19-22 Tundra Owners Transmission Important
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraTRD11, Mar 11, 2021.
  1. Mar 23, 2021 at 6:57 PM
    #91
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    My thoughts for a while have been that this (dropping the trans cooler) was not a cost saving measure now, but an experiment for the future.
    I think the reason it defaults into S4 is that, as several have written, you should be in D with heavy load and in tow/haul mode, unless going downhill. When you switch to S-mode when towing, it is primarily to downshift going down hill and utilize engine braking to help decelerate. No engine braking is available in S4 or S5. So if your in 6th and suddenly hit a 15% downhill grade, you don't want to immediately jump to S3, you want to be coasting one gear above above engine braking before you make that downshift. If you need to switch to S-mode going downhill, D to S5 and you're two shifts from where you want to be braking and that isn't very efficient either.
    S-mode is not for protecting you transmission temps, that is what the cooler is for...sorry '19-'21 guys. I would be soooo pissed. Toyota is smart, and this was a great design AI system. Unfortunately, I think the disappearing trans cooler was a corporate experiment leading into the new model. Toyota wanted a real estimate of how many like sgtfluffy 16 and 327Tundra and myself are actually out using their tundras the way Toyota originally marketed and built them. Now that they are going to this B.S TTV6 +/- hybrid powertrain, they want an estimate of how many will fail in the warranty period, and will the cost be worth it. Toyota may be mimicking more than Ford's powertrain, they may also be mimicking Ford's business model.
    Summitroad and LarryDangerfield like this.
  2. Mar 23, 2021 at 7:07 PM
    #92
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Got it. That makes more sense. I think I remember you sharing that info before. Thanks.
  3. Mar 23, 2021 at 7:21 PM
    #93
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Report attached to the original response as well.
  4. Mar 25, 2021 at 10:29 AM
    #94
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Just noticed my transmission on my 2020 start shifting "differently" I have the cooler installed too. I am going to take it to the dealer to see what's going on. It could be I don't know how to drive.
  5. Mar 25, 2021 at 10:31 AM
    #95
    14burrito
    2014 SR5 CM 4x4 5.7
    I'd check fluid level before letting a dealer look at it, especially since you modified it.
    Melikeymy beer likes this.
  6. Mar 25, 2021 at 10:38 AM
    #96
    Lake.Life24
    Shawn
    Upstate, NY
    I will. I would be surprised if it was off, but who knows. Hopefully it's something simple.
  7. Mar 25, 2021 at 10:51 AM
    #97
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Thanks for posting this. I have noticed the same things with my transmission but thought it must be normal. I'll have it checked when I take it in for my fuel pump recall fix probably next week.
  8. Mar 25, 2021 at 11:08 AM
    #98
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I assume you're not going to the trouble to remove the cooler retrofit before taking it in? (Best course if you leave it, is don't mention it imo.) Don't forget to let us know how dealership service guys react to your cooler install. That's been another ongoing discussion here.
  9. Mar 25, 2021 at 11:18 AM
    #99
    Lake.Life24
    Shawn
    Upstate, NY
    I am dropping it off tomorrow for them to check. I told them I added the cooler and just need to make sure its at the appropriate level. We will see what they come back with. Luckily, the Service manager and the master mechanic are Tundra owners. So they understand the passion.
    JohnLakeman[QUOTED] likes this.
  10. Mar 26, 2021 at 8:26 AM
    #100
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    Eliminated.
  11. Mar 26, 2021 at 11:13 AM
    #101
    Lake.Life24
    Shawn
    Upstate, NY
    Heard back from the dealership....
    Transmission was over filled. It appears the transmission had enough fluid in there for the cooler already. The guy I had install didn't check correctly and just added the 1.5 quarts.
    The master mechanic set everything to the correct level, then drove it for about 50 miles and said its shifting normal now. He doesn't think there is any long term damage, but they made a note that it was overfilled. I asked if the trans cooler is an issue and they said not a problem they just have to note that there is an aftermarket part.
    They only charged me for an hour of labor due to it having an aftermarket part.
    I pick it up in a couple of hours so we will see how it drives. I trust thing mechanic as he did my Cam tower seals on my 2018. Kept the truck an extra two days to make sure everything went back together smoothly. He also drives a Rock Warrior so I have to trust his judgment.
  12. Mar 26, 2021 at 11:42 AM
    #102
    14burrito
    2014 SR5 CM 4x4 5.7
    Genuinely curious how the tech that installed the cooler ended up overfilling it based solely off the procedure for checking/filling the gearbox.
  13. Mar 26, 2021 at 11:46 AM
    #103
    Lake.Life24
    Shawn
    Upstate, NY
    No idea. I should have just done it myself but I don't have a garage and it was in the middle of winter. He probably just unscrewed the fill plug and pushed the whole bottle in there.
  14. Mar 26, 2021 at 1:59 PM
    #104
    JMB711
    JMB711 New Member
    Why where the old timey tranny dip sticks eliminated?
  15. Mar 26, 2021 at 2:11 PM
    #105
    JohnLakeman
    2005. Why? Only Toyota knows for sure. The rest of us can speculate, apply common sense, logic, etc.
  16. Mar 26, 2021 at 2:26 PM
    #106
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Oil dip sticks are going away as well - my wife's car doesn't have one. You look on the little computer to see the oil level. Apparently people never checked even with the stick.
  17. Mar 26, 2021 at 2:39 PM
    #107
    Tundrafan23
    Tundrafan23 New Member
    I'm sorry, but your theory is utterly absurd! You really think Toyota is purposefully willing to ruin its reputation as an incredibly reliable truck and alienate 3 years worth of Tundra customers from future Tundra purchases, all for some data? There are a hell of a lot easier ways to gain data on how Tundra users are using their trucks.
    Clemsonman14 and Dallas007 like this.
  18. Dec 10, 2021 at 8:45 PM
    #108
    Captain papa
    Captain papa New Member
    It appears they have proven to themselves that it is okay without the external cooler because the 2022 also does not have one.
  19. Dec 11, 2021 at 4:22 AM
    #109
    timsp8
    NY
  20. Dec 11, 2021 at 6:32 AM
    #110
    blanchard7684
    blanchard7684 New Member
    good screen shot. Yes that is what I saw in one of the videos was plubming to and from radiator reflecting an in tank cooler.
  21. Dec 11, 2021 at 8:38 AM
    #111
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Does anyone have a link or process on how to check/change transmission fluid in the 2019+ MY?
  22. Dec 11, 2021 at 12:46 PM
    #112
    timsp8
    NY
    I think it’s the same as other years, you just don’t have a thermostat to pin.
  23. Dec 11, 2021 at 4:07 PM
    #113
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    A 6 spd manual option with a big clutch plate would fix this problem. Toyota probably wouldn’t sell any of them though.
  24. Dec 11, 2021 at 4:37 PM
    #114
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'd buy one but I know I'm a rarity.
    Tbrandt[QUOTED] likes this.
  25. Dec 11, 2021 at 5:01 PM
    #115
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'd buy one. TONIGHT.
  26. Dec 11, 2021 at 5:46 PM
    #116
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Cpl_Punishment likes this.
  27. Dec 11, 2021 at 6:49 PM
    #117
    timsp8
    NY
    I don’t know. I thought the same thing, but if you look at the bottom right there is an arrow for “ATF Flow”. It almost looks like it has both.
