'18+ OEM Hood Scoop installed on '17 Pro (Pic Heavy)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Devildawg712, Jun 25, 2018.
  1. Jul 19, 2019 at 7:00 AM
    #61
    2015TundraCrewXP
    2015TundraCrewXP New Member
    Charles
    SC
    2015 Black Tundra Crew Max XP
    20" blacks wheels, trd pro grille, color matched fender flares and handles, steel rear bumper, black leather, bakflip cover, spyder led headlights
    Looks awesome! great job!
  2. Oct 6, 2019 at 6:53 PM
    #62
    TransNone13
    TransNone13 New Member
    Sorry to revive an old thread. I planned on wrapping the scoop on mine and wanted to ask how fragile those heat shield/sound dampening clips under the hood were. If they break easily I'll order spares just in case.
  3. Feb 5, 2020 at 12:25 PM
    #63
    Tiger343
    Tiger343 New Member
    19 Tundra 1794
    Great job....Do you still have the template? I would pay you for a copy of it. Plus I have two options. Either fly you to Philly to help me or drive to CA to get help from .you. I think flying you is easier. Please let me know about the template. What lights did you use in the scoop?
    Thanks,
    615boyz likes this.
  4. Jun 2, 2020 at 8:54 AM
    #64
    chaz66
    chaz66 New Member
    chester
    14 tundra platinum,
    tires,leveling kit
    sorry a little late ,but just got my tundra and putting on this scoop,so the only thing really holing this on is them little bolts?,and you just grinded down or off those 3 hood standers ,thats what i would call them so the scoop doesnt warp,from heat or anything. what about the 4 plastic white holders? thanks for the help your truck looks great
  5. Aug 2, 2020 at 2:45 PM
    #65
    bferraiu
    bferraiu New Member
    2020 Tundra Limited
    Alright guys. I’m just about done blacking out my 2020 limited. Thanks to Roman, it’s worked out great. The last step (other than suspension) is to install the TRD Pro hood scoop. I know it’s not everyone’s cup of tea, but I’m a little confused on the install. I purchased 8 nuts and 4 clips per Roman’s instructions. The front piece came with two T bolts. I’m confused. I’m assuming the 4 clips go in the green locations. The yellow spots look like they need the T studs and nuts. The blue spots look like they do also but are slightly different. Finally, do I just cut off the red tabs? I’ve looked high and low and can’t find this level of detail. I want to make sure I get it right before I start drilling. Thanks for any help!
  6. Aug 2, 2020 at 8:07 PM
    #66
    TRDPRONORCAL
    TRDPRONORCAL New Member
    Yes, you need to cut them off.
    I also sanded them and added a double sided tape.
    GELCW likes this.
  7. Aug 21, 2020 at 9:43 PM
    #67
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    There are a few good YT videos on this install.
    KingsAustin likes this.
  8. Dec 15, 2020 at 3:13 PM
    #68
    RNDABOUT
    RNDABOUT New Member
    17 Quicksand TRD Off-road
    Is there a reason why the scoop can't be attached with 3M tape that automotive body shops use to adhere decals and badges?
    Second, is there room to mount an Air intake below the scoop? It seems like a good place for forced induction.
    Grrr. Why don't they ever build any trucks right.? Sry..that Q was redundant.
  9. Dec 15, 2020 at 3:30 PM
    #69
    Elduder
    Elduder New Member
    Possibly due to the amount of drag it incurs, the tape may not hold the air that is hitting the scoop.
    For your second, right below it is the the top of the motor, so no not really. Even if you could, the belief that ram air would do something for an EFI modern motor needs to be dispelled. To entertain the idea would require tuning, any increase in intake air velocity or mass would be accounted for by timing adjustments automatically. Hence the need for aftermarket tuning. In the event that you were to someone achieve this, the gains would be small enough that you essentially wouldn't be able to tell. It's never going to accomplish FI power gains, it never has.
    The reality of a ram air scoop would be more dirt, debris and water in the intake area, more maintenance. I've had 2 vehicles in my life with ram air hoods, it was just an additional inconvenience. The 2nd of those two was a modern vehicle, a s2000, prior to tuning with and exhaust and intake to accompany that hood it saw I think ~5 or 8hp at peak. Tuning bolstered the mid range, but the end outcome was the same as my friends running stock hoods. I eventually sold the hood because I got tired of cleaning the filter and box out.
