1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. Nov 28, 2021 at 5:52 PM
    #241
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Per normal, stuff took longer than I hoped for. Some bolts to tend to, and I probably won’t get the bed on as soon as I like, but things seem to be going well.
  2. Nov 28, 2021 at 7:57 PM
    #242
    alb1k
    Left Coast
    It's good
    @daveeasa - any reason I can't ditch the fuse on the Switch Pro 9100 4 ga power cable and use a breaker instead? It's a 125A inline fuse and I'm thinking a 120A breaker. I see breakers on tons of builds, but I can never see if thats for the aux fuse blocks, or actually straight to the SP. Almost sounds stupid to ask, but what do you think?
  3. Nov 28, 2021 at 8:08 PM
    #243
    daveeasa
    David
    They are sticklers on this one I believe, probably b/c of all the people who make a mess of things. Kinda your call I think. I did MRBF fuse + their inline fuse (ANL I believe?)
    A 125 breaker is OK by me but I guess it does add extra "stuff" which they will be cranky about so don't tell them?
    Maybe we should delete these posts? :)
    FWIW, I did the ground to the fender bolt rather than the negative terminal on my Tacoma. Then again I'm currently using exactly 0/8 circuits right now so if something were wrong I wouldn't know.
    But yeah, electrons and breakers aren't rocket science right? Just don't overload it and the thing should work fine. And I've heard good things about them honoring problems / warranty.
    alb1k[QUOTED][OP] likes this.
  4. Nov 28, 2021 at 8:18 PM
    #244
    alb1k
    Left Coast
    It's good
    Sweet David, thank you! I'll likely just run their power cable direct, but it's on the short side, so placement may change that...I'm a while out on the whole project. But, I can't stop thinking about it. I would love to see your setup.
    Erik
  5. Nov 28, 2021 at 8:30 PM
    #245
    daveeasa
    David
    My Tacoma build thread is here, I think I have a few photos of the switch-pros. But since I'm not using it for anything yet, probably nothing terribly useful in there.
  6. Nov 30, 2021 at 6:43 AM
    #246
    alb1k
    Left Coast
    It's good
    These bump stops compress quite a bit.
    Darkness likes this.
  7. Nov 30, 2021 at 8:21 AM
    #247
    alb1k
    Left Coast
    It's good
    27F battery tray. Should work, but 5/16” taller than the 24F OEM
  8. Nov 30, 2021 at 9:11 AM
    #248
    daveeasa
    David
    What material? 5/16” steel?
    I need a solution for my 31 and the Rago cage doesn’t really get me there. Currently running no tray.
  9. Nov 30, 2021 at 10:14 AM
    #249
    alb1k
    Left Coast
    It's good
    I had some G10 sitting around. I think some electric/circuit boards are made of Micarta. I didn't have a big enough piece of that. But they are both just fancy reinforced epoxy. Probably an expensive option to buy.
  10. Nov 30, 2021 at 10:26 AM
    #250
    daveeasa
    David
    Compared to the $200 group 31 cage which doesn't help me? :)
    I'll look it up.
  11. Nov 30, 2021 at 11:32 AM
    #251
    alb1k
    Left Coast
    It's good
    You can find natural color Micarta in a 12x10 or 12x12 for cheap. It’s kinda brown. I think Amazon may have it. 3/8 is pretty stout. 1/4 would be borderline thin.
  12. Nov 30, 2021 at 11:36 AM
    #252
    alb1k
    Left Coast
    It's good
    I would send you this but it’s a little short. The natural is lighter, but it all works. Cut it with a wet tile saw if you have one. Mills and drills great.
    FrenchToasty likes this.
  13. Nov 30, 2021 at 11:38 AM
    #253
    alb1k
    Left Coast
    It's good
    Battery install good for now.
    Punk1974, HBTundra and Darkness like this.
  14. Nov 30, 2021 at 11:47 AM
    #254
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fancy work. I stuck a board of wood under my battery.
    alb1k[OP] likes this.
  15. Nov 30, 2021 at 11:54 AM
    #255
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    I would bet the AG MD springs will tow far better than your stock leafs and AALs. I went that route originally and all I did was waste my money. Should have gone AG from the get go.
  16. Nov 30, 2021 at 12:20 PM
    #256
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Surprisingly my leafs seem to handle towing very well. But they weren’t in bad shape when I got the truck.
    alb1k[OP] and MDobb79[QUOTED] like this.
  17. Nov 30, 2021 at 1:00 PM
    #257
    alb1k
    Left Coast
    It's good
    I remembered that from a battery thread. I didn't have to cut this, so one less saw to get out :)
    Darkness[QUOTED] likes this.
  18. Nov 30, 2021 at 2:09 PM
    #258
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    nice progress so far. i was able to nicley fit 27f in my 2000 tunny years ago in the factory oem tray. iirc it weighed about 52lbs vs 37lbs for the 24f. makes a big difference in handling
  19. Nov 30, 2021 at 6:41 PM
    #259
    alb1k
    Left Coast
    It's good
    Thank you @Punk1974. My tray was about an inch short, probably good though - made me reinforce the area. Yeah, I didn't weigh them but it's pretty heavy. 15 more pounds seems about right.
  20. Nov 30, 2021 at 6:55 PM
    #260
    alb1k
    Left Coast
    It's good
    Back on the road, kinda - need an alignment. Next
  21. Nov 30, 2021 at 10:13 PM
    #261
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's cause they were like new. Given your truck didn't use them, being upside down and all. ;)
  22. Nov 30, 2021 at 10:37 PM
    #262
    empty_lord
    05 rollover special
    Hmmm maybe stretching her legs did help!
  23. Dec 1, 2021 at 6:43 AM
    #263
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    :rofl:maybe thats why Australians don't bother with lift kits.
  24. Dec 1, 2021 at 10:40 AM
    #264
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    Very nice
  25. Dec 1, 2021 at 11:35 AM
    #265
    alb1k
    Left Coast
    It's good
    Thanks! @0h6SR5
  26. Dec 1, 2021 at 9:05 PM
    #266
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I’ve used breakers on lots of builds. Multiple RZR’s, Rock Buggy and my Tacoma. I have not had any issues.
    chrisb, Lil Steve, SLA10 and 4 others like this.
  27. Dec 1, 2021 at 9:07 PM
    #267
    alb1k
    Left Coast
    It's good
    Thanks @Diablo 169. I can't see why it would be a problem, but ever run a breaker to a switch pro instead of the supplied inline fuse?
  28. Dec 1, 2021 at 9:11 PM
    #268
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I haven’t pulled the trigger on a switch pro yet, but I talk to them every year at KOH and they do always bring up over loading it and to make sure to run relays for any of the high amp items.
    I prefer the breakers because you can turn them off and kill all accessories for storage.
  29. Dec 1, 2021 at 9:13 PM
    #269
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Awesome build!
  30. Dec 1, 2021 at 9:19 PM
    #270
    alb1k
    Left Coast
    It's good
    Thanks @SLA10, this is the practice build so I can make my mistakes here :)
    Yea, @Diablo169, compressor and such on relays for sure. Thanks again!
    Diablo169[QUOTED] likes this.
