1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. May 20, 2021 at 5:16 AM
    #91
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'm hoping you used an etching primer on that chrome.:fingerscrossed:
  2. May 20, 2021 at 2:21 PM
    #92
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I used an adhesive promoter. Time will tell.....
  3. Jul 16, 2021 at 7:48 AM
    #93
    alb1k
    Left Coast
    It's good
    Decided to added Deaver’s in the end. Pretty sweet. I think a shock upgrade is in order. But what?
  4. Jul 16, 2021 at 2:05 PM
    #94
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Enjoying your build.....and I feel "F-ing around" helps me feel like I'm still young, keep F-ing it !
    FrenchToasty likes this.
  5. Aug 16, 2021 at 8:34 AM
    #95
    alb1k
    Left Coast
    It's good
    Edit 9/18/21: Rustoleum rattle can holds up to UV, Seymore getting/is flat. I forgot to take a pic today, but I'll try to remember to add.
    New EDIT: they both suck
    Glock 40 and daveeasa like this.
  6. Aug 16, 2021 at 8:41 AM
    #96
    daveeasa
    David
    Which brand are these? The green matches well?
  7. Aug 16, 2021 at 8:49 AM
    #97
    alb1k
    Left Coast
    It's good
    Quick turn around.
    Darkness likes this.
  8. Aug 16, 2021 at 8:55 AM
    #98
    alb1k
    Left Coast
    It's good
    These are perfect. Need a step drill bit to bore larger holes. Work fast and look great. Other colors available.
    KarmaKannon and daveeasa like this.
  9. Aug 16, 2021 at 9:00 AM
    #99
    daveeasa
    David
    Thanks. I did low brow dremmel for the first one I did. Probably should have done the step bit
    alb1k[OP] likes this.
  10. Aug 16, 2021 at 2:07 PM
    #100
    alb1k
    Left Coast
    It's good
    Yes, green = good.
  11. Aug 16, 2021 at 2:15 PM
    #101
    alb1k
    Left Coast
    It's good
    I expected I would be, but I'm a fan of 700# springs on coilovers for DC tundra. 650# is the Access Cab rate, and King also ships 650s with 2.5 OEM coilovers for the DC. Switching from 650# to 700#, I got same ride height with less pre-load, more droop travel (very much underrated IMO), and a better ride on hits and humps. Fast and slow. I also have room to add more preload if I add armor, and keep height.
    I can't see any reason to run 650# over 700# on a DC. The added droop travel alone wins.
  12. Sep 19, 2021 at 9:35 PM
    #102
    alb1k
    Left Coast
    It's good
    I’ve been posting and commenting on other threads, I think I’m fairly up to date, but here’s today. PS, my truck has no cabin air filter, lol.
    This is bed/cargo tie down mod, with bed mat mod.
  13. Sep 20, 2021 at 12:08 AM
    #103
    alb1k
    Left Coast
    It's good
    The Deaver springs in the rear (G57) are very nice - but, the driver side is riding higher by about an inch or so. Maybe the right side settled sooner? I have read recently that the 2.25 width stack settles/sags eventually. In this case, not at the same time, not on the expected side. I'm going to relocate my shock mounts for more travel, (not related). I'll contact Deaver before or after, probably before. I did see a post about 3" spring width, sounded promising, not sure where it ended up. Regardless, I will update with my results.
    Edit: great springs, not for my application. The ground wasn't level enough to measure properly.
  14. Sep 20, 2021 at 1:12 AM
    #104
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Bro, your truck looks amazing. Subscribed.
  15. Sep 20, 2021 at 6:19 AM
    #105
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Agree on the Seymour... poor UV resistance, grr. I'm planning to re-prep my Seymour areas and re-coat with rattle-can Raptor this winter.
    Keep up the great work! I always enjoy your updates.
    alb1k[QUOTED][OP] likes this.
