1794 Wood Trim Wrap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cwalker417, Apr 5, 2022.
  1. Apr 5, 2022 at 2:46 PM
    Cwalker417
    Cwalker417 [OP] New Member
    I've decided that I can't stand the fact that the steering wheel wood grain is darker than the door and dash trim wood grain. I'm looking into seeing if I can wrap all these pieces with a brushed metal looking vinyl, similar to the texture/color on the trim around the radio. Does anyone have experience doing this? Can you pop the wood grain pieces on the doors off or do you have to remove the whole door panel?
    Link to vinyl
    VViViD® XPO Silver Brushed Steel Car Wrap Vinyl Roll with Air Release Technology (1.49ft x 5ft) https://www.amazon.com/dp/B00YLFUBIG
    If anyone has any other suggestions would love to hear what you've done.
  2. Apr 5, 2022 at 7:19 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I'm planning to wrap the fake wood pieces too but I'll probably just leave the pieces in place even if it is easier to wrap them removed.
    The dash panels will come off but it looks like there is a bottom to top order to how the panels come off. As far as the doors go those look like they are not removable but I haven't found a definitive answer yet.
    @2020Platinum has a video on the dash disassembly:
    https://youtu.be/xu1C1AapaAI
    another dash disassembly:
    https://youtu.be/goeP-D8hH94
    2020Platinum likes this.
  3. Apr 5, 2022 at 7:33 PM
    Saltyhero13
  4. Apr 5, 2022 at 8:22 PM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
  5. Apr 6, 2022 at 10:11 AM
    Cwalker417
    Thanks for all the posts very helpful. Don't think I want to remove the door panels and drill out the clips though. Anyone ever wrap these pieces in place? Do you use a blow dryer or just stick it on and cut the excess?
  6. Apr 6, 2022 at 1:56 PM
    Saltyhero13
    A few ways to do it.
    You can cut them slightly larger than the piece being wrapped where you would tuck the excess under the edges of the piece with a soft tool. Heat gun is usually necessary for pieces with a lot of features and contours where stretching the wrap is necessary; squeegee will be the main goto for the featureless parts.
