17in wheels on 2018
Discussion in 'Wheels & Tires' started by dsmith13, Oct 3, 2018.
  1. Oct 3, 2018 at 11:32 AM
    dsmith13
    dsmith13 [OP] New Member
    Derek
    2018 SR5
    My last three trucks have ran smaller diameter wheels and I have never owned a truck with anything larger then 16s. The idea and popular trend in offroad was to maximize amount of rubber by using smaller wheels and increasing tire size. Larger "rims" were for showing off and looking good rather then function.
    Jump to 2018 when I now own a new wonderful Tundra and stock wheels are 18-20in diameter. Looking at the cost to replace with similar size and little more aggressive tire for rougher conditions is blowing my mind.
    Is it common or accepted as ok to use 16-17 in wheels with larger tires? Thanks
    Sunnier likes this.
  2. Oct 3, 2018 at 11:33 AM
    T-Rex266 Moderator Staff Member
    You can go as small at 17”
    zcarpenter92 likes this.
  3. Oct 3, 2018 at 11:53 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I agree with everything you said about more sidewall rubber and smaller diameter wheel. Plus, tires for 17” can be a bit cheaper (my set of 285/75/17s were close to $400 cheaper than the comparable 285/70/18s).
    But the Tundra’s brakes are so big, the smallest you can go is 17”. Unfortunately, only a few 17” wheels fit (Methods, Icon Six Speeds and Rebounds) thus far. Maybe more selection may be offered in the future, though.
    doggiecareman, Zum, Sunnier and 3 others like this.
  4. Oct 3, 2018 at 12:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Rock Warrior wheels (OEM) are a great option for those that like off roading. Plus, 17" tires are cheaper from what I've seen.
  5. Oct 3, 2018 at 1:11 PM
    dsmith13
    Derek
    2018 SR5
    Thanks for the info and confirmation that I can run 17". I will confirm with Method on what model wheels will work with my Tundra. Do you know the backspacing numbers for your 17"? Thanks
    Sunnier and equin[QUOTED] like this.
  6. Oct 3, 2018 at 1:57 PM
    equin
    Ed
    DFW, TX
    Good post. Completely forgot anout the OEM Rockwarriors!
    831Tun[QUOTED] likes this.
  7. Oct 3, 2018 at 1:59 PM
    equin
    Ed
    DFW, TX
    Yes, my Icon Rebounds are +25 offset. I don’t remember the backspacing, though. The 17” Method wheels are +0 offset if I remember correctly. Also don’t know their backspacing. The OEM Rockwarriors are stock offset, which is about +50 to +60 or so.
  8. Oct 3, 2018 at 2:24 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, you kinda covered all the others, had to think up something. LOL
    joonbug, Sunnier and equin[QUOTED] like this.
  9. Oct 3, 2018 at 2:49 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
  10. Oct 3, 2018 at 2:59 PM
    dsmith13
    Derek
    2018 SR5
    Thanks. I've been trying to work my way through that huge thread. I'm also finding my knowledge/visualization of offset/backspacing is making me crazy. I do not want tires to stick out beyond fender wells and am only going to level front using bils 5100s on middle setting. Trying to find good wheel to wrap with 285/70/17 Falken Wildpeak A/T3W. thank guys a bunch.
  11. Oct 3, 2018 at 3:01 PM
    TheBeast The Beach
    check the Icon six speed/ Rebound specs for Tundra. I think they have it done perfect for 17"s on Tundras.
    equin and dsmith13[OP] like this.
  12. Oct 3, 2018 at 3:10 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    FN also has a BFD lookalike in 17” diameter, not sure if they’ve been realeased yet though!
    flinky14 and equin[QUOTED] like this.
  13. Oct 3, 2018 at 3:17 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I’m saving monies for these, FN wheels 17”, about a $1000 for 5 and a bit cheaper if you pay cash which I will do they’re about 2 hours from me (CA). They’re hub-centric and I’ve been told they are 22lbs a wheel!!!!. Definitely my choice.
  14. Oct 3, 2018 at 3:21 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    If I ever upgrade to true 35x12.5’s, I’ll likely go down to these from 18’s. That’s a friggin gorgeous, simple wheel! I think my BFD’s are 23-24 lbs a wheel, so that’s pretty light.
