1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Dec 30, 2023 at 7:36 PM
    #661
    shifty` [OP] Earth acid cleanses me, cleanses me clean
    Did you use plate on either side for load distribution, or just bolt/washer/nut?
  2. Dec 30, 2023 at 7:39 PM
    #662
    daveeasa
    David
    I don’t remember clean access from underneath. But that may be due to the existing hole location selection.
    I am tempted to try a right angle air powered drill.
    should have knocked it out when I rented the hole hog. Could just rent it again I suppose.
  3. Dec 30, 2023 at 7:44 PM
    #663
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    fender washer on top. bottom doesn't matter so much because its metal
    shifty`[QUOTED][OP] likes this.
  4. Dec 30, 2023 at 7:46 PM
    #664
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You could raise up the shell and put it on blocks, then drill from the bottom. Then set it back onto the truck and mark the holes, then lift the shell again to drill the rails
  5. Dec 30, 2023 at 7:55 PM
    #665
    daveeasa
    David
    I have the rails already drilled from the old shell. So I can mark from below and then remove the shell and drill. Might have to go a little thinner with the bolts if I’m off. Just rotating the shell 90 degrees and resting on the rails would work. Some black spray paint might be the best way to mark it. Or maybe a sharpie.
  6. Dec 31, 2023 at 2:06 PM
    #666
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nice looking shell in Ole Man Tan. Never heard of the brand Ranch.
  7. Dec 31, 2023 at 2:08 PM
    #667
    Ranch is pretty similar in reputation and quality to Jason and Century caps.
    The Black Mamba likes this.
  8. Jan 1, 2024 at 3:48 PM
    #668
    montanalily
    montanalily New Member
    montana
    02 AC V8 4WD
    hi! I too was struggling terribly. so desperate, I left my phone number on peoples trucks asking if they'd sell their toppers to me (no one responded, ha!) so I called a few local shops (topper shops, pick n pull, and well-established mechanics) to put feelers out for a shell. In about a month I got one for $200, ARE high rise topper, basically mint condition. not color matched but personally I love the two-tone <3 (gold & thunder grey). good luck!
    shifty`[OP] likes this.
  9. Jan 3, 2024 at 1:18 PM
    #669
    $300 for a nice looking Century shell for an AC truck west of Atlanta:
    455h0le_dachshund likes this.
  10. Jan 3, 2024 at 2:55 PM
    #670
    And from a God fearing veteran no less
    txagg and Acatlin96 like this.
  11. Jan 3, 2024 at 6:37 PM
    #671
    Check out this camper for an AC, I wouldn't personally want it but nice job for a DIY and sounds like a portable house basically:
    Wallygator, abcinv and JasonC. like this.
  12. Jan 5, 2024 at 11:42 AM
    #672
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Since I passed last year, I can say I was today years old when I learned this nuance of the Texas Transportation Code:
    13. If my camper shell covers the Center High Mounted Stop Lamp, will that cause me to fail inspection?
    No. A camper shell that covers the Center High Mounted Stop Lamp will not be cause to fail inspection.​
    14. If my camper shell comes equipped with a Center High Mounted Stop Lamp, but covers the vehicle’s Center High Mounted Stop Lamp, will that cause me to fail inspection?
    No; however, if the camper shell was manufactured with a Center High Mounted Stop Lamp, it must be operable at the time of inspection.​
    Guess I'll be getting that Scamazon replacement TBL for my Leer camper after all. Or paying another 7 dollars and trying again elsewhere....
  13. Jan 5, 2024 at 12:00 PM
    #673
    Yup, I swear asshole_dog or @Mr.bee posted about #14 recently. Or maybe it was in a PM chain with the Texas folk. I don't recall.
  14. Jan 5, 2024 at 12:02 PM
    #674
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
  15. Jan 5, 2024 at 12:03 PM
    #675
    I can never remember how to stylize his name, so that's what he'll get if I can't figure it out within two or three tries. :bananadance:
  16. Jan 5, 2024 at 12:50 PM
    #676
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    chlorophil and 455h0le_dachshund like this.
  17. Jan 5, 2024 at 7:42 PM
    #677
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It might. The shell on my truck is an ARE off a Double Cab. It leaks a little but not enough to be a major issue.
  18. Jan 5, 2024 at 7:44 PM
    #678
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Bit 'spencive... Nice T3 though
  19. Jan 5, 2024 at 7:44 PM
    #679
    I'd give him $1,500 for the truck, he can keep the cap and the cheesy wheels, no offense, just not my bag of chips.
  20. Jan 5, 2024 at 7:58 PM
    #680
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Shiiiiiit thats a mint T3, minus the wheels and the weird accessories.
  21. Jan 5, 2024 at 8:17 PM
    #681
    You’re right, I guess I’d give him $150.
  22. Jan 5, 2024 at 9:03 PM
    #682
    chlorophil
    chlorophil New Member
    Reno, NV
    2004 Green Tundra DC 4x4
    gawd damn this went fast
  23. Jan 6, 2024 at 1:06 AM
    #683
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Interesting. I was thinking the long bed dohble cabs would, just based off the angles wasnt sure if this was a long or short bed.
    Side note, is there any height difference from the top of your cap and your cabin?
    Whewww already? Honestly most people around here are asking around a $1000 for a good condition shell so not surprising honestly
  24. Jan 6, 2024 at 5:36 AM
    #684
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not really. I've posted a million pics over the years.
    The gap is along the front bed rail by the cab. I could stick my hand through it so what I did is take a piece of pipe insulation and cut it to match the length. First I put down normal camper shell "double bulb".
    This is roughly what I used.
    https://www.homedepot.com/p/K-Flex-...y11jpml5XkaVAtH7V_EaAqvBEALw_wcB&gclsrc=aw.ds
  25. Jan 6, 2024 at 6:51 AM
    #685
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Not a perfect fit.
    Nicklovin and 455h0le_dachshund like this.
  26. Jan 6, 2024 at 7:19 AM
    #686
    Damn, Tex. Patrollin' mi barrio over here.
    It doesn't fit right because it's an AC shell on a DC. You can make a DC shell at least look somewhat right on an AC, you cannot make an AC shell fit right on a DC. It'll always appear too long.
  27. Jan 6, 2024 at 7:25 AM
    #687
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  28. Jan 6, 2024 at 7:37 AM
    #688
    Black AC shell on a DC in Louisville KY. Grossly overpriced for the used market, especially as-optioned, and with the rust and other stuff, no carpet, potentially crooked-mounted roof rack, missing window latch on rear passenger side, EDIT: And rigged up rear door latch (they used heavy cable), but I guess this is a possible option for KY folks if you can talk them down to what it's worth, which is about $250, $350 tops? It may also be missing the lower trim bead that goes around the perimeter of the cap:
  29. Jan 6, 2024 at 7:54 AM
    #689
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Damn I'd trade em my softopper if he were closer.
    Dude's rig looks great too.
    FrenchToasty likes this.
  30. Jan 6, 2024 at 9:19 AM
    #690
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Shifty, throw your search juju over to the west a bit. Like on our side of the mighty Mississippi :D