  16. Sep 20, 2021 at 2:04 PM
    #106
    alb1k
    Left Coast
    It's good
    Thanks @Glock 40, I always value your input.
    Glock 40[QUOTED] likes this.
  17. Sep 27, 2021 at 12:29 PM
    #107
    alb1k
    Left Coast
    It's good
    So this is happening….
  18. Sep 27, 2021 at 3:50 PM
    #108
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I'm really interested to see how this goes. I've been thinking about getting one of these for a little bit now.
  19. Sep 27, 2021 at 4:24 PM
    #109
    Casper421
    In the woods
    06 DC
    Nice choice! Are you welding it up yourself?
  20. Sep 27, 2021 at 6:17 PM
    #110
    alb1k
    Left Coast
    It's good
    Me too. So far I like the quality. There are a few differences in different trims, years of Gen 1 that determine a few steps. That part is a tad confusing. One lame thing is Toyota did not square up the front of the bumper mounts. They angle out, so I’ll be shimming the outboard bolts. Also, not all trucks have a crossmember there. Mine does and is has to be trimmed. That’s easy, but I’m going to need to go back and see how it fits in there. Only bitch is that I noticed after welding that the plate that goes between the primary mounts, is interfering with my rear winch holes. I don’t know how that’s even happens. It’s a straight shot. I’ll need to fix that.
    Yes, I am. I’m no master welder, but I can get penetration and know how to avoid most warp. The finish seams will be a challenge. Wind was starting to mess with my shielding gas outside. Glad I’ll be able to do most of those welds in the shop.
    Here’s where I decided to quit today. I need to be fresh to figure out a couple of things and get my lines right moving forward….
    300BLK, Darkness, FirstGenVol and 5 others like this.
  21. Sep 27, 2021 at 6:18 PM
    #111
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Welds look nice. :)
  22. Sep 27, 2021 at 7:13 PM
    #112
    daveeasa
    David
    Impressive.
  23. Sep 27, 2021 at 8:54 PM
    #113
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Looks good. Will you be selling your old bumber?
  24. Sep 27, 2021 at 8:56 PM
    #114
    alb1k
    Left Coast
    It's good
    Coastal Offroad out of BC, Canada. @Casper421 has some good pics of one on his truck.
    So you don't have to search:
  25. Sep 27, 2021 at 9:45 PM
    #115
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yea... i really do want that bumper.. but man i want the aluminum to keep weight down
    but almost 1400 for a weld together kit is... eek
    KarmaKannon and SouthPaw like this.
  26. Sep 27, 2021 at 9:49 PM
    #116
    alb1k
    Left Coast
    It's good
    Yeah, I think its 105 lbs. Probably on the lighter side of winch steel bumpers, but it is weight...
  27. Sep 27, 2021 at 9:57 PM
    #117
    empty_lord
    05 rollover special
    my biggest reason for aluminum is the ability for it to not rot away out in my environment. lol
  28. Sep 27, 2021 at 10:09 PM
    #118
    alb1k
    Left Coast
    It's good
    Im going to have my body guy spray mine with the same bedliner type coating he sprayed the boys 4R with. But in the meantime, I asked him what to put on it before rust starts and that will be a good undercoating. He directed me to POR 15. Ill be picking up the degreaser, etch and paint in a day or two.
    EDIT: I sprayed it with Raptor Liner 2 part rattle can.
  29. Sep 28, 2021 at 7:36 AM
    #119
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    My thoughts exactly. I let someone borrow my truck this weekend and it was in a minor fender bender. I've been looking for aftermarket bumpers but it seems it's none, or $1400+ lol. That's almost half what I paid for the entire truck!
    alb1k[OP] and empty_lord[QUOTED] like this.
  30. Sep 28, 2021 at 8:55 AM
    #120
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    There is always getting it galvanized and painting or whatever over it. There's a place around here that would do it by the pound. They started at $200 or something like that and that covered up to 200lbs. I have been tempted a few times to send my sliders and eventual bumpers in.
