PM
    #109
    FlightSimGuy
    Yep, that's what it is. Should I just rip it out and go with something else when I add lights?
  20. May 2, 2019 at 4:59 PM
    #110
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I mean there's worse choices but way overkill and had to have been a bitch to work with.
    I'm assuming you'd run LEDs so 14 gauge would be more than enough. I prefer adhesive lined butt connectors, easy to use and weather proof.
  21. May 2, 2019 at 5:05 PM
    #111
    Hand Protectors
    If its already run and you still want to keep it, then snip the bare copper off to the jacket and wrap some electrical tape around the tip. You’ll end up cutting back on the other side of that connector and installing a new connector when you do your future work.
    Or, just rip it all out back and start fresh in the future.
  22. May 2, 2019 at 6:27 PM
    #112
    FlightSimGuy
    I might just take it all out. I thought it strange that they used 12-2 (didn't know it was UF, I'm used to the yellow stuff).
  23. May 2, 2019 at 9:56 PM
    #113
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    UF is direct burial cable. NM(yellow) is regular romex. If you wanted you could pull it out and just do a stranded 14 cable assy and sleeve it in wire loom for a cleaner install.
    FlightSimGuy[OP] and NUDRAT like this.
  24. May 6, 2019 at 11:24 AM
    #114
    FlightSimGuy
  25. May 6, 2019 at 11:51 AM
    #115
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can only answer part of your question but the general consensus here is to only order OEM CV's. The aftermarket ones don't last. Did you end up lifting your truck? If so, you may want to consider doing something about the angle of the CV axle. CVJ is one option. https://www.cvjreman.com/product-tag/9550/
    Another is just replacing the boot with a high angle offering from ORS. https://www.offroadsolutions.com/products/high-angle-inner-cv-boot/
    I'm curious about the install as well as I'll likely have to do something to mine after I lift it. Hopefully someone else will chime in.
    CodyP likes this.
  26. May 6, 2019 at 12:42 PM
    #116
    Festerw
    Festerw New Member
    04 Tundra DC
    My 2 cents, if you've never touched it replace the whole axle. It's about the same amount of work to replace just the boot.
  27. May 6, 2019 at 12:52 PM
    #117
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My shop said the same thing. But if he has a lifted truck he may want to consider one of those 2 options I linked or the boot may tear again.
    How difficult is it to remove and replace one of these on our trucks?
  28. May 6, 2019 at 1:08 PM
    #118
    Festerw
    Festerw New Member
    04 Tundra DC
    There is somebody I believe that has the shafts with the high angle boots already installed. Escapes me who it is now.
    I've never changed one on my truck but from looking I can't imagine it taking more than 2 hours from the time you wheel the jack out.
  29. May 6, 2019 at 1:13 PM
    #119
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes, it's in the link I posted above.
  30. May 6, 2019 at 1:19 PM
    #120
    Festerw
    Festerw New Member
    04 Tundra DC
