19 Tundra under 10k miles burning oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Amad, Nov 26, 2019.
  1. Nov 26, 2019 at 7:27 PM
    Amad
    Amad [OP] New Member
    19 Tundra trd sport
    Hey, I just bought my truck Sept 30 brand new, I've got close a 100mile commute on highway for the jobsite I'm on. I had to add 3/4 quart before 1st oil change. Drove to St Lousi Missouri from chi roughly 1200 mile had to add half a quart already. I went to dealer I went to service Manager he said its normal for it to burn"or diccipate up to 2 quarts" in a oil change interval. It's my first new car I've ever bought, I thought this was a good buy is this normal or not? Any feedback will be greatly appreciated
  2. Nov 26, 2019 at 7:29 PM
    AZBoatHauler
    So.Arizona
    Not normal.
    Nic146, B737, OR18TRD and 1 other person like this.
  3. Nov 26, 2019 at 7:33 PM
    koditten
    Kirk
    Midland of the Mitten
    Agreed. Not normal.
    Nic146, OR18TRD and GODZILLA like this.
  4. Nov 26, 2019 at 7:34 PM
    That service manager is full of it. Some oil usage in a new engine can be normal, but not that much. Oil level is one of the things you have to watch on a 5.7. If they run low they can coke up, and then it's a snowball effect. Source -> https://www.motorreviewer.com/engine.php?engine_id=108
  5. Nov 26, 2019 at 7:35 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sounds like it's time to find a new dealer.
    GODZILLA likes this.
  6. Nov 26, 2019 at 7:44 PM
    AZBoatHauler
    So.Arizona
    and filter housing
    OR18TRD[QUOTED] likes this.
  7. Nov 26, 2019 at 7:47 PM
    Amad
    19 Tundra trd sport
    Sorry, dont know what cam tower or rear main seal, I'll google and update.
  8. Nov 26, 2019 at 7:50 PM
    Don't google. Just use the search feature on this forum. Lots of info on them.
    OR18TRD and Amad[QUOTED][OP] like this.
  9. Nov 26, 2019 at 10:35 PM
    :rofl:Was just cutting out the middleman. His google search is just gonna bring up the threads here.
  10. Nov 26, 2019 at 10:37 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Dang straight
  11. Nov 27, 2019 at 12:29 AM
    TTund16
    TTund16 New Member
    Tundras don't burn oil.
    If it was an Audi, BMW or Subaru then maybe! The service manager must have transferred from one the above.
  12. Nov 27, 2019 at 12:30 AM
    :sorry: :threadjacked:
    I was lucky with my WRX I guess. Never used any oil.
    MS22 and TTund16[QUOTED] like this.
  13. Nov 27, 2019 at 1:50 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Everything will wear enough to burn oil eventually.
    Most of my new vehicles don't burn any until over 100k, some like my 3rd gen 4runner didn't until over 275k.
    The manual does say it is "allowable" to burn up to 1 quart per 1000 miles, so the OPs burn rate is within "standard", yet I would be oh so upset if my under 10K mile motor was already burning oil, what will it be like at 100k or 250??? Not a good sign no matter what. Yet not much legally can be done about it, so ask very, very nicely and just maybe they'll do something about it. Luck and enjoy.
  14. Nov 27, 2019 at 2:53 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  15. Nov 27, 2019 at 5:15 AM
    My 07 didn't burn any oil and my new to 14 doesn't either. 2qts....not normal
    TTund16, Cpl_Punishment and GODZILLA like this.
  16. Nov 27, 2019 at 5:22 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    You need to get that documented with Toyota ASAP, I'd say, so it's on the record that you are having this problem at this time. Keep running it up the chain to the next level. I've never done that with Toyota, but people here know the process.
    TTund16, Black Wolf and GODZILLA like this.
  17. Nov 27, 2019 at 5:42 AM
    15whtrd
    15whtrd Mr. Blonde
    I think people are missing the fact that he only mentioned that the dealer said they can burn “up to 2 quarts”. He’s burned 3/4 of a quart within the oil change interval. While it is using some, most manufactures are going to consider that normal, and not do anything about it. If it was 2 quarts, I’d be pissed.
    OP, make sure you’re checking it in the same manner every time. That way it’s consistent. Usually a warm truck that has sat for five minutes, then check. I have to add a splash of oil between my oil change intervals. In 5000 miles I’ve probably added a 1/4 to 3/8 of a quart. Some oil is going to get used through the PCV system.
    When my truck was new, I think I added over a half a quart through the oil change interval. Now that I’m at 30 K, it seems to be much less. I changed my oil a few months ago and check it every month. I haven’t added a drop in the last 2000 miles.
  18. Nov 27, 2019 at 6:28 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I agree with this.
    A new engine with rings that aren't broken in can burn at a faster rate.
    I would be more concerned with how the truck was used after driving it off the lot. I wouldn't buy it and then drive 100 miles highway/ day until after it's broken in. Engine break in procedure is a real thing and driving extended milage at highway speed/ consistent RPMS isn't exactly a good thing.
  19. Nov 27, 2019 at 7:31 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Does the manual mention proper break in procedure. I read my 17 but cant remember other than don't tow for the first 500 miles. Curious because I'm considering trading for a 20.
  20. Nov 27, 2019 at 7:32 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had one of the famous Ford 5.4s. It used a quart every 1000 - 2000 miles from day one. Ford said is was within the acceptable range. Specs were for 5-20 syn blend but I found that running 10-30 it used less. I change oil in my Tundra every 10k. Last change it was in the middle of the stick with no additional oil added.
    15whtrd likes this.
  21. Nov 27, 2019 at 7:36 AM
    15whtrd
    15whtrd Mr. Blonde
    I can’t remember exactly either, but something about not towing or sustaining a consistent RPM for extended periods of time. No hard acceleration or braking.
    TTund16 likes this.
  22. Nov 27, 2019 at 8:53 AM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Burning oil was normal for my GMC not for my Tundra. I have a 2019 Tundra and I was pleased to find that it used no oil between oil changes.
  23. Nov 27, 2019 at 10:53 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    2019 with 9,000 miles on it.Oil is right were it should be. Idid change it at 5,000
    TTund16 likes this.
  24. Nov 27, 2019 at 11:10 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Cam tower leaking by chance?
  25. Nov 27, 2019 at 11:21 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Your service manager claims it's normal to burn 25% of your engine oil between changes in a brand new truck? I'd let Toyota know they have dealers telling people that. Unbelievable.
  26. Nov 27, 2019 at 11:57 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    My old 08 that I traded in had 100,000k on it, never burned a drop.
  27. Nov 27, 2019 at 12:47 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    See bold:
  28. Nov 27, 2019 at 1:08 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My 2006 350Z had oil control ring issues and used 3 quarts between oil changes. At 18k they replaced the motor with an identical defective motor & gave it a 12k/12month warranty when it happened again at 36k they said we'll give you free oil changes.
    I'll never own another Nissan.
    Call corporate, create a case, make them document the use & prove it is ok.
    Good luck.
    Amad[OP] and Cpl_Punishment like this.
  29. Nov 27, 2019 at 2:26 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Im gonna go check the dipstick.
    4600 since change, sat 2 hrs level. Right on mark full.
    TTund16 likes this.
  30. Nov 27, 2019 at 3:00 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
