18" rim and tire question
Discussion in 'Wheels & Tires' started by JRM6868, Jan 27, 2024.
  1. Jan 28, 2024 at 7:45 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    This is my dilemma... I'd like this tire (or the similar Continental) in this size (275/70-18, which do fit 7.5" rims) in a p-metric, but they only make Load Range E. Being Michelins and with the proven tread pattern they might still drive quiet and not be to firm. Does anyone here have these?
    Michelin Defender LTX M/S2 | LT275/70R18 (tirerack.com)
  2. Jan 28, 2024 at 7:49 AM
    Tom
    Tom New Member
    Like this? I’m at 15.5 mpg and my platinum is a work horse hauling around 800-1500# daily.
    Yaboy and raylo[QUOTED] like this.
  3. Jan 28, 2024 at 8:47 AM
    raylo
    Frederick, MD
    How do they feel compared to the stockers? Not too much stiffer?
  4. Jan 28, 2024 at 11:14 AM
    Tom
    Tom New Member
    The last tire that I was on for a year was p rate GO15 so i can’t say. But from 285/70/17 35 off set to brand new 275/70/18 I can say the yoko has better wet traction. Could be the size and wheel comb but that’s how I feel and experience with new set up.
  5. Feb 2, 2024 at 9:19 AM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    275/70R18 BFGs A/T and I installed my 2.5gen 1.75 spacers up front
    rides pretty well
  6. Feb 2, 2024 at 12:32 PM
    bransull
    bransull New Member
    2023 Tundra SR5 TRD
    What's your instagram?
  7. Feb 2, 2024 at 1:54 PM
    MRQZTNDR93
    San Diego CA
    @mrqz_TRD
  8. Feb 3, 2024 at 8:34 AM
    AND
    AND New Member
    Washington, PNW
    285/75R18 Toyo AT3 load E
    No lift, no rub, no cutting/trimming.
    You could also try 305/70R18 @JRM6868
    JRM6868[OP] and Tom like this.
  9. Feb 5, 2024 at 1:00 PM
    JRM6868
    JRM6868 [OP] New Member
    2024 Tundra SR5 TRD OR
    I think I'm going with the 295/70/18 Mickey Thompson Baja Boss A/T 34.5 O.D. x 11.7 Width. They are going to test fit them at full lock to verify no rub before they put all 4 on. Based on what everyone said these should fit no rubbing. Thanks everyone.
  10. Apr 25, 2024 at 11:34 AM
    Motopilot
    Motopilot New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    Sorry for the resurrection of this thread but just got a 2017 crew limited 4x4 (trd I think) anyway trying to decide between the 285/70/r18 or the 285/75/r18 (stock rims for now) and a 5100 small leveling kit. I noticed there’s a 10lb difference in the 2 sizes for the Nitto’s. Any thoughts on choosing one over the other?
    BTW the truck is kinda stiff right now in my opinion or maybe I’m not used to it ( coming off a 2005 DC 4x4).
  11. Apr 25, 2024 at 11:52 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    You're in the third gen area of the forum....so likely won't have many comments that would apply to your situation with you having a second gen.
  12. Apr 25, 2024 at 11:58 AM
    Motopilot
    Josh
    NC/FL
    Dang it! Sry bout that
  13. Apr 25, 2024 at 11:59 AM
    teab
    Ty
    Denver
    All good just thought you should know before you took any advise from this thread....
  14. Apr 25, 2024 at 1:51 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Just curious, did you ever get any rubbing since having this tire set up, even at full lock or with any articulation? It’s what I’m hoping to do when I get new rubber, keep stock 18 in rims just upsize the rubber a bit.
    Tks
  15. Apr 25, 2024 at 6:53 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    If you have a TRD Off Road and put TRD Pro wheels on it a 285/70/18 which is an honest 34" tire will fit no rubbing cutting tucking or trimming...the key is 47mm offset vs 60mm and 8.5 width vs 7.5 or 8. This gives you just enough extra track width and is a better fit for any 285 tire. The stock tires are right at 32.5" wide 265/60/20 TRD or 265/70/18 TRD or 285/65/18 Pro. 285/70/18 is available in lighter weigh off roady sizes so your ride and gas mileage take less of hit. The TRD Pro truck has just over an inch of factory lift, enabling 35" tires to fit without mods.
    gmcguire7220 likes this.
  16. Apr 26, 2024 at 5:57 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    It must be close as I have 295/70r18 and it’s close. No rubbing but pretty close. The 285/75r18 is a little taller. It’s a nice option and I may go with it next time around. But that’ll be years away.
