1st Gen Exhaust
Discussion in '1st Gen Tundras (2000-2006)' started by f-edtruckgotmemessedup00, Feb 26, 2024.
  1. Feb 28, 2024 at 9:27 AM
    #61
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Nah dog, put that cherry bomb, buzz bomb whatever the fuck fart cans are called muffler you got on a V6 and make all the Honda bois jelly
    Dirt Ferguson likes this.
  2. Feb 28, 2024 at 9:59 AM
    #62
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    yea, manifolds. Heat cycled bolts arent gonna give up easy without breaking. Lots of penetrating oil, and every extractor you can imagine. I dont know how much rust maine gets, but its a job i'd expect to take longer than expected.
    455h0le_dachshund likes this.
  3. Feb 28, 2024 at 10:04 AM
    #63
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    JBA short tube headers, Magnaflow cats, JBA Y-pipe, JBA catback.
  4. Feb 28, 2024 at 10:22 AM
    #64
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    This
  5. Feb 28, 2024 at 10:29 AM
    #65
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Who told you that?
  6. Feb 28, 2024 at 10:29 AM
    #66
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    When you run your straight midpipes, do you stack two spacers per rear O2 sensor or use an elbow?
  7. Feb 28, 2024 at 10:31 AM
    #67
    FrenchToasty
    Mo
    Bone stock
    It still throws a code, haven’t found a solution for that
  8. Feb 28, 2024 at 10:39 AM
    #68
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    The owner of the muffler shop that installed LTs on my 2wd one week and my 4wd the next, said he'd never do another LT install on a 4wd FGT :rofl:
    FishNinja likes this.
  9. Feb 28, 2024 at 10:41 AM
    #69
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So have you tried spacers already?
    I wish current EPA standards hadn't killed the URD o2 simulators. Gadget told me he had to quit selling em because the EPA cracked down on him.
  10. Feb 28, 2024 at 11:14 AM
    #70
    FrenchToasty
    Mo
    Bone stock
    Yeah I even tried the mini cat spacers and still get the CEL
  11. Feb 28, 2024 at 12:45 PM
    #71
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    that reminds me of when my cats got stolen. I fought the bolts that mount to the heads for about a full day.
    here are some tips: get engine hot. Penetrating fluid on the tops and bottoms of the bolts. Let it cool for like 15min. Penetrating fluid again. 6 sided long socket. Breaker bar.
    Do not try to use an impact, or dare even look in the direction of a 12 sided socket. It will be the end of you.
  12. Feb 28, 2024 at 3:08 PM
    #72
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Hi temp antiseize and copper or brass nuts.
  13. Mar 1, 2024 at 5:15 AM
    #73
    tvpierce
    tvpierce Formerly New Member
    Maine
  14. Mar 1, 2024 at 5:38 AM
    #74
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've heard mixing acetone and ATF works pretty good, but I have not tried it. I don't live in a rusty area, unless it floods.
  15. Mar 1, 2024 at 7:01 AM
    #75
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    A torch worked really well on most of JPink's severely rusted bed bolts. He came over two nights ago and welded a nut to the last one. Ripped it out with his Milwaukee.
  16. Mar 1, 2024 at 7:22 AM
    #76
    FishNinja
    Lee
    06DC2wd
    honeatly. If I saw that. I’d just replace everything that kind of rust gives me anxiety
  17. Mar 1, 2024 at 7:41 AM
    #77
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Was it because of front driveshaft clearance issues?
  18. Mar 1, 2024 at 7:44 AM
    #78
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Something like that. He didn't specify which components of the 4wd made it such a PITA.
  19. Mar 1, 2024 at 7:50 AM
    #79
    FishNinja
    Lee
    06DC2wd
    it probably because it was the entire 4wd system
  20. Mar 2, 2024 at 2:37 AM
    #80
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Whenever i get a free 5 days im just unbolting mounts and lifting whole engine. From everything i have read, it will take equally as long and this will way will probably reduce risk of minny stroke. Also buying a few extra studs. Then ear plugs on off to my favorite baltimore city exhaust shop. Buy materials, 30 pack of domestic beer of their choosing and they will make a perfect exhaust. Plus a $100. Biggest hurdle is mid-pipes, x pipe. Then dumping after rear axle. Prob wont happen until 2025. But ill spend money and dyno it for you guys.
  21. Mar 2, 2024 at 11:49 AM
    #81
    whodatschrome
    lots of dents
    I’d probably try to unbolt the manifolds before yanking the entire engine. Yes the engine comes out of the bay fairly easily, there’s a waterfall of other smaller things that get to be a pain...namely removing and installing the transmission. Even if you snap off a few studs (when the engine is still in place), once the manifolds are removed you will then have a lot more room for extracting the broken off studs.
  22. Mar 2, 2024 at 4:25 PM
    #82
    BluegrapeVr6
    J
    Clarification. Im going to loosen trans mount/ engine mounts, disconect drivetrain (not seperate trans) and lift engine as little as possible per keiths recomendation. That in combination of removing both front wheels/wheel well guards should do the trick. I used to wrench on vw/audi so it might not be that bad, others certainly say its a bitch and I have every reason to believe them. First time removing most exhaust manifold=throwing one cheap wrench against a wall.
