19-20 Discussion on Missing Ambient Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Aug 22, 2020.
  1. Sep 12, 2020 at 5:39 PM
    #151
    betotundra
    betotundra Toyota for Life
    I agree with what you said, but the amount of $ you mention is WAY BELOW what most people installing the cooler are expending.
  2. Sep 12, 2020 at 6:08 PM
    #152
    Greg Marmalard
    Greg Marmalard New Member
    2019 Tundra TRD Off Road Double Cab
    Right.... because Toyota removed the plumbing and thermostat..... and never had a good mount for one ever as I recall....
    betotundra[QUOTED] likes this.
  3. Sep 12, 2020 at 6:16 PM
    #153
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Under $400.
  4. Sep 12, 2020 at 7:31 PM
    #154
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I was towing nothing and the only load was my wife and me and maybe 50# of tools and stuff I keep in my bed toolbox all the time. Ambient was 81 deg F.
    SomeGuy4 likes this.
  5. Sep 12, 2020 at 7:59 PM
    #155
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    I see the same not towing.
    My experience so far is that my temps are very close towing vs not towing , I see higher torque jumps when accelerating vs not towing , however pan temps are close from what I observed , of course I tow on s4 and keep it at 60mph max . I have uploaded to this thread data collection from towing vs none towing showing results
  6. Sep 12, 2020 at 9:03 PM
    #156
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    My experience is that the stock 5.7 engine is nearly impossible to overheat when the cooling system is in good working order.
    The trans cooling system on the other hand seems insufficient to control the trans temp when towing even if you pin the trans thermostat open.
    betotundra and pickeledpigsfeet like this.
  7. Sep 12, 2020 at 9:12 PM
    #157
    careyrob
    Carey
    Massachusetts
  8. Sep 13, 2020 at 6:03 AM
    #158
    timsp8
    NY
    GODZILLA and Cpl_Punishment like this.
  9. Sep 13, 2020 at 7:08 AM
    #159
    careyrob
    Carey
    Massachusetts
    Gotcha :smack:Sorry.
  10. Sep 14, 2020 at 9:12 AM
    #160
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Real time info is what we need, thanks to those who are sharing. Keep it up.:thumbsup:
  11. Sep 18, 2020 at 5:02 PM
    #161
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've finished my vacation and I traveled around 7,500 kms over a three week period. Everything worked perfect with the added cooler and I saw pan temps from 195f to 210f. Very happy with the results.
    Bammer, rebmo, jordoncloutier and 2 others like this.
  12. May 10, 2021 at 11:56 AM
    #162
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    Just towing my bass boat about 40 miles to the lake...outside temp 84 degrees; towed in S5 with tow-haul mode....too high of a temp???
  13. May 10, 2021 at 12:11 PM
    #163
    Jtundra81
    Joe
    We don’t see the image , try re-uploading
    Fearthisbeard likes this.
  14. May 10, 2021 at 5:29 PM
    #164
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Or just tell use the temp.
    Cpl_Punishment likes this.
  15. May 17, 2021 at 8:29 AM
    #165
    swampshark
    south la
    2020 MGM SR5
    Pan temp...223; Torque temp...228; Oil temp...223; Coolant temp 203...towing in S5 with tow haul mode.
  16. May 17, 2021 at 8:34 AM
    #166
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If it stays there for the entire drive, that's probably not unreasonable. What do the temps do if you drop it to S4?
  17. May 17, 2021 at 9:03 AM
    #167
    Jtundra81
    Joe
    How heavy is the boat and how fast were you going ?
  18. May 17, 2021 at 9:28 AM
    #168
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I wouldn't be too worried about those temps.
    Cpl_Punishment and Saltyhero13 like this.
  19. May 17, 2021 at 9:40 AM
    #169
    swampshark
    south la
    2020 MGM SR5
    boat, trailer probably 3000lbs.....traveling anywhere from 70 on hwy. to 45-50 in town....never tried towing in S4
  20. Jul 11, 2023 at 7:34 PM
    #170
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    Resurrecting this thread from over two years ago from the last post, actually read every comment from start to finish, I also have a 2020 with the hockey puck type cooler/heater, I really don’t do any towing to speak of but I do run 80 miles an hour on the freeways and tollways on various trips, curious if anybody has anything to add about their comments on this thread…
    Thanks in advance
    2mchfun likes this.
  21. Jul 11, 2023 at 8:39 PM
    #171
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I can tell you from experience that running 80 on the highway will easily bring your temps up to 220-230 with no cooler. With the cooler you stay around 185 all the time.
    Jtundra81 and 2mchfun like this.
  22. Jul 11, 2023 at 9:04 PM
    #172
    2mchfun
    Mine is running with the thermostat unpinned. Max payload and WOT, stock gears, on 35's not towing with air temp at 85 the tranny stays at 212. Works for me.
  23. Jul 11, 2023 at 10:13 PM
    #173
    AZBoatHauler
    So.Arizona
    Thermostat? I thought there was not thermostat on the 2019+ because there is no real cooler and that’s the whole gripe…
  24. Jul 12, 2023 at 2:28 AM
    #174
    2mchfun
    Not long after I bought the truck, I installed a Hayden HD cooler, OEM thermostat, hard lines, and hoses. Just sharing the numbers for those who want to make comparisons.
  25. Jul 12, 2023 at 6:27 AM
    #175
    _none_
    _none_ Poser
    2020 DC SR5 4x4
