1st gen 5VZ starts and stalls
Discussion in '1st Gen Tundras (2000-2006)' started by bro66677, Mar 16, 2022.
  1. Mar 20, 2022 at 6:43 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This seems like the biggest concern. If there is still some aftermarket nonsense going on.
  2. Mar 22, 2022 at 11:41 AM
    bro66677
    bro66677 [OP] New Member
    Ahmed
    nothing is left to try.
    called a friend to ckeck immo system. maybe reinstall original.
    thank you all
    shifty` likes this.
  3. Mar 22, 2022 at 11:44 AM
    bro66677
    Ahmed
    yes. spark is ok.
    power cuts off injectors right after ignition.
    strangly it returns within few seconds but can not start the engine afterwards.
    somehow the sestem kills power to injectors although fuel pump is running.
  4. Mar 22, 2022 at 11:53 AM
    shifty` Ten EV 12's so you know I raise hell
    That is weird. I don't know the typical behavior of the immobi, does it cut power to the injectors?
    Too bad you don't have a compatible spare ECU on hand to plug in ... could be ECU damage also.
