18 tundra cm size
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ds1234567890, Jan 20, 2018.
  1. Jan 20, 2018 at 6:47 PM
    Ds1234567890
    Ds1234567890 [OP] New Member
    i am looking to buy a 2018 tundra. I’m looking at the trd off road and really like it but also test drove a sr5. By Wife thinks the sr5 is a touch smaller on the inside. Any info would be great. I know the trd sits a little higher. As a daily driver which rides/drives the best
  2. Jan 20, 2018 at 7:26 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I don't think there is size cab size difference between TRD and SR5.
    If you never go off road, non-TRD will be a little smoother. TRD tends to be bit stiff (good for off-roading).
    zcarpenter92 and 15whtrd like this.
  3. Jan 20, 2018 at 7:45 PM
    TheBeast The Beach
    unless the SR5 was a double cab. were they both crew max ?
    NewImprovedRon and 15whtrd like this.
  4. Jan 20, 2018 at 7:50 PM
    Ds1234567890
    Yes both was crew max. It may have been the higher vehicle then she is accustomed to previous was a Chevy. Only off road I do is farm related and hunting
  5. Jan 20, 2018 at 7:53 PM
    TheBeast The Beach
    you can also get the SR5 right now and upgrade the suspension later for your needs. Lots of guys do it here.
    15whtrd likes this.
  6. Jan 20, 2018 at 7:54 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Mine has the TRD suspension and the rear TRD sway bar, I don't think it rides rough, it does handle good though going around corners. I don't know how a regular Limited suspension with the 20's feels or handles so I can't make a comparison.
    Are you sure the TRD suspension adds height?
  7. Jan 20, 2018 at 8:05 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
  8. Jan 21, 2018 at 12:06 PM
    Ds1234567890
    I’m not 100 percent but it felt a little taller to get into. May have been the different tire sizes
  9. Jan 21, 2018 at 3:28 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Stock 18's or 20's have pretty much the same height due to the different aspect ratio.
  10. Jan 21, 2018 at 3:38 PM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. I agree with the previous comments and I'd recommend looking at the entire package that it is included with each truck since there are different SR5 packages. Some packages include the larger 38 gallon fuel tank, tow package, etc. so that might be more important than the Off Road package depending on what you want to use the truck for.
    Good Luck.
    Tony v likes this.
  11. Jan 21, 2018 at 3:38 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    They should be the same size. Maybe it was the ground around the truck if it wasn't perfectly flat or something. If it makes you feel better being a tape measure next time.
    Good luck shopping! They are great trucks!
    NewImprovedRon likes this.
  12. Jan 22, 2018 at 4:22 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Did either of them have the steps? Could be the perception culprit...
  13. Jan 22, 2018 at 5:31 AM
    chphilo
    Western PA
    There was small variance in height in 2010 models (which I assume is the same for the 3rd gen). Typically, RC and DC are slightly taller than CM (tiny fraction of an inch). 4x4 models are taller (more substantially). I didn't see any height difference between TRD off-road and non-TRD. Surprisingly, trucks with 255/70/18 are tiny bit taller than ones with 275/65/18 or 275/55/20.
    I don't think these tiny differences can be felt by most of us (unless it's between 4x2 and 4x4). Were you looking at Tundra Pro by any chance?