  15. Oct 3, 2018 at 3:22 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Any idea on the name of those @Samoan Thor ? They’re not on the site from what I can see.
    Samoan Thor likes this.
  16. Oct 3, 2018 at 3:24 PM
    Samoan Thor
    @zcarpenter92 its the six shooter model, still new from what they told me that’s why it’s not on their site.
  17. Oct 3, 2018 at 3:26 PM
    dsmith13
    Derek
    2018 SR5
    I like very much. I am headed there very soon with cash in hand to check those out for sure. Thanks for the post @zcarpenter92
  18. Oct 3, 2018 at 5:05 PM
    dubless
    dubless New Member
    Al
    2016 Tundra/Old—>2018 Tundra/New
    New Ride- FOX 2.5 ExtTravel Reservoirs/2.5 Piggybacks, DirtKing UCA, Maxtrac +1. Ironman POLY bushings, Wheelers Superbumps, TRD Front/Rear Sways, TRDPro SkidPlate, 35" TOYO RT, ARE CX Topper, BedRug, Husky X-Act Mats Old Rig- Bilstein 6112/5160, TC UCA CB+2’s . 17” BMF Pro SSD, 35” KO2, Snugtop topper
    There are a few other wheel mfgrs making 17’s for the Tundra. KMC, Fuel, Innov8, TR etc. Here are some 17” SOTA Offroad with powdercoated rock rings on my old truck.
    For my new truck I went with FN Six shooters through Dustin@ FN. Love the understated JDM look, quality, and great offsets of his wheels.
    Just waiting for one 35x12.5 Toyo RT that got lost in shipping :mad: then I’ll post up new pics for you guys.
  19. Oct 3, 2018 at 5:11 PM
    TheBeast The Beach
    those FNW wheels are mighty fine. what are the specs as far as offset and backspacing ?
    dcsleeper408 and zcarpenter92 like this.
  20. Oct 3, 2018 at 5:14 PM
    dubless
    dubless New Member
    Al
    Mine are 17x9 et25 Gunmetal. Contact Dustin at FN wheels for pricing. He’s a super cool guy and a Tundra fan!:thumbsup:
  21. Oct 4, 2018 at 7:16 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Method Race 701 17 x 8.5 0 Offset
  22. Oct 4, 2018 at 8:25 PM
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    17 TRD PRO Barcelona Red
    mag2650, ported 85mm TB, lt headers, 3" midpipes, 3" exhaust, 5.29 gears, 37s, and a few other things
    I'm still trying to decide between the FN fivestar or the sixshooter myself, both are 17x9 +25offset. Just cant make up my mind.
  23. Oct 4, 2018 at 8:31 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    FN wheels has a 17x9 five star (like the ones on the truck) with +25mm for our tundras? I didn’t see those on their website.
    flinky14 and zcarpenter92 like this.
  24. Oct 13, 2018 at 7:55 AM
    thetroll262
    thetroll262 New Member
    2010 Black Tundra Limited TRD
    Where are you getting the intel on these wheels? I can’t track them down anywhere on the interweb.
    A light weight 17” wheel is exactly what I’m looking for on my tundra and the TRD Rock Warrior wheels don’t really do it for me.
  25. Oct 13, 2018 at 9:49 AM
    Samoan Thor
    dcsleeper408, Sunnier and dubless like this.
  26. Oct 14, 2018 at 8:42 AM
    thetroll262
    I will! Thanks!
  27. Oct 14, 2018 at 8:52 AM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    Tmu, offset and backspacing are the same thing. One is measured in mm’s (offset) and one is measured in inches (backspace). Typically you need only one measurement, not both
    Sunnier likes this.
  28. Oct 14, 2018 at 9:08 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
  29. Oct 14, 2018 at 11:23 AM
    TunderStorm
    Michael
    ^ That looks awesome but I couldn’t live with the offset of those wheels. I went with 18’s. Great middle ground between 17’s and 20’s imo
    SoCal619 likes this.
  30. Oct 14, 2018 at 1:52 PM
    TunderStorm
    Michael
    Fuel Vapor 18x9 +20
