1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. Mar 24, 2022 at 12:00 PM
    #421
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    FrenchToasty likes this.
  2. Mar 24, 2022 at 12:01 PM
    #422
    alb1k
    Left Coast
    It's good
  3. Mar 24, 2022 at 12:03 PM
    #423
    alb1k
    Left Coast
    It's good
  4. Mar 24, 2022 at 7:38 PM
    #424
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    The LCA's look nice! did you need to upgrade the ballpoints?
  5. Mar 24, 2022 at 11:27 PM
    #425
    alb1k
    Left Coast
    It's good
    balljoints? no - stock. There is no upgrade :(
  6. Mar 24, 2022 at 11:28 PM
    #426
    alb1k
    Left Coast
    It's good
  7. Mar 26, 2022 at 5:52 PM
    #427
    2006Tundra
    Lou
    Long Beach, CA
    Oh nice. I know when I bought their spindles, you needed to upgrade the lower ball joints on the 04-06's.
  8. Mar 26, 2022 at 7:00 PM
    #428
    alb1k
    Left Coast
    It's good
    There may be a balljoint upgrade if you go with those spindles. I feel like I really wanted that.
  9. Mar 30, 2022 at 10:51 PM
    #429
    alb1k
    Left Coast
    It's good
    Fancy Solo Motorsports lower control arms are in and new air fill station.
  10. Mar 31, 2022 at 12:17 AM
    #430
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I clear my 33s even with mud flaps. But my camber doesn’t like me to get the caster
    alb1k[QUOTED][OP] likes this.
  11. Mar 31, 2022 at 12:18 AM
    #431
    empty_lord
    05 rollover special
    I want an air compressor on board. But whh
  12. Mar 31, 2022 at 6:42 PM
    #432
    alb1k
    Left Coast
    It's good
    WTH or whatttt? LOL
  13. Mar 31, 2022 at 6:46 PM
    #433
    empty_lord
    05 rollover special
    EHH.
  14. Mar 31, 2022 at 8:22 PM
    #434
    daveeasa
    David
    I want caddy horns but I know I’ll never use them.
  15. Mar 31, 2022 at 9:20 PM
    #435
    alb1k
    Left Coast
    It's good
    The tank system is low priority, but I will be getting a horn on a momentary button at some time. I went to the manifold first because it is immediately useful and I had everything after I got the hoses that attach. There are tire setups out there that are fairly expensive for 4-tire inflate/deflate. This does that but is better IMO, maybe the same cost or less. I want to get one or two different fittings to clean stuff up on the truck end, but I should make a video to show you what I mean about convenience and how it works.
    daveeasa[QUOTED] likes this.
  16. Apr 22, 2022 at 3:57 PM
    #436
    alb1k
    Left Coast
    It's good
    Current profile on 285/75/17s
    I have some fitment work to do…
    2006Tundra and 805Tundra like this.
  17. Apr 22, 2022 at 4:09 PM
    #437
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    New tires look sick! I was surprised to hear you had frame rub with the new LCAs, I guess the the 1" that they pushed out weren't enough for the wider tires?
  18. Apr 22, 2022 at 4:13 PM
    #438
    alb1k
    Left Coast
    It's good
    Well they push forward, but not away from the frame, sooo....
    I'm going to first play with 3/4" Boras if my Methods have enough stud relief milled or cast into them.
    2006Tundra and 805Tundra[QUOTED] like this.
  19. Apr 22, 2022 at 4:16 PM
    #439
    805Tundra
    Ben
    Central Coast
    Well i missunderstood lol and that makes a lot more sense then. maybe they won't rub as bad on the pinch weld then with spacers?
  20. Apr 22, 2022 at 4:21 PM
    #440
    alb1k
    Left Coast
    It's good
    For sure, they just barely clear now on turns and would not clear without the Solos. That's good. Any spacing and that clearance goes away, so If I do space, I expect to be massaging things.
    805Tundra[QUOTED] likes this.
  21. Apr 27, 2022 at 9:34 AM
    #441
    2006Tundra
    Lou
    Long Beach, CA
    I bought 1 1/4" boras without issue. Let us know if the 3/4 work out.
  22. Apr 27, 2022 at 10:53 AM
    #442
    alb1k
    Left Coast
    It's good
    Will do. I like them better for me. Almost zero frame rub and less fender and tub concerns. Also less scrub radius and leverage against the suspension. Less expansion and contraction under heat. One of the reasons I’m going steel in the end. But I’ll get into it more….soon.
  23. May 12, 2022 at 11:44 PM
    #443
    alb1k
    Left Coast
    It's good
    I'm very happy with my setup on the 3/4" spacers. They almost completely took away frame rub and reduced the other areas of concern as compared to 1.25. I'm going to the desert this weekend and will get a better idea of what can hit or rub as it sits. I have done the easy mods and am hopeful I don't need new fenders next week.
    2006Tundra[QUOTED] likes this.
  24. May 12, 2022 at 11:45 PM
    #444
    alb1k
    Left Coast
    It's good
    Image update.
    805Tundra and 2006Tundra like this.
  25. May 13, 2022 at 12:18 AM
    #445
    alb1k
    Left Coast
    It's good
    I've changed bump configurations a dozen times. The latest is based on my full stuff test. I would really like a pair of Superbumps in the front and my current Durobumps in the rear (front-front, rear-front) to test, but I've just been spacing my Duros differently or pulling and putting them back, lol.
    5N0W808[QUOTED] likes this.
  26. May 13, 2022 at 12:44 AM
    #446
    alb1k
    Left Coast
    It's good
    Not really, but I'll trade a set for those supers :). The stock stops are bigger front-rear, I guess it's a progressive design as they hit first. Now that I have the Solo LCAs, the front of the same size hits first. And there is more distance than stock arms to the frame. Most people just add aftermarket bumps either front-front or front-rear, not both. Honestly, I've never hit them hard enough to really know how good I have them set. Or, they are so good I don't notice. That reminds me, I should see if I can find the boy's old go pro...
  27. May 13, 2022 at 6:03 AM
    #447
    daveeasa
    David
    I have some durobumps inbound from @memario1214 which I think are designed for FGT? Not sure though, not a expert on riding bumps.
    alb1k[OP] likes this.
  28. May 13, 2022 at 6:36 AM
    #448
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Correct. The Duros I sent you are 1st Gen Tundy specific :thumbsup:
    alb1k[OP] and daveeasa[QUOTED] like this.
  29. May 16, 2022 at 11:41 AM
    #449
    alb1k
    Left Coast
    It's good
    Thanks to @des2mtn, had some field testing this weekend.[​IMG][​IMG]
    sn_85 likes this.
  30. May 16, 2022 at 12:09 PM
    #450
    805Tundra
    Ben
    Central Coast
    This photo is so sick! looks like you had a blast. Do you disconnect the sway bar when you go romping around?
