18" alloy wheel pressure rating
Discussion in 'Wheels & Tires' started by Navy Eagle, Sep 9, 2020.
  1. Sep 9, 2020 at 11:04 AM
    Navy Eagle
    Navy Eagle [OP] New Member
    2019 Tundra 4X4 Limited Crewmax TRD Off-Road
    Performance dual exhaust, bed liner, tri-fold tonneau cover, swing tool boxes
    I have the factory stock 18" alloy wheels with the P275/65R18 tires. I am interested in replacing the tires with LT tires which will be better for towing my camper. Does anyone know the pressure rating for the wheels? Need to know if I will have to upgrade the wheels if I run pressures above 50 psig. Couldn't find any pressure info inside the wheel.
  2. Sep 9, 2020 at 12:00 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You will have no issue with LT tires on your rims. Many, maybe most of us run LT tires on the stock rims. Moving to an LT and usually E load is pretty much required if someone wants to install a larger tire on a tundra with 18 inch rims.
    snivilous likes this.
  3. Sep 10, 2020 at 8:11 AM
    Navy Eagle
    Thanks for the quick reply.
  4. Sep 20, 2020 at 10:56 AM
    Toyfosi
    Toyfosi New Member
    Tom
    Calvin, KY
    2010 Tundra
    Trailer brake,
    My 2010 Tundra has the same 18" alloy wheels with the P275/65R18 tires and Firestone Transforce HT tires. The tires have 80 psi. max but when I bought it they had 50 psi. in them. Firestone said go with mfgr recommended pressure which is 30 and 33psi. What do you guys think?
  5. Sep 20, 2020 at 1:30 PM
    Navy Eagle
    When you run P-metric tires the tire OEM will tell you to use the vehicle mfg. recommendations because they don't publish load/pressure charts for p-metric tires. Toyota customer service will tell you to use pressures on the door post (too many lawyers). My guess/concern is that Toyota sets the sticker pressures for comfort and ride based on a lightly loaded truck. If you don't tow or carry much in your truck you can run the sticker pressures. If you run near the GVWR you need to run higher pressures to safely support the axel load. If you use LT tires, the mfg. should be able to provide you a load/pressure chart. Then all you have to do is hit the CAT scale when loaded up to determine your axel load and then pressure the tires for your load.
  6. Sep 20, 2020 at 1:33 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FWIW....
    LT is overkill even in a C.
    A LT C rated tire capacity surpasses the GVWR.
  7. Sep 20, 2020 at 2:08 PM
    Navy Eagle
    True, but the LTs have a stiffer sidewall which is beneficial when towing.
  8. Sep 20, 2020 at 2:15 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    While that is a pro, there are a lot of downsides to running an LT tire. That's for the each person to weigh out themselves.
  9. Sep 20, 2020 at 3:25 PM
    Navy Eagle
    I was considering moving to LT tires when the original equipment tires need replacing since I tow a camper. Can you educate me on the downsides?
  10. Sep 20, 2020 at 5:27 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Weight = rotational mass = worse everyday fuel economy, ride quality diminishes , handling characteristics, cost (not always), tread life - to name a few
  11. Sep 20, 2020 at 5:29 PM
    Navy Eagle
    Got it. All things to consider. Thanks