    Every time I hear a complaint regarding how the scoop isnt functional :deadhorse: It wouldn't make a difference if it was.
    AggiePhil and ElNopal like this.
  10. Dec 16, 2020 at 5:46 AM
    #70
    RNDABOUT
    RNDABOUT New Member
    Thx for clarifying!
  11. Dec 17, 2020 at 6:34 AM
    #71
    shapinoweno
    shapinoweno New Member
    2014 Tundra Platinum crewmax 4x4
    looks good
  12. Dec 17, 2020 at 7:57 AM
    #72
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Check this YT video out. He lays it out pretty simple even for me. Hope it helps.
    https://youtu.be/WO1P3yB1B2A
    tinman10101 and Vang530 like this.
  13. May 31, 2021 at 10:33 AM
    #73
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Fantastic write up! I’m considering this route if I can’t find a hood with a scoop.
    anybody have updates?
    thanks!
  14. Jan 11, 2022 at 7:21 PM
    #74
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    Hey marine! Are you in CA? Near sac. I could use help with my scoop project. Did you just improvise adapt and overcome to drill the holes. I’m nervous about doing that to a 50k dollar truck. Any tips would be great!
  15. Feb 9, 2022 at 7:50 AM
    #75
    Ojata
    Ojata New Member
    South Elgin, IL
    2021 Tundra Limited CrewMax
    I’m about to pull the trigger and order it , but it says I doesn’t fit 2021 , I’m assuming it’s going to fit , because hoods are the same from +14 and up?
  16. Feb 9, 2022 at 7:54 AM
    #76
    It will fit.
    Ojata[QUOTED] likes this.
  17. Feb 9, 2022 at 7:55 AM
    #77
    Ojata
    Ojata New Member
    South Elgin, IL
    Thanks mate , I’m pulling the trigger !!!
  18. Feb 9, 2022 at 7:55 AM
    #78
    :hattip:
  19. Feb 9, 2022 at 7:57 AM
    #79
    Who are you ordering it from?
  20. Feb 9, 2022 at 7:59 AM
    #80
    Ojata
    Ojata New Member
    South Elgin, IL
    My friend own a paint shop who has an account with Toyota and get insane deals and I’ll use him ! As well he will paint and install it for me !!!
  21. Feb 9, 2022 at 8:00 AM
    #81
    :thumbsup:
    I was going to say Sparks parts alot of people are using now since Roman is AWOL.
  22. Feb 9, 2022 at 9:00 AM
    #82
    Ojata
    Ojata New Member
    South Elgin, IL
    If my buddy’s Toyota doesn’t have it , I’m going Sparks for sure !
  23. Feb 9, 2022 at 9:32 AM
    #83
    :thumbsup:
  24. Apr 8, 2022 at 9:51 AM
    #84
    ftmyerstundra
    ftmyerstundra New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    Anyone ever laid one of these on a 07-13 hood and see if it lines up with the indention? If not, any chance someone could measure the tidth of the scoop at the front and at the rear?
  25. May 24, 2022 at 11:12 AM
    #85
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Does anyone know the part# for the mounting studs? @Roman TIA
  26. May 24, 2022 at 11:19 AM
    #86
    ftmyerstundra
    Gary
    absolutely none
    Would love to see one of the scoops sitting on the hood of a early gen 2 to see if there is any possibility of fitting one. #Roman. Cough cough.
  27. Aug 2, 2022 at 10:30 AM
    #87
    Taahheel
    Taahheel New Member
    I have a question here: What do the flange nuts attach to? I've studied all posts on here and watch the 2 YouTube videos of quality installs and can't understand why there are only 2 of the mounting studs but 8 flange nuts. Wouldn't we need 8 flange nuts AND mounting studs to bolt it down after we drill?
  28. Aug 2, 2022 at 2:44 PM
    #88
    Cmilla25
    Cmilla25 New Member
    2015 Tundra Trdpro
    Nice I love the scoop
  29. Sep 1, 2022 at 6:55 PM
    #89
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am thinking about getting a scoop to install and having it vinyl wrapped the color I want. Has anyone done this?
  30. Apr 22, 2025 at 6:13 PM
    #90
    BoatBroker
    BoatBroker New Member
    Sarasota, Florida
    2016 Tundra SR5
    This seems like the worlds greatest mystery. Did you ever figure out the part number for those mounting "t style" bolts?
