1st Gen(2UZ-FE) header options
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Sep 23, 2019.
  1. Oct 19, 2021 at 5:18 PM
    #91
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    No I haven't snice that's something that I would probably need to pay to install as I'm not sure I can trust myself doing gears. Even though I have done gear replacement on my 4x4 quads. When do gear replacement help? I thought it helps after you have like 33" tires.
  2. Oct 19, 2021 at 5:28 PM
    #92
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    If you've never done it before I would definitely advise professional install. Not something for a novice to tackle. Having said that there is no particular tire size needed before consideration. If you are considering going to a larger tire size soon I would factor in that extra weight and size difference to the gear choice and that way you eliminate the possibility of having to regear twice. If you have a local 4WD club or the like close by you can ask who they use as an installer.
    @Dave8699 somewhat lengthy but it answers your question fully:
    https://motorbeast.org/gear-ratio-how-it-affects-horsepower-torque-and-rear-axle-in-trucks/
  3. Oct 19, 2021 at 6:02 PM
    #93
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I know this is a header thread but do you have any recommendations or threads comparing gears? I have 265/70 17 right now.
  4. Oct 19, 2021 at 6:10 PM
    #94
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    These little engines need to spin a bit to have power. Peak torque is at 3400rpm, the rest of the power is higher. Headers generally raise those numbers, so the engine wants to spin even faster. And you dont want to ‘lug’ it because 2 bolt mains and American rods. It doesnt mind being spun, boost can come on early, but with extra fuel, and you dont want to overspin these engines cause 2 bolt mains and american rods. Know how badass a 1gt would be with a vortec 8100 and a 8,9, or 10 speed?
    bmf4069 likes this.
  5. Oct 19, 2021 at 7:21 PM
    #95
    Desert Dog
    I'm not aware of any threads comparing them and any recommendations would require the specifics of what you're trying to accomplish. I suggest creating a new thread with your details and getting input from other members. Bear in mind that the gearing that's in it now is a compromise and any regear you do or have done for you will also be a compromise. It's just a question of what you're willing to compromise to achieve your specific ends/wants/needs. Personally, I believe for towing a regear is a better option for you over headers and exhaust.
    Lil Steve likes this.
  6. Oct 20, 2021 at 8:31 AM
    #96
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
  7. Oct 20, 2021 at 4:11 PM
    #97
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I wonder of if it will be more or less the same for our trucks.
  8. Oct 20, 2021 at 4:12 PM
    #98
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The VVTI motors respond better. But gains % wise should be similar on all
  9. Oct 20, 2021 at 4:16 PM
    #99
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    So its looking like @dirtydeeds is the only option for headers and exhaust
  10. Oct 20, 2021 at 4:27 PM
    #100
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Whether long tube or shorties, the JBA headers can be bought anywhere. From there it depends what you do with your cats and anything behind them can be fabricated.
    FrenchToasty likes this.
  11. Oct 20, 2021 at 5:12 PM
    #101
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    So im assuming the best case scenario snice Stans is out is JBA long tubes, hi flow cats Spintech muffler and have a shop fab everything in between.
  12. Oct 20, 2021 at 5:34 PM
    #102
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Yes, you can buy the JBA long tubes from anywhere, but Dirty Deeds is the only place you can buy the 05-06 headers with SAIS delete. The only other way to fit 00-04 headers to an 05-06 when using the Hewitt SAIS bypass kit is by drilling and tapping your cylinder head for plugs to block the air injection ports.
    So if you have a functional SAIS on your 05-06 and you don't buy from Dirty Deeds, just spend the extra $300 for SAIS equipped headers.
    As mentioned elsewhere in this thread, Keith and his crew fit the 05-06 header flange and puddle weld the air injection ports. So when you bolt the header on using an 05-06 header flange gasket it effectively blocks the air injection ports on the head.
    Casper421 likes this.
  13. Oct 20, 2021 at 5:36 PM
    #103
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    At least I don't have to deal with that headache.
    Darkness and Riverdale21[QUOTED] like this.
  14. Oct 20, 2021 at 5:40 PM
    #104
    Riverdale21
    OTP ATL
    This photo from a post by FrenchToasty shows where Dirty Deeds welded the air injection ports.
    First picture shows the 05-06 exhaust manifold gasket. You can see the extra holes for air injection is at the 12 o'clock position relative to the exhaust port.
    This shows the 00-04 with no air injection ports on the cylinder head
  15. Oct 20, 2021 at 5:44 PM
    #105
    Riverdale21
    OTP ATL
    True. You have the last year before VVTI.
  16. Oct 20, 2021 at 5:44 PM
    #106
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The guy I was answering has an 04, no sai to mess with.
    :hattip:
  17. Oct 20, 2021 at 5:51 PM
    #107
    Riverdale21
    OTP ATL
    I was more or less putting the info out there for the masses. If someone else with a VVTI thinks they can save a few bucks buying an 00-04 header they are in for a headache.
    Darkness[QUOTED] likes this.
  18. Oct 20, 2021 at 5:52 PM
    #108
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Anyone know of hi cats that bolt to JBA long tubes?
  19. Oct 20, 2021 at 5:56 PM
    #109
    Riverdale21
    OTP ATL
  20. Oct 20, 2021 at 6:05 PM
    #110
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Anyone use a unichip after header or exhaust? Is it worth it?
  21. Oct 21, 2021 at 10:18 AM
    #111
    empty_lord
    05 rollover special
    Well called today and he sold and the headers are no longer available. Does anyone make tri y headers still? I don’t want shorties or long tubes.
  22. Oct 21, 2021 at 10:23 AM
    #112
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  23. Oct 21, 2021 at 10:27 AM
    #113
    empty_lord
    05 rollover special
  24. Oct 21, 2021 at 10:32 AM
    #114
    empty_lord
    05 rollover special
    Are there any dynos of each headers? I’m curious. Because I’ve got a cracked manifold so now I need something. I just hate shorties and long tubes don’t gain you much of anything down low.
  25. Oct 21, 2021 at 10:41 AM
    #115
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Dont be skeered.
    bmf4069, tyler-brown and Darkness like this.
  26. Oct 21, 2021 at 10:46 AM
    #116
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have one and the canned tunes aren't worth the cost. One member here got his tuned and pulled some extra power, I'm not sure what his total cost was. I think he got about 15hp.
    When I got the Unichip they were having a blowout sale and it was around $400, so I took a chance. No dyno time, from seat time it shifts earlier even when I floor it. Maybe pulls harder on freeways but hard to be sure. Best useful feature to me is the valet mode, that won't let rpm go above 2000. Nice for car washes or valet. No way would I recommend it at the full $700+ price.
  27. Oct 21, 2021 at 11:10 AM
    #117
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Ok so if you go with shorties or long tubes snice tri-y are out. Will it still benefit me snice its not tuned? How about CEL, I'm used to have my tuner use HPtuners to tune my track car.
  28. Oct 21, 2021 at 11:13 AM
    #118
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Wait. What the hell am I looking at? I'm trying to figure out relationship of vehicle position to objects behind it and my brain just melted.
  29. Oct 21, 2021 at 11:25 AM
    #119
    empty_lord
    05 rollover special
    Those are 180 degree headers to mimic flat plane v8s
    shifty`[QUOTED] and Darkness like this.
  30. Oct 21, 2021 at 11:31 AM
    #120
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, i think the top is the bottom, but it also looks like the starter bendix engages with the back of the trans.
    but the image came from a detomaso forum, so maybe it is the top… but i didnt think they had that much room in the back. And im not seeing a rad.
