18 vs. 20 inch - Any advantage to either wheel size?
Discussion in 'Wheels & Tires' started by gdog_Tundra, Feb 21, 2019.
  1. Sep 22, 2021 at 3:48 AM
    #91
    EWR
    EWR New Member
    2021 silver Toyota Tundra Limited 4x4
    Will 17" and 18" make the ride less bouncy and jittery compared to 20 in?
  2. Sep 22, 2021 at 6:25 AM
    #92
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Great info Chris. So the wheels are 4 lb heavier EACH for the 20's and the tires are a lb heavier EACH. On top of the ride differences, this would affect both acceleration performance and MPG's. From all of this, I see three advantages for 20's:
    1. Looks (subjective preference, I don't care which myself - I like both)
    2. Better cornering. If you are cornering fast enough to see a difference between 18's and 20's, I would venture to say that you are probably going faster than you should be going - get a sports car.
    3. Slightly better coasting. The added weight of the wheels/tires increases the flywheel effect (torsional/rotational momentum). I imagine this would be very slight and probably not noticeable.
    If the right deal comes along, I'll be getting black 18's to replace my stock 1794 20's.
  3. Sep 22, 2021 at 6:27 AM
    #93
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The extra rubber in the sidewalls would absorb more of the bounce/jitter. How much would depend on which tires. Some report a significant improvement while some say they don't notice a difference at all.
  4. Sep 22, 2021 at 7:02 AM
    #94
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    You mis understand me.
    MY comment was that some, (specially the young) love to modify, which I was once, the Hell out of cars / trucks / bikes.
    If 20s came with your rig, then 20s were designed for your right regardless of what brand of wheel you choose.
    Lots of times, and you can't challenge me on this part, the (I should of left it stock syndrome ) comes back.
    This is true with lots of things, even firearms.
    Now do you understand?
  5. Sep 22, 2021 at 7:23 AM
    #95
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Could the right deal be $1,000 for 4 silver 17" beadlock wheels? :rolleyes:
    Been installed once and driven about 50 miles. Tires removed because they were just too small IMO.
  6. Sep 22, 2021 at 7:40 AM
    #96
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Looking for black, and I'd likely pass on 17's unless I really liked the look of them.
  7. Dec 3, 2024 at 9:14 AM
    #97
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    2019 Limited Crewmax 4x4, mine have the stock 20”s!
    I don’t really want to raise the truck, or level it because we tow a trailer when camping.
    However, I do wanna fill that wheel well up with bigger tires or at least look that way.
  8. Jan 7, 2025 at 1:21 PM
    #98
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    How tall are the tires?
